Question about Karcher 2500 PSI Pressure Washer
No pressure coming out of hose when motor is going hard I can put my finger on the end of the spray wond and there is hardly anything Karcher 5.0hp GC160 K2400HH
  • 3,740 Answers
First thing is remove the water supply house and check the water screen for clogs. Remove the hose washer and pull the screen out. Wash and clean the screen then re-install. Make sure your using a 5/8" hose as a supply hose and that the water faucett is turned all the way on.
If after all of the above it still has low pressure the unloader valve is most likely corroded or has debris in the seals.
Download this parts manual The unloader / thermal valve that is supposed to reset is Item(s) 9 {Valve 60 GND} and 12 {Spill Valve} of detail A on page 11. The spring, seals and housing need a good thorough cleaning to get high pressure. If the seals are damaged they will have to be replaced. Lubricate the seals with lubriplate white grease No. 105 before you reassemble the unloader valve. Grease link: http://www.lubriplate.com/webstore/default.aspx This grease is at any automotive store.
Thanks for using FixYa.
Kelly
Posted on May 12, 2010
We have a Karcher, Model K3300G S/N 041477,
so no pressure, check the pump hit the switch, rev the motor
Sep 04, 2014 | Garden
Soap feed
I fixed mine works good too, watch my video step by step i put it on youtube
http://www.youtube.com/watch?v=UFXSLOBL0Mg
Jan 26, 2013 | Karcher G2650HHR Gas Pressure Washer
Karcher puzzi 100 not spraying
blocked pressure hose or blocked nozzle at the end of the wand
it is controlled by a pressure relief regulator which quite often plays up.
Jul 19, 2012 | Garden
IT HAS PRESSURE BUT IT PULSATES INSTEAD OF STEADY SPRAY
I have same model with same problem. Tried the easy fixes:
unloader valve lube and clean, inlet water sufficient, and nozzles and hose are fine. Broke down pump and called for parts (about $50 for 3 inlet valves and some seals) hopefully this will fix it. Mine has been used in my business pretty hard for a few years, so not bad.
Joebro
Jun 11, 2011 | Karcher G 2600 VH Gas Pressure Washer
My Karcher 720mx moter is working fine but i have no water pressure coming from pump
hi put some silicon spray in inlet and outlet then reconnect hoses what is going on is when you store it the seals start to dry out.........
Jan 13, 2011 | Karcher K3.68MR Electric Pressure Washer
I own a Karcher 3000 pressure washer. There is no water pressure. I've checked the obvious...hose to house, kinks, attachment is tight....Enging runs, no water pressure.
I had the same problem. On the top of the pump there is a little nickle colored button cap. It is attached on both sides with a screw. What this actually does I don't know but when I took it off with the motor running and put my finger over it the pressure come up. I also discovered that having the motor running and taking the nozzle tip off and pulling the trigger would clear the pump to work until you let of the trigger again. Weird but it works for me.
Aug 06, 2010 | Karcher Garden
Karcher 320H i have the same pressure coming out as i put in from the tap, the motor is running ok
You have an air lock in the pump and or piping.
  • Open all drain cocks and remove the spray hose
  • Connect the inlet water hose and turn it on slow
  • allow water to run from all open ports for 2 minutes or so
  • leave the water running - close drains start motor
  • Shut down reconnect spray hose restart
  • You should now be smiling
Mar 08, 2010 | Plumbing
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
Karcher k3.86 motor runs but has no pressure when trigger pulled, motor doesn't go faster.
Could be a pump, but most likely the unloader valve is stuck open. After replacing/repairing the valve, do the following to prevent it in the future: after finishing using it, unhook both hoses and pull the start cord on the engine several times to empty the water from the pump and valves. This is especially necessary when using hard water.
Nov 19, 2009 | Karcher 2500 PSI Pressure Washer
Have honda karcher 5.0 pressure washer and i cant get it to spray any water or pressure out the gun at all? Why??
That is a on going problem with power washers the pump not working, than works sporadically. the main cause is leaving the pressure hose hooked up to the machine over a long period of ,not draining hose & machine, in the winter time the hose & pump willfreeze causing hose & pump to expand and burst. build up of calcium deposits from hard water clogging up pump nozzle,valves in the gun handle,clogging hose fittings and screens.one of these has to be your problem.you can find a parts brake down at KARCHER.COM.orRJ BOWERS.COM . and manuals,these are good info,sites,hope this helps, MrFixIt,oh could you please rate this solutions
If it is not leaking water anywhere and the nozzle is OK then go HERE
Turn it off and shut the water of. Go to pate 2.1 of the manual
Carefully remove part #2. Pull out part # 1 and make sure the O-rings are in good shape ad are lubricated with a good waterproof grease. Re-assemble and try it.
Thanks for contacting Fixya
Jul 01, 2009 | Garden
Karcher 2500 PSI Pressure Washer Logo
747 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
