Question about Dishwashers
I have an old hoover Crystaljet 7000 dishwasher, which got stuck in the wash stage with water in it. After many attempt to turn it on and off again it moved on a stage ( I think to rinse) but stays there. Is there anyway to reset it? or any ideas on where it is jammed? Thanks
5 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: Kenmore Ultra Wash 3 (6651694193) stuck in wash cycle
There should be 2 thermostatic switches in the heater area. They are just simple bi-metallic "button" switches.
One will trip at the correct temperature - and tell the programmer to advance now the water is hot enough. The other will cause a shut-down if the water is over heated.
It is the first one you need to replace - I wouldn't bother testing it.
Obviously - disconnect everything before opening up (I have to say this) and only if competent to carry out a repair.
However - you don't know which is which?
To test them. Remove one, put inside an empty can , and put 1" of water in a pan onto boil. Test continuity with a meter when cold - and when sitting in boiling water.
Turn off heat, and see which trips first. That is the over-temperatue one. When a little cooler, the other should trip. This low setting one is likely the faulty one - so will not trip or contacts will be faulty.
These are available online from various appliance retailers.
Posted on Aug 15, 2009
Testimonial: "Thank you very much!"
  • 5 Answers
SOURCE: have a hoover hed6612 dishwasher just over a year
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Posted on Mar 30, 2010
Daniel S
  • 4323 Answers
SOURCE: Hoover Crystaljet 7000, seems to
Hi
First thing that should be checked is the drain hose, try to clear the drain hose for any blockages and then check the drain pump operation. If the issue remains and the pump is working then it is the Timer that is bad causing this issue and should be replaced to solve it. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 10, 2010
ercupa190
  • 12223 Answers
SOURCE: DISHWASHER GETS STUCK ON THE 1ST RINSE CYCLE
see the diagram attached.
1) Test the switch door,it is defective, the starting relais turn off, and consequenc the motor off.
2) TIMER: TEST FOR DEFECTIVE, clean contacts, repair wires loose, burn or broken.
God bless you
Posted on May 10, 2012
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Hoover floor mate sucks up water while in the wash position
They do that. They pickup the water in all stages but lower the squeegee to different heights. At no point does the suction turn off.
Jan 20, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover ddy068t dishwasher keeps discharging water
dirt in the waste pipe or something stuck in it thanks
Aug 27, 2012 | Hoover Dishwashers
God bless you
May 09, 2012 | Candy Dishwashers
Bosch SMU7052UC gets stuck in wash cycle. Pressing alot of buttons, on/off, I can move it to rinse where it sticks again. No drying either. Any suggestions?
I have a 10 year old Bosch SMU 7000 and the drying function has ceased. Dishes are wet after all cycles. From what Ive read this isn't worth fixing because Bosch are so difficult to get into.
Jan 23, 2010 | Bosch 24 in. SMU70 Built-in Dishwasher
Dishwasher will not advance beyond water fill stage
when it fills and water stops /the motor will start up in a min.or so. you should be able to hear the motor & water or just a hum then the motor will click and quit .. the seak kit came with a tool to center the pump housing properly / if this was done it should work. unplug motor and run thru cycle if it finishes cycle timer ok and pump is still problem . the motor may have been damaged from the first problem and water got in top brg. ck motor see if it will turn ...mm
Nov 22, 2009 | Dishwashers
Item: Whirlpool Ultra Dishwasher Age: 3 yrs Problem: Not enough water to effectively wash the dishes. State: When the dishwasher is started, the fill valve opens as normal. Only about 1/2 the amount of...
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Oct 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher overflows from front
Hi andrew did you get this fixed as it sounds identical to my problem.
Ian
Sep 01, 2009 | Hoover 24 in. HD83M Free-standing...
Dishwashers Logo
239 people viewed this question
Top Dishwashers Experts
Owen Barnes
