Question about RIM BlackBerry Pearl 8100
When i am pressing my track ball its not responding
Hi frens,
thanks for your assistance in many problems... i got a problem with my bb 8100 track ball.. there is no problem in selecting the icons upwards or downwards or sidewards... but when i am pressing the track ball to select them its not selecting them.. i try to press hard but no use.. can u please help me in this issue...
thank u
  • 9 more comments
  • Karamazov Apr 05, 2008
    I am having the same problem. My BlackBerry ball will not select, but it is able to track. This problem seems to be circumvented, however, whenever it comes to typing messages, I cannot select letters or words.
  • btsri Apr 07, 2008
    i have the same problem and now my problem is gotten worse.. the selected icons are selecting by themselves.. for example.. when i am talking with my fren on phone.. it selects the menu button and it automatically press mute or do the same procedure to unmute..
  • Anonymous Apr 28, 2008
    taken battery out turnen on and off
  • Anonymous Jun 03, 2008
    dude same problem
    it wont select and when i tried to restart my whole keyboard stopped working!!!!!!.... same thing for my cousin and she couldnt get a new phone....
    and now it keeps typing in things by itself
  • Anonymous Jul 02, 2008
    Same problem. I asked a few friends that have them and 2 said they had the same issue. Its the software, unless you broke it
  • telinal Jul 26, 2008
    Similar problem: when I press the trackball button, it actualy behaves as though I am pressing the "Q" key. I even tried by removing the trackball and pressing with a "Q" tip to emulate the ball pressing down, and it does the same thing, it seems very odd, but I am afraid it is not a hardware problem...  I am wondering if the trackball can loose calibration? Can it be recalibrated?
  • aschissler Nov 14, 2008
    Same thing here, It started out not working at all then it worked fine for a couple hours and now its just not stop clicking, I bet its made 100 calls and sent atleast 500 blank messages out on its own, im going crazy here someone help
  • Anonymous Jan 01, 2009
    8330 Sprint Curve, keyboard spontaneously stopped working.  Have tried battery pull.  Have tried battery pull and waiting for 30 seconds.  Have tried alt, right shift delete.  Nothing.  The track ball can highlight items, but not reset them.
    This happened once before, and then fixed it's self randomly.
    What a bunch of ********.
  • jgraham18 Feb 04, 2009
    i can scroll all directions but i cant select the icon unless i press the enter key. when i depress the roller ball nothing happens.
  • LPNL Apr 15, 2009
    i have the same problem but mine also randomly clicks in on things. is this a problem with the ball, software, or does it click from underneath the ball?
  • akojim May 11, 2010
    Solution link . . . . http://www.IMBlackBerryPearl8100.com
  • 14 Answers
Get a sheet of paper or a pad of paper, put your cell upside down so the rollerball is touching the paper... Rub the phone on the paper quite vigerously. This has been a problem for me with many pearls - there is some dust / dirt lodged under the ball which stops it behaving the way it should. You may need to do this in all directions.
Posted on Oct 13, 2008
  • Wikaitaia Dec 23, 2010
    I just triedd the paper trick
Hey! this is actually a flaw with the software on the newer blackberrys. Mine did the same thing, one day it was working fine in the morning, but in the afternoon, nothing. Would only show its display after plugging it in to a charger or usb cable, the trackball would scroll on the home screen, but if i wanted to click in on anything, forget it! none of the buttons worked, the entire keyboard? rendered useless. Take it in to your local wireless provider and have them take a look at it. My provider (Sprint) went ahead and ordered me a new one since it was still under warranty.
Posted on Apr 14, 2009
    Problem Solver:
  • 5 Answers
The metal ring and the actual ball can be removed but be careful and pick the ring up straight so you do not break any prongs from the ring, after removing them you will see a yellow piece of tape pull that up and clean under the clicker under the tape, put tape back on the center of clicker and place track ball back in, than put silver ring back in with three legs to the bottom hole at top...Hope this helps if not you can purchase new track balls at wirelessparts.com
Posted on Nov 18, 2008
  • 846 Answers
The only way to fully get it up and running again is remove the trackball and replace the switch membrane underneath. If you want somebody else to do it for you, goto Blackberry Button Repair. If you want to do it yourself, here is a Blackberry Repair Guide that shows how, the part is available on Ebay.
