Question about Belkin (F5D7633UK4A) Wireless Router
I can't access secure sites like betfred.com my isp says it could be my mtu settings with belkin router please help
  • 64 Answers
SOURCE: Belkin setup problem
Hi Anya,
First of all, as far as your ISP is concerned, are you using an always-on connection that doesn't require a username/password (such as basic digital cable) or are you using a PPPoE connection that does require authentication (such as DSL)?
If you're using basic cable, you should be able to bypass the setup and configure it manually if nothing else. Let me know.
Ben
Posted on Mar 04, 2008
  • 104 Answers
SOURCE: im trying to set security on belkin n router
Hi...if your router has WPS capability, such as a special button to set up wireless security, then to use it your client computer/device must also be WPS enabled.
If it is, there are usually two options to configure WPS security: the push button method, or the PIN number. The push button method usually requires that you press the WPS button on the router, then within a set time, press the equivalent button on the computer (eg laptop, or whatever device it is). The PIN number method requires a PIN to be entered into the client computer. The PIN can sometimes be found on a sticker on the router.
Your manual should help with the details, but see this page for some more info.
http://kbserver.netgear.com/kb_web_files/n101691.asp
If you don't have a WPS enabled computer or don't want to use it, you can set up security manually. Please come back to Fixya if you'd like help with this.
Posted on Dec 30, 2008
rahul26485
  • 611 Answers
SOURCE: cannot access Belkin security settings
avast virus disable it then try it you get the other wise reset the router and re-configure it after reset you get the all configuration in default setting then you easly get it but anti virus disable then work after then you can enable
Posted on Mar 04, 2009
teksquisite
  • 18 Answers
SOURCE: how do i change the mtu setting on my belkin n
You can adjust MTU from within the Belkin Router administrative console. You really should not be changing it unless your current ISP gives you a specific MTU setting, otherwise you could disrupt internet connectivity.
Default IP address: http://192.168.2.1
Default admin username: Administrator
Default admin password: <blank>
Be sure to set a password for your router!
This is the address where you change MTU
192.168.2.1/wan_pppoe.html
Belkin Wireless G User Manual:
http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=5999&scid=221
Windows Tools to adjust MTU:
DrTCP tool:
http://www.dslreports.com/drtcp
TCP Optimizer
http://www.speedguide.net/downloads.php
Posted on Jun 12, 2009
dante777
  • 623 Answers
SOURCE: Attempted to set up wireless security - lost all wireless
Sure the reset button will fix this, because it will reset the router tofactory defaults and erase all personal settings.
The better and easier way is to connect one of your clients/computers to the router via an Ethernet cable, login to your router (The default is http://192.168.2.1), go back to your wireless settings and either write down the key or delete it.
Now connect from another computer and provide the network key when asked for it. Make sure that broadcasting the SSID is enabled in your router, so computers can "see" the network. (Look at page 47 of your manual for details.)
If you don't have a manual, you can download it here.
If you have any more questions or need assistance with any of these steps, just come back here and leave a comment - I'm happy to help.
Posted on Aug 17, 2009
My router keeps dropping the internet connection. The ISP checked and said it was "unstable". They sent me a test modem which I am using now and this solved the connection problem. They suggested...
The reset button resets the router to its factory default settings. It's really there for if you forget the password into the router you can reset it and set it up from scratch again. Beware of this button because you will have to set the router up again if you press it - including your broadband username and password which most people have long forgotten and lost the documentation for!
As to the connection being dropped, this reeks of MTU problems - ask your ISP for their reccomended MTU setting and then put that in the router, if thats already in then try both a lower number then a higher number and see what happens.
(MTU is Maximum Transmittable Unit - essentially how big the packets it can transmit back and forth - if the packets are bigger than the router will accept then they get dropped, and if they are smaller then you are losing speed) - dropped packets = dropped connection.
And finally, upgrading the router software. Go to Belkin site and find the firmware for your router model. follow the steps to install this on the router.
