Question about Sony Ericsson K810i Blue Smartphone
I startup the phone,it cannot go to main menu...i
I start up the phone,it cannot go to main menu...i need toremove the batteryin order to turn off... any expert know what happen???
Internet barely works
Step 1:
Most of the programs running in the background of your computer start automatically during PC reboot. These applications were added to the Windows startup menu during default installation. However, you probably do not need all of the programs that are currently running on your computer all the time. This only slows down your PC and the reboot time. Fortunately, you can access the Windows startup menu and remove the programs you do not need to have running automatically. Turning off the programs shuts them down until you enable them again through the "Start" menu.
Go to the "Start" menu, type "msconfig" in the "Start Search" box and press "Enter" to start the System Configuration utility. Click the "Startup" tab in the System Configuration window. Uncheck the programs that you want to turn off and stop from running in the background. Click "Apply" and "OK" to save the new settings. Restart your computer.
Feb 24, 2013 | Dell Studio Computers & Internet
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Tip
How to make computer to fast or fast boot ?
Do the following to make your PC Fast
Do 1
1. Turn on your computer, and hold down delete.
2. In the BIOS window, look for the Boot Menu option.
3. Choose the QUICK BOOT to turn off memory test
.4. Make sure the hard drive comes first in the BOOT ORDER.
5. Turn off any logo displays.
6. Restart
Do 2
1. Open your Start menu.
2. Click Run
3. In the command screen type msconfig
4. In the system configuration utility,click either BOOT tab.
5.In the boot menu, change the default setting for Time Out from 30 to 5 seconds.
Do 3
1. Click the Start button.
2. In the Start Search bar, type control userpasswords2
3. Load the User Accounts window
4. Uncheck User must enter user name passwords...
5. Click Apply
Do 4
1.Click Start button and load the Control Panel
2. Under the Control Panel menu, click Programs.
3. Under the Windows Defender heading choose View currently running programs
4. Choose Startup Programs from the Category option
5. Remove Programs that you feel unnecessary for startup
Do 5
How to disable this indexing service
1. Click on Start
2. Click Run
3. Type services.msc
4. Select Indexing Service and Double click on it.
Select Manual under Startup Type.
5. Click Stop
6. Click OK
on Jan 03, 2010 | Computers & Internet
I cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
Which button is the menu button on the panasonic kx-tg6524? None of the buttons on the answering machine or phone say "menu" and all the settings require you to hit menu first. Thans
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones
Jan 25, 2011 | Panasonic KX-TG6524 Cordless Phone
How to see start con Avaia 4610?
Press the options button (the one with the checkmark)
This phone will not display a startup screen. It displays the binary files that it is using to boot the phone.
May 31, 2010 | Avaya 4610
Computer boot screen slow?
Do 1
6. Restart
Do 2
2. Click Run
Do 3
5. Click Apply
Do 4
Do 5
1. Click on Start
2. Click Run
5. Click Stop
6. Click OK
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
I cant install a new operating system into my HDD. My setup does not suportt boot from CD.
The Bios Settings need to be changed to boot from The ATAPI drive. When you turn on computer press the F2 or F1 or Delete button, sometimes its F10. Once you are in the bios setting look for boot devices. Follow the on screen instructions to change the boot order. I hope this helps.
Mar 30, 2009 | IBM NetVista PC Desktop
Setting boot sequence
press Del or F2 or Esc while booting ..
Feb 17, 2009 | Systemax ™ Mission Xeon™...
Start up menu
Click on the start button at the botton left of the screen, open the all programs, with your programs you will see a section that reads startup. Right click on anything in the startup and click delete. You will have to do them one at a time untill it reads empty. Don't worry about deleting the items in the startup section. It doesn't delete or effect the program at all. The only thing it does it keep that program from automatically starting when you turn on the machine. If you need any further assistance fell free to ask.
Jun 19, 2008 | Dell Inspiron B130 Notebook
Sony Ericsson K810i Blue Smartphone Logo
163 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
