Question about Philips 42PF9630A 42 in. Plasma Television
I can't watch TV....! help....
I have a Phillips plasma 42PF9945/69 that we tried to turn on but all that happens is the standby light turns on and off and a relay inside clicks in and ouy. it's acting like your turning on the tele and turning it of straight away. can anyone give me an idea of what is wrong and can it be fixed for less than a new one.
cheers
    Scholar:
  • 100 Answers
Hello, I came across several times in this type of malfunction, stems from primary circuit of the power supply unit. I solved it by replacing the 5W ceramic resistor. In another case I came across electrolytic capacitors that i had to replace in the same circle. I hope it was helpful!
Posted on Feb 21, 2011
Standby light changes from red to green
hi this fault could be down to capacitor in the power supply, they bulge or go leaky, you need to take the back off the tv, to have a look. try and find a tv tech in your area hope it helps
regards
shaun
Jan 05, 2014 | LG 42PX5D 42 in. Plasma HDTV
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
50" phillips plasma wont turn on
I'm having the same problem and am about to try this solution. I truly believe this is going to work. I hope this helps!
http://www.youtube.com/watch?v=OsJSzYVUWVA&feature=related
Dec 28, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Plasma problems
It's in standby mode.
Let's do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
Let me know how this works
Jan 30, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Plasma TV.
I have the same problem. since I have 3 of these TV's, I switched boards around, and I came to the conclution that is the power board. I will try to repair it, and I'll let you know the component that is bad. Gaston
Dec 28, 2008 | Sony FWD-50PX2 50 in. Plasma Television
Phillips 37FD9944/01S Plasma TV - Power Supply
dont waiste your money problem main or logic board or if shure power supply go radio shack and get one with specifications match voltage,ampers,and polarity
Mar 30, 2008 | Philips 60PP9352 60" Rear Projection...
2 year old Phillips 42" Plasma TV won't turn on
Hi I had exactly the same problem, bought the above parts off ebay. The above solution worked and tv back to normal. the soldering is a bit tricky and there is a lot of screws holding the back on!
Sep 13, 2007 | Televison & Video
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF9630A 42 in. Plasma Television Logo
184 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