Posted on Jul 19, 2010
“call” , “call end”, “A” keys and trackball select on my bb 9700 will not work! would this be a moisture problem? Will shift-alt-delete solve this?
Posted on Mar 29, 2010
@telinal : Same problem happened to me and after I remove the trackball and clean it inside (with an earpad) it started behaving as normal
  • 113 Answers
You can get the keypad and trackball from www.blackberry8100parts.com
probably the cheapest place
Posted on Aug 17, 2008
Yehhh i just got the same problem today!!!!! at first my whole keyboard was just not working at all now its only the trackball im so pissed off im gonna beat the hell out of the guy that made blackberry pearl lol
Posted on Jul 20, 2008
Hey call your service provider i had the same problem i called them and they said ya there is a recall and they are sending me a new pearl in the mail i have t mobile but even if you bought your pearl right from blackberry they will replace it that goes for the blackberry curve too.
Posted on May 29, 2008
Hey lads, suffering from the same problem however the return/enter button functions as a select button. A small bit of an inconvenience but grand nonetheless.
Hope this helps.
Posted on May 27, 2008
    Problem Solver:
  • 5 Answers
Try the link www.blackberry.com/RimBlackberryPearl8100
For find a best solution.
Please Rate me if this information helpful for u.
Posted on Oct 19, 2008
My BB doesn't turn on>
My bb track ball does not respond and the letter (A) is the only letter not responding,,i am current unable to get my bb unlock, because the (A) is part of my code
Mar 29, 2010 | RIM BlackBerry Bold 9000 Smartphone
BB Pearl's trackball scrolls but it will not
There is probably some corrosion underneith the center dome cover on the select button. It is held on by some tape. Simply remove the track ball then remove the center select button dome and clean/scrap both sides with a small screwdriver and reinstall. You will probably have to retape it down. This should get you up and running in no time.
Dec 14, 2009 | RIM BlackBerry Pearl 8100
My BB Pearl 8100 tracj ball will not select when I
The trackball dome and/or module is bad. Try www.bbmedic.com
Dec 12, 2009 | RIM BlackBerry Pearl 8100
Rollerball will not go up it goes left and right and down
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 16, 2009 | RIM BlackBerry Pearl 8100
My BB Pearl 8130 goes into camera mode and takes pictures by itself. Also the roller ball does not click anymore so i cannot select anything on any of the menues. HELP!!!
This might be because of Hardware issue you need to walk into the service center to get it repair.
For your track ball:-
1) Go to menu
2) Select Option's
3) Select screen and key board
4) Make Horizantal and vertical sensitivity to 100, Still not working you need to walk into the service center.
Nov 09, 2009 | RIM BlackBerry Pearl 8100
Tracking ball not working after cleaning it exactly as directed
do a battery pull.. wait 30 to 60 seconds, the reboot up you blackberry, and firmly press down on the tracking ball as you scroll up
Jun 11, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl
Common faults with Pearls, do you have warrenty on the Phone?
Send it back for replacement as its hardware fault.
I hope this helps,
Thanks.
Mar 07, 2009 | RIM BlackBerry Pearl 8100
Pearl roller ball
It might be a case where the track ball has some dirt or debris underneath it. First, turn the device off. Next, press down firmly on the track ball while at the same time rolling it in every direction. Hopefully that will knock loose any debris. Another tip to try is to wet your thumb with a little water and do the same thing.
If those two options don't work, you may try taking out the track ball and blowing out the slot with some compressed air. Below is a link that shows how to remove and clean the track ball:
http://www.blackberryforums.com/general-8100-series-discussion-pearl/113889-how-clean-trackball-your-pearl-8100-a.html
Oct 03, 2008 | RIM BlackBerry Pearl 8100
Blackberry pearl
First, turn off the device. While pressing down firmly on the track ball roll the ball in all directions.
If that doesn't work, then you may need to take out the track ball and blow it out with compressed air. The link below shows how to disassemble the track ball:
Oct 01, 2008 | RIM BlackBerry 8700c Cellular Phone
BlackBerry 8100 Pearl
You can order a replacement trackball at www.blackberry8100parts.com for $9 its easy to install
Jun 02, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
2,857 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
