Question about Canon L220 Plain Paper Laser Fax
How do i change the fuser unit on my canon l295 fax/printer
  • 1,219 Answers
Remove upper cover(4screw), than remove axis with few small rollers, than remove from right side toner crg holder ( black plastic peace on right machine metal side ), unscrew 2 screw on black cover, remove it, unscrew two screws on metal cover ( beneath black plastic cover that you removed )
Posted on Jun 25, 2010
If problem persist contact dealer or service rep turn the main power on e301-0001
This is a fuser error, the fuser replacement for this machine is best done by a technician as there is moderate disassembly involved..
Your local canon warranty agent will be a good place to start.
This same printer engine is used in a few HP printers and multifunctions and the fuser is available from HP as well. Though HP are usually slightly dearer.
If you want to have a go yourself the part number is one of the following, depending on your electrical grid voltage un your part of the world
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 120 Volt
RM1-7576-000
or
Canon imageCLASS MF4450 Fuser (Fixing) Unit - 230 Volt
RM1-7577-000
Oct 26, 2013 | Canon ImageCLASS MF4450
My L295 fax machine does not recieve and print
The Fixing unit of the fax is blown.Replace the fixing unit.
Aug 12, 2009 | Canon Office Equipment & Supplies
Sir, can anyone help me with my fax (canon fax l295)for a problem, it was always indicating that "load paper" even though i put paper on the tray once it was start feeding it makes an paper jam error and...
You either have a paper path blockage or your feed rollers are worn. You'll need to take it apart to check though. Try removing paper, turning machine off and on and re-inserting paper. Remember to fan (separate) paper before loading, it could be static causing the sheets to stick together and jam in the machine.
Jun 11, 2009 | Canon L295 Plain Paper Laser Fax
How do I tune my fax machine so that each time I send a fax I get an individual delivery report?
Press funcktion ,dataregistration,scroll down until you get report settings,press ok and scroll down to tx report,press ok and change to output yes.
Then you will receive a report for every fax you send.
Mar 20, 2009 | Canon L295 Plain Paper Laser Fax
Line In Use Messege
Plug a regular phone into the wall jack. Verify that you have a dial-tone.
Sep 10, 2008 | Canon L295 Plain Paper Laser Fax
How to connect canon L295
Hi THe main difference in the phone fax line is that if you are only using as a fax plug the cable from phone socket into the line socket sometimes this may be marked line/tel then the hand held phone goes into the tel socket.this should make it a little clearer..line to wall socket ....and tel to hand telephone
May 02, 2008 | Canon L295 Plain Paper Laser Fax
CANON FAX L-295
Dear TAMBUNAN
Please go to CANON's site below,
http://software.canon-europe.com/products/0010059.asp
From the menu select ,
OPERATING SYSTEM: Windows98
LANGUAGE: Engish (Or your language if available)
The driver in English IS available.
Regards,
EngineerGR
Please Rate this solution if you found it useful!!
Apr 08, 2008 | Canon L295 Plain Paper Laser Fax
Canon L220 Plain Paper Laser Fax Logo
222 people viewed this question
old marine
old marine