In fact I've just found it for you and linked it below, hope it helps
http://en-uk-support.belkin.com/app/product/detail/p/4784
Word of warning - follow the steps exactly when updating firmware - you can easily 'brick' your router if anything fails or you cancel halfway through.
Oct 29, 2010 | Belkin (F5D7633UK4A) Wireless Router
Why does my belkin g wireless modem router f5d7634 always disconnect every hour? i already turned the firewall off and yet it still disconnects from the internet. the globe led does not turn off but i...
You said that the Internet connection is dropping. It is a modem *** router.
If there is any MTU settings , then reduce the MTU.
For example If MTU is 1500 then reduce it to 1400.
Otherwise you will need to upgrade the Firmware of the router.
Click Here for more info about the networking
Oct 07, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin g wireless modem router f5d7634 always disconnect
try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
Oct 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Can't download files and upgrade using my wireless
If you connect the computer to the modem, you are able to download the files.
But if you connect it through the router, it is not working.
the problem is with the router. Cogeco is a cable ISP.
you can reduce the MTU settings on the router. If MTU on the router is 1500 then Make it 1300.
Under security settings, disable the firewall on the router and disable the Block internet request.
If it doesn't work then try to upgrade the Firmware of the router.
For more info about networking Click Here
Oct 06, 2009 | Belkin (F5D5231-4) Router
Mtu settings
Two things needs to be cleared:
1) Which connection did you talking about LAN/WAN?
2) Xbox live may not be up yet, can you verify it?
Most home gateway routers can only change WAM MTU for certain connection type (PPPOE), and cannot set MTU for LAN and other WAN connection.
To change MTU for PPPOE, going to WAN connection setting, and you will see the MTU options box. But do not change it unless your ISP told you to do so.
So make sure Xbox live is online -- I am no Xbox fun so I have no idea how it works, but just guess from your message.
Jun 19, 2009 | Belkin (F5D7633UK4A) Wireless Router
I have two questions 1. How do I secure my n1 Belkin router? 2. My new laptop (Lenovo Think Pad T500) seems to have "issues" with the router. Internet video feeds are choppy and stall. Access to email...
Here is a link on how to secure your router:
http://www.belkin.com/support/article/?lid=en&pid=F5D9230-4&aid=10177&scid=221
To correct the email and video issue, you may need to change the MTU settings:
Adjust your wireless router settings
  • Lower the MTU (Maximum Transmission Unit) from 1500 to 1492 or less (usually found on your router's main/ basic setup page)
  • Adjust the following advanced wireless settings:
    • Lower the beacon interval from 100 to 50
    • Lower the fragmentation threshold from 2346 to 2306
    • Lower the RTS threshold from 2347 to 2304
192.168.2.1/wan_pppoe.html.
You can download the user manual from the previous link.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 16, 2009 | Belkin (F5D9230-4) Wireless Router...
How do i change the mtu setting on my belkin n wireless router
DrTCP tool:
TCP Optimizer
Jun 09, 2009 | Belkin (F5D7633UK4A) Wireless Router
360 mtu test keeps failing
Access the routers setup page by typing 192.168.1.1 (ip address of the router) on the address bar on IE.
then on basic setup page at the bottom part of the page you will see MTU normally its on auto,
to change the value set it to manual. ask your isp what is their prefferred value for the mtu you can go as high as 1300 to 1500.
Sep 13, 2008 | Linksys Wireless-G WRT54G Router
ROUTER PROBS WITH MY BELKIN
Hi Thomas,
I have been having the same trouble, I think its to do with accessing secure sites, anyway there is a solution and it works,
download and run dr tcp ( http://www.dslreports.com/drtcp ) and set mtu ( adaptor settings) to 1400. I also changed my mtu to 1400 in the belkin connection set up page.
Hope this works for you.
Regards
Gary
Oct 27, 2007 | Belkin (F5D7633UK4A) Wireless Router
Belkin (F5D7633UK4A) Wireless Router Logo
124 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
