Question about Crown I-TECH 6000 Amplifier
How much power does a single Crown IT-TECH 6000 occupies from power socket
  • 311 Answers
Http://www.crownaudio.com/pdf/amps/137434.pdf
it varies between what you are playing and how you have wired the speakers
Posted on May 10, 2010
I have an Element LCD flatscreen model Eleft326. Can I hook up my Polkaudio Surround Bar 6000 to it?
surely there is a scart fitment that will allow this? I imagine that the connection is possible by some means or other, if you have insufficient scart sockets obtain a scart expansion device, I haveone , can put 4 scarts on my single slt tv. Ebay or Radioshack should have these
Apr 24, 2016 | Element Televison & Video
I use the crown xti 6000 for 2 double 18s pd186 for bass per channel
Send a signal from the mixer to the amp directly, seems as if you have a distorted signal from your crossover
Dec 23, 2013 | Crown XTi 2000 2-Channel Amplifier
Fuse keeps blowing, tech replaced a 'faulty' battery but it continued. Tech then fixed a 'short in th wiring and still the fuse keeps blowing. Not sure if this is a glitch or an actual problem with just my...
What fuse keeps blowing (drive or hyd HEAVY FUSES or light fuses probs for invertor controller LIGHT FUSES), low batteries or running on discharged batteries for a period of time can blow the fuses. Have the motors been tested? Is the drive an AC and hyd a DC?
Sep 20, 2013 | Crown Walkie Pallet Truck Electric 6000 lb
2 speakers and 1 powered sub
The red and black connectors are the right (red) and left channels for the speakers, so they should connect. However the sub needs a single RCA type phono socket, which should be marked "sub" etc. If it hasn't got one of them you will have problems connecting the powered sub.
Jun 07, 2013 | Crown CE1000 2-Channel Amplifier
How much watts is the crown ce 2000
Depending on the configuration of speakers you have it will deliver different amounts of power up to 1950 watts when used to power a single 4 ohm speaker. Typical usage would be powering a pair of 8 ohm speakers, in which case it will deliver 400 watts per channel/ speaker.
Sep 16, 2011 | Crown CE2000 2-Channel Amplifier
I have a crown Itech 4000 and when I plug it in it the green light around the front power button does not light up and when I turn on the power button on the front only the blue "power" light...
Nice amp. There is a breaker/switch on the back that trips to protect the amp. Turn it off, then back on and see if the green indicator comes back. If the breaker trips again, that's probably an indication of a more serious internal problem.
Nov 09, 2010 | Crown I-TECH 6000 Amplifier
Had a new battery fitted to my tag 6000 and now 2 of the dials dont reset to zero
To reset the chronograph dials back to zero do the following:
1) Pull the crown out to the position where the date can be adjusted and push the buttons.
2) Pull the crown out to the position where the time can be adjusted and push the buttons.
Jan 06, 2009 | Tag Heuer 6000 WH1312.BA0677 Wrist Watch
TS-6000 Shredder Problem
1800 639 3803 tech solutions service hot line for the ts6000
Aug 18, 2008 | Tech Solution TS-6000 Shredder
117 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
