Marantz Amp I have a Marantz 6010OSE KI signature amplifier that has a problem. Whenever the amplifier is moved, the left channel stops working, or will only emit very weak sound with no bass. If I tap the side or top of the case eventually it will start working again. Sometimes it will start working again straight away, and at other times it will take quite a few taps before its right. Any ideas?
  • 3 more comments
  • wadden Mar 28, 2008
    No, it is still just out of the right channel when I turn it up
  • wadden Mar 29, 2008
    Thanks for the help Graeme, I had the top and back off the amp last night and checked everything. There was nothing obvious regarding the soldering, but when I put it all back together, there was no sound out of either channel, until I pressed the source direct button, then perfect sound on both channels. Does this suggest it might be something to do with the balance control (there are no tone controls)?
    Many thanks
  • wadden Mar 31, 2008
    Thanks Graeme, I will give that a go and hopefully all will be ok.
  • Graeme Ross
    Graeme Ross May 11, 2010
    Ah, could have been a speaker protection relay, but this fault often clears when you turn up the volume.
    Sounds like dry solder joints in the amp. Have you removed the covers and checked about the power stages for dry solder joint, or cracked heat stressed connections about output stages and power supply. 90% of problems in audio output stages are generated by fry joints and soldering failure. I often blanket resolder every joint, to ensure that there are never any again in the future.
    Gte back to me here and we can go further after you have checked for soldering problems.
    regards
    Graeme
  • Graeme Ross
    Hi there, a question for you.,.. what happens when you turn the vol up, does the audio clean up and come good?
    regards
    Graeme
  • 1,512 Answers
Hi, well done in diagnosing your problem:) From what you have just told me, the amp has noisy source selector switching, and may even have more than one switch or control causing the problem. Start with the source/direct button.
To resolve this, best bet is to "flood" the internals of the switch or control with CRC 2-26 . This will clean the contacts and leave a layer of lubricant to prevent the problem reoccurring, Getting the spray into the controls is the hard part. Check out what you find by way of entry points that you can get a the delivery straw into to spray. Sometimes you can use the a hole on the top of the switch, or "click" the top of it a little, enough to get the sray in. If the switch is a hermitcally sealed type, i have in the past used a pin vice and a very small drill to make a hole at the very back of the switch creating a place to get the spray in. Check it out and see how you go.
regards
Graeme
Posted on Mar 29, 2008
Can I connect a modern DAC like the Schiit Bifrost to my Marantz CD6000 OSE KI signature, or have digital output standards changed since then?
I can't find a manual of a manrantz CD6000 digital camera. Sure you are in the correct category?
Nov 06, 2013 | Cameras
Can i connet my marantz ki17 amp to a power amp
Hi, i don't really understand why you want to connect an amplifier to an amplifer.
Might be that you want to get a louder volume or ?don't know.
I don't think there is any need for you too connect marantz ki17 amp to a power am. Both do the same work, but might have different watts.
So you will need to check what you want to connect with the amplifier first and check the watts that can carry it without interference from the amplifier.
I guess that would do the magic.
Have a nice day.
Feb 18, 2011 | Marantz PM-15S1 2-Channel Amplifier
Hi, I have a Marantz PM7200 KI Signature, This morning sadly realised that the amp is gone, There is no light on, something like no power. Firstly, I look for the fuse socket but there is no socket on...
hi,
First of all check the power at the socket to which you have connected the amp.If you are not aware of electronics, then do not go for a test with an amp like KI signature.
it will have a fuse in its inside. its only blow off if there is some fault inside the its circuitry. consult someone who is well equipped for the same.
ok
Feb 06, 2011 | Marantz PM7200 2-Channel Amplifier
I have a Marantz PM6010SE K1 signature amp - just for listening to CDs, if anyone remembers them. The amp creates a low level (mains) buzz in the left speaker. If I turn up the volume to max the low...
Use on the control buttons and other switches balance contact spray as the first step let it work for a few minutes.
Control the print for some loose components (solderings) by carefully some manipulation and movement on print and components with a wooden or plastic object, because solderings on active heat-conducting components have allways high priority on the end stage, and in power supply primary you can become early loose components in the solderings if the manufacturer has used leadfree solder. If you have after this no improvement then ALLWAYS refer the damaged to find components replace always twice (on both sides) each other replace if a damaged deformed capacitor or diode was found both as well left as right the same brand components , be carefull in replacements its very important because of in most repairs refurbishing for tonal influences Passive components as example (only suggestion) to take a capacitor 10Volt 330 MF then replace it for a 16 volt 330 mf the size should in most case be the same of the component its very important for tonal effects and balance, in most repairs is that more size format on capacity sounds better as the new order components become smaller on the same voltage its better to get the higher voltage capacitors with the same size as the old lower voltage ones.
http://akdatabase.org/AKview/albums/userpics/.../Marantz%20PM6010F%20Service.pdf
Jun 27, 2017 | Marantz Audio Players & Recorders
Center channel dosen't work on 10 yr old marantz 500$ receiver. Should I just buy a new one?
I'd do some more investigation first. Have you determined if the amplifier for the channel works or if it's a preamp problem using the built-in speaker setup controls?
With this unit's great audio processing features you might be able to bypass a failed amplifier using the pre-outs and drive an external amp for the missing channel.
You could always just get a modest stereo amp (like a Carver M-100T and bridge it), or use the extra channel for another center speaker or a subwoofer, for example.
Aug 12, 2010 | Marantz SR5500 Receiver
I have a Marantz PM-66SE Ki amp which appears to have a problem with one of the channels which is only outputing about 10% of the volume of the other channel. Have tried swapping speakers and cables around...
I have exactly this same problem with my Marantz PM60100SE - one of the channels seems to have lost power and is much much quieter than the other one.
Did you find a solution to this? Anyone have any ideas?
May 20, 2010 | Audio Players & Recorders
Marantz dedicated amplifier squeals
The symptom sounds like a feeback loop. As long as that indicator is showing near maximum output on one channel AVOID ATTACHING ANY SPEAKERS TO IT!!!! You'll cook the tweeters.
Turn it off and manually operate every control, knob and pushbutton throughout its range many times to wipe oxides away from their conductors.
Set all EQ controls to their midpoints and re-evaluate.
We don't know if it's an input or output problem yet. Does it do that with all inputs?
Jan 19, 2010 | Marantz PM7200 2-Channel Amplifier
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Heat in operation of marantz pm 74d
Sounds like your left channel output transistors are getting weak.
Jan 17, 2009 | Marantz PM-68 Amplifier
Marantz PM4000 amp keeps cutting out
There is a fairly simple fix to this problem here: http://www.audiotoolers.com/ubbt/ubbthreads.php/topics/5316/Problems_with_Marantz_PM4000_A.html
Apr 22, 2007 | Marantz ZS5300 6-Channel Amplifier
89 people viewed this question
 Grubhead
Grubhead
