Question about HP PSC 1510 All-In-One InkJet Printer
My HP 3-in one printer is eating paper, what can I
My hp 3-in one printer is eating paper what can I do does it just need to be cleaned ?
  • 4,041 Answers
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on May 10, 2010
Paper jams
Go To Below official HP Printer Page For Your problem,http://h30434.www3.hp.com/t5/Other-Printing-Questions/Printer-Paper-Jam/td-p/126558
Still having Problem Then follow Us For HP Printer Support
Feb 24, 2014 | HP PSC 1510 All-In-One InkJet Printer
Tip
Paper Jam Error on HP Printer
Paper Jam is the most common issue in all the HP Printers ( Officjet, Photosmart, Deskjet Printers )
What Causes a Paper Jam ?
  • Paper thickness.
  • Room temperature OR due to Dust in atmosphere or the room.
  • Paper pulled out in a hurry and paper pieces stuck in Rollers or Carriage
  • Could be Hardware Failure
NEVER PULL THE PAPER STUCK IN THE PRINTER FROM FRONT SIDE OF THE PRINTER ( unless the paper is 3/4th visible in front view if you open the printer front panel door )
Follow the instructions below to resolve Paper Jam issue.
  1. Turn off the printer.
  2. Open the rear access door ( or duplexer )
  3. Check for any bits of paper stuck, if so, remove them.
  4. Open the front access door where you see the cartridges.
  5. Check for any paper pieces, if so, remove them.
  6. Take a lint free cloth. Little bit Damp ( use water )
  7. Clean the Rear rollers pushing it upwards and close the door.
  8. Close the front access door.
  9. Connect the power cord and power on the printer.
  10. It should be ready to print/copy/scan/fax.
To clean the duplexer ( 2 - sided printing device ) remove the duplexer and clean the rollers you find inside.
If the above steps do not solve your problem, you printer needs repair. Contact HP. ( 1-800-474-6836 )
If the printer is In-Warranty please contact HP for replacement. HP may charge for repair for Out of Warranty printer.
Find the Video below for paper jam cleaning
Regards,
Ron
Your rating will help us improve the service we provide
on May 20, 2011 | Office Equipment & Supplies
My HP 3-in one printer is eating paper, what can I do, does it just need to be cleaned ?
Hello there
Mar 16, 2010 | HP PSC 1510 All-In-One InkJet Printer
Hp 3600n prints 3 faint lines on letter head only and not on other paper. What is causing this?
It could be a couple of problems:
1. Your toner needs to be changed
2. You need to clean your printer
3. You paper weight is too thick and the toner is reacting to it by leaving streaks on your paper.
See if those help
Jan 14, 2010 | HP LaserJet 3600n Printer
Unexpected Paper Size error while printing a3 size paper on HP 9300 deskjet printer
Although you have selected the paper size A3 your printer HP Deskjet show unexpected paper size.....
1. clean the carriage area ...........
2. change the carriage sensor....... If not solved
3. you need to replace carriage unit.
Thanks
Oct 26, 2009 | HP Deskjet 9300 C8136A Printer
Hp color laserjet 1600
Sounds like a bad TRANSFER Belt
Dec 29, 2008 | HP Color LaserJet 2600n Printer
I have a HP OFficjet 7210 All-in-one that keeps jamming.
Clean the pickup rollers and ensure that there isn't a small peice of paper lodged between them. I use a product called "rubber renew", it removes the dust, dirt, etc. and eats away someof the rubber to make it rough again.
Nov 18, 2008 | HP Officejet 7210 All-In-One InkJet...
Printer scanner laser jet hp 3030
open the printer and take out all the attachment, paper tray, ink cartridges. check for any of the paper path. make sure there is no paper stucked in the path. chance are there is a small peice of paper stucked in the path.
Sep 14, 2008 | HP OfficeJet 6110 All-In-One InkJet...
My printer is eating my paper
Hi
I had exactly the same problem and had to stop my flatmate trashing the thing! Try buying the cheapest, nastiest supermarket printer paper you can find! Works great in mine...
cas
Jan 07, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
166 people viewed this question
Seeker5211
Seeker5211
