FixYa.com
Tags:
Acer AL1711 17
Power board malfunction (by 4 users)
posted by shan x on Mar 28, 2008
The technician said that my power board is gone. What can I do about this?
Should I scrap the monitor and go for a new one or is this fixable? I would also like to know if the components are available for purchase and/or if it is cheaper to go for a new monitor altogether.
Your advise is much appreciated.
Thank you
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by Guest, posted on Apr 20, 2008
the monitor extinguishes (dark) him after a pò that is in operation.
Best Solution
posted on Mar 28, 2008
FixYa! (100)
Benimur
Rank:Guru Guru
Rating: 87%, 2237 votes
There may be four (4) ways the repair could be done:
1. board - an entirely new power board maybe available from the monitor manufacturer or you can Google for OEM provider;
2. board - a refurbished/reworked board may be available, again you have to Google. Both 1 & 2 would require that you search for the actual PCB assembly number;
3. use the power supply board from an identical unit that has defective LCD panel, inverter or other problems/defect other than the PSU; and
4. component level repair - determine which components in the power supply are defective and needs replacement.
All of the above would require time. Time to look for the replacement board, time to determine which component to replace, time to do the actual repair.
Cost - depends on the tech. Of course board assembly would cost more to purchase but should be relatively easy to perform and therefore should not be expensive in terms of service. On the other hand, component level repair often would be cheaper in terms of parts purchases but would cost more in terms of service fees.
Taking into considerations the above factors, it may be more to your advantage to do the repairs yourself (no service fee). Still should you be uncomfortable on a DIY, then the cost of repairs might justify the purchase of a new LCD monitor instead.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Rating Locked! (?) shan x has rated this solution as FixYa!
Can you Help with these Monitors problems?
Acer AL1711 17" LCD Monitor
acer al1711 monitor
you said that the... Answer This...
My Screen is "greyed"...
Full size:... Answer This...
Acer tft AL 1711 doesn't stay...
It takes many times switching... Answer This...
Thanks
Thanks Zeb6, your hints fixed... Answer This...
Acer al1711 shows only a white...
I searched for this problem on... Answer This...
Repair Service
Find Monitor Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
