Question about Toshiba TEC B-SX4 Thermal Label Printer
System error showing on my toshiba tech sx4
Have a system error showing on my toshiba tech sx4 how do i fix this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 240 Answers
Hi Thanks for your question.
First thing you should try is unplugging your printer from mains and plugging back again after 30 sec or so. Good Luck
Posted on May 10, 2010
How to toshiba sx4 reset factory
I found an article with steps you can take to factory reset a Toshiba SX4
ttp://www.progressive-id.co.uk/_img/pics/Toshiba_B-SX4-B-SX5_How_to_perform_a_RAM_clear.pdf
For more help, give me a phone call at 1800-204-4427
Sep 14, 2017 | Toshiba Office Equipment & Supplies
TEC B-SX4 head temperature error
Please give me more feedback, can't help you with that.
Oct 23, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Ribbon error problem for Toshiba TEC B-SX4 Thermal Label Printer
Calibate the detection value and check the rbbon motors values
a sammler ribbon could need some adjustments
Mar 27, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
syntax error
communication problem or cable not well fixed or bug in your software
Jun 10, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
I have a toshiba tecra m5 and is showing a message PCI Express error
Welcome to Fixya.
The error that you are getting pertains to a system board-related hardware issue. Please understand that there are no DIY instructions to get this problem fixed as motherboard replacement is the only solution.
I strongly suggest for you to contact Toshiba's support (follow link below) for repair options :
Toshiba Support Website
Tech Support Toll Free number : 1800 457 7777
Thanks for using Fixya.
May 25, 2011 | Toshiba Computers & Internet
Barcode printer type: TOSHIBA SX4 sensor setting for thermal transfer / transmissive error msg paper jam. how to see the sensor?
Diagnostic boot
Feed PAuse button pressed and switch on Keep button prressed until message (1)Diag ...
with feed goto 5 sensor adjustements.
Pause to enter the menu
select the sensor you want to calibrate!.
Feed or restart button for 5 seconds until a star appears.
Switch off and on the calibration is stored in Eprom
Feb 10, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Hello, we are living problem with our printer B-SX4 with error code SG-1511-15 what is your comment about our problem ? Thanks alot for your kind attention.
Either you driver is not correctly interpreting the image data or you have a problem with you connections. This is syntax error detected due to missing or unorrect datas.
Aug 03, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Can any one tell me where to find error codes for my SX4 2008 crossover, the code was B1504 and the tech told me they not allowed to give me any info on codes, they can only clear the codes and if there is...
This should be under waranty and you should get something in writing just incase problem comes back after waranty expires,this code is for the sunload sensor, this is for the a/c system and detects sun heat amounts to make ac colder when needed, this code can be caused by a defective sensor or a bad connection or dealer needed to reprogram it.
Jul 15, 2010 | 2008 Suzuki SX4
Download a new firmware.
- check that the antiparasite cores are mounted on the ribbon motor cables
Mar 16, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Paper jam error message
This problem is a detection problem, due to a bad sensor selection or incorrect label size.
If the labels are white labels with a separation between each, select TRANSMISSIVE. If the labels are preprinted, select the TRANSMISSIVE PREPRINTED LABELS and set the threshold doing this.
With the printer in ONLINE, press PAUSE once, the message PAUSE appears in the display, press and hold on the PAUSE key, TRANSMISSIVE is displayed, release the key and press PAUSE until labels starts to feed, let feed some labels (5 or 6) and release the key. Press Restart and start to print.
Dec 08, 2009 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba TEC B-SX4 Thermal Label Printer Logo
397 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
matt
matt
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
