Question about Bosch Dishwashers
Solenoid Vater Valve or Aqua Stop Valve
If the dishwasher is left overnight not in uses, water seeps slowly back into the dishwasher.
With the door open and the 'on' button depressed, the dishwasher begins pumping away the water that's gathered. At this point the door is still open and no programme has been selected.
I am told the water inlet valve needs replaced but on my model, the only thing I can see is a aqua stop valve.
Spare parts suppliers quote Bosch part No. 167025 which is a Solenoid Vater Valve and Bosch part No. 263789 which is an Aqua Stop Valve
Bosch model SHV43A03GB/42
  • 1 more comment
  • brian_burns May 10, 2010
    Thank you for your reply but I'm still not sure which part I should buy is it the Solenoid Vater Valve or the Aqua Stop Valve?
    Thank you for your reply. I accept your answer but can you suggest where I coudl fnd instructions for replacing the Aqua Stop Valve?
  • brian_burns May 11, 2010
    I found the second solution to be the easiest to understand and the advice on how to replace the part very helpful. I would recommend your service.
    President:
  • 949 Answers
On your model the aqua stop valve is the root of what is causing the leak, the check valve inside the aqua stop is reducing the pressure too far and the seat on the water inlet is bypassing due to the aqua stop.
So to repair this order the second part you list No. 263789
Let me know if you need more clarification.
Posted on May 10, 2010
  • Philip May 10, 2010
    The part is located under the dishwasher in the lower pan. It is between the water inlet from the house supply and the water inlet to the tank on the dishwasher.
    The dishwasher will have to be removed from the installation and the water and electrical supply to the dishwasher turned off while make the change.
    With the dishwasher out lay it down carefully, you should be able to remove the lower pan and see the component. It is not not difficult but can take a bit of time.
    Once you are done, check very good for water leaks!
    Let me know if you have questions.
  • Bosch Master
  • 12,061 Answers
Http://www.managemylife.com/mmh/Troubleshooting_Guides/Dishwasher.pdf
http://appliancejunk.com/ge/dishwasher/31-9137.pdf
http://appliancejunk.com/ge/dishwasher/31-3280.pdf
please find above some dishwasher DIY help sites, and service manuals, these manual should help you troubleshoot and repair your dishwasher. If water seeps in, it is the INLET solenoid that's leaking and probably needs replacing that or the seal has gone, wither way you may need to replace the entire thing. It is NOT the outlet valve, the only way water gets into the washer is from the water inlet valves, on the Hot & Cold taps.
How do I get to make it stop and work .Dishwasher is not shutting down it says E 15 Water tap flashing , and red Aqua stop light .
inlet valve is the aqua stop long hose to tap has a solenoid at tap end that is likely your fault
Sep 29, 2016 | Bosch Dishwashers
AEG Favorit 44090i Dishwasher will not fill with water
There may be a filter after the aquastop pipe which is blocked. This is usually at the back of the inlet valve. Also, the inlet valve may no longer work.
Nov 07, 2014 | Dishwashers
AEG Favorit 44080i Dishwasher will not fill with water
Well, this was very long-winded. If it works when filled manually, then check the stopcock for the water flow and open it more if not all the way. If this does not work, try the water pump in the back/bottom of the disher
Error 305 on meiko dv200.2 what does it mean?
Could be a faulty booster level / pressure switch. Do you hear the air gap cup filling in the back? Could be a faulty fill solenoid (aqua stop hose with solenoid at water inlet.)
Aug 31, 2013 | Meiko DV200.2 Door-Type Dish Machine
My Kenmore Elite dishwasher (model W10082943A) is draining very slowly, what should I look for to fix it?
If your Dishwasher is not Draining check the following
PISTON VALVE
On some dishwashers that have a filter (screen) along the back wall of the tub have a piston valve. The piston valve commonly causes dishwashers not to pump out. if your dishwasher does have a filter, remove it. Now remove the piston valve located in the center behind the filter. Now to check the piston valve, press up on the spring. Once done the piston should stop up the hole in the top of the valve. When a piston valve, is bad the piston dissolves to the point that it can no longer stop up the hole, in this case replace it.
DRAIN SOLENOID
Another common problem on some dishwashers that will cause it not to drain properly is the drain solenoid. To check this, first disconnect power from dishwasher then remove the bottom panel of dishwasher. Once off, you should see the drain solenoid attached to the main pump then reach under the dishwasher and push down on the solenoid. If it will not move down it is bad and needs replacing. If it will push, down most of the time it is good but not always so follow these steps as well. Reconnect power to dishwasher, now start the dishwasher in to a cycle. If you have a mechanical timer turn it slowly until the solenoid energizes. If you turn the timer all the way around and the solenoid never energizes replace the solenoid. If you have an electronic control, start the dishwasher and wait a few minutes then push start/reset then the drain solenoid should energizes, if not replace the solenoid. At times the timer will cause this part to go bad especially if its melted or frozen down. So you may have to replace the timer as well.
CHECK VALVE
If your dishwasher is not draining properly, the check valve may be your problem. The check valve will be on some dishwashers with both a separate drain pump or drain valve (note if you do not have both you will not have a check valve). The check valve will be located where the black hose connects to the drain pump. To access the check valve, you must first remove the water from the dishwasher. A Wet-Vac works well. After the water is out, disconnect power to dishwasher. Now remove the dishwasher from under the cabinet. Now remove the black hose (even though you removed the water you will still have water in the pump so be ready).Once off you should see the check valve. It's the little red rubber flap. If it is torn off, the flap may have gone down the drain but you still should see the red ring left behind, in this case replace the valve. Sometimes the check valve will swell up and hang in the pump, if so replace it.
DRAIN PUMP
If your dishwasher is not draining properly, the drain pump may be your problem. As stated before, not all dishwashers will have a drain pump. To check this, First check to see if it is getting power. You should have 120 volts when the dishwasher is put into a drain cycle. If you have power and the pump does not run remove the pump and check for obstructions if none found replace the pump.
DRAIN HOSE
If your dishwasher is not draining properly, the drain hose may be stopped up. To check, remove all the water from tub. A Wet-Vac works well for this. After the water is gone remove the drain hose (even though you removed the water you will still have water in the pump so be ready) from the house plumbing and the dishwasher. Check for obstructions and remove. If you just installed a new garbage disposal check that the metal knockout was removed. Check the air gap if this is not right your dishwasher will siphon water back into it.
Use the VOM. God bless you305bcbf7-1f41-45db-8ea3-1549c1868ff4.jpg1accc4d2-1db1-4b03-b8f0-740c344ec33a.gif
Apr 04, 2013 | Dishwashers
Aeg favorit 35085 not draining
PISTON VALVE
DRAIN SOLENOID
Another common problem on some dishwashers that will cause it not to drain properly is the drain solenoid. To check this, first disconnect power from dishwasher then remove the bottom panel of dishwasher. Once off, you should see the drain solenoid attached to the main pump then reach under the dishwasher and push down on the solenoid. If it will not move down it is bad and needs replacing. If it will push, down most of the time it is good but not always so follow these steps as well. Reconnect power to dishwasher, now start the dishwasher in to a cycle. If you have a mechanical timer turn it slowly until the solenoid energizes. If you turn the timer all the way around and the solenoid never energizes replace the solenoid. If you have an electronic control, start the dishwasher and wait a few minutes then push start/reset then the drain solenoid should energizes, if not replace the solenoid. At times the timer will cause this part to go bad especially if its melted or frozen down. So you may have to replace timer as well.
CHECK VALVE
If your dishwasher is not draining properly, the check valve may be your problem. The check valve will be on some dishwashers with both a separate drain pump or drain valve(note if you do not have both you will not have a check valve). The check valve will be located where the black hose connects to the drain pump. To access the check valve, you must first remove the water from the dishwasher. A Wet-Vac works well. After the water is out, disconnect power to dishwasher. Now remove the dishwasher from under the cabinet. Now remove the black hose (even though you removed the water you will still have water in the pump so be ready).Once off you should see the check valve. It's the little red rubber flap. If it is torn off, the flap may have gone down the drain but you still should see the red ring left behind, in this case replace the valve. Sometimes the check valve will swell up and hang in the pump, if so replace it.
DRAIN PUMP
DRAIN HOSE
If your dishwasher is not draining properly, the drain hose may be stopped up. To check, remove all the water from tub. A Wet-Vac works well for this. After the water is gone remove the drain hose (even though you removed the water you will still have water in the pump so be ready) from the house plumbing and the dishwasher. Check for obstructions and remove. If you just installed a new garbage disposal check that the metal knockout was removed.. Check the air gap if this is not right your dishwasher will siphon water back into it.
Use THE VOM.God bless you12567004-0afb-4605-8b5d-f8507096ff31.jpg9456b97a-bc1b-4d19-bb59-a6584bc4f997.gif
Frigidaire front opening washing machine fills with water
Hi, if it fills slowly overnight with clean water you may have to repalce the solenoid valve as it may be seeping water through, If however it fills with dirty water you may have water returning from the sink, if this is the case raise the level of the grey outlet pipe
Mar 10, 2013 | Washing Machines
Turn on dishwasher hear noise solenoid clicks water valve works but no force of water to turn tines and no clean.
Sounds like you may have a bad solenoid valve. you can check this by opening line that feeds the valve to see if you have sufficient water flow. GET SOME TOWELS READY THIS MAY GET A LITTLE MESSY!
  1. turn off the water valve that feeds the dishwasher.
  2. remove the line to the dishwasher solenoid valve.
  3. slowly turn water back on that feeds the dishwasher.
  4. verify sufficient water pressure flows onto the towels.
Dec 30, 2010 | KitchenAid 24 in. KUDP02SR Built-in...
Dishwasher not starting when door closes
What your saying is suggesting a water supply issue. The Model number you've given can not be found on the Neff website.
You will need to disconnect power, turn the water supply off (under sink or behind dishwasher), disconnect the water line, put the end of the hose in a bucket or cup, turn water back on slowly and make sure water flows. Turn back off. If water flows -
Then check that there is not a restriction in the water solenoid valve. If you know how to use a multimeter, check the water valve solenoid for continuity.
Plug the unit back in, and initiate a wash cycle, and watch for voltage applied to the water solenoid valve. If you get voltage, you should hear the valve open.
Power the unit off, connect the water line, and repower the unit. Check again if water does or doesnt flow.
Let me know what you find.
Jan 25, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
508 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
