Tv through dvd/video combo shows only black & white picture???
I think it is connected right - have tried many options, bought 2nd hand, no manual, desperate for some assistance - is it a cabling issue? We have foxtel digital plugged in and video in through foxtel - tv sees it but can't get a colour picture??  HELP!!  It is an older TV Model CT-M6828S and I know I am probably pushing my luck - but it can't hurt to ask can it?  Thanking you in anticipation if you can help. Cheers, Kathy
  • 74 Answers
Could either be one of your connecting cables (the first thing I would check) or the TV itself. Check you have not mixed up the input and output plugs on the VCR as well :-)
Posted on Mar 28, 2008
I am trying to connect a sony dvd player by rca cables to my tv and it only plays in black and white.do I need specific cables
Wallie, If possible save your self some aggravation and get a HDMI cable, if you have that option..
press the helpful button and follow me on fixya for more tips and info.
Feb 10, 2016 | Sony Televison & Video
I just bought a Westinghouse LED TV. When I hooked up my dual DVD/Video combo the picture is black and white. What did I hook up wrong??
It sounds like you may have connected the dvd/video combo to the wrong spot on the television. The yellow wire cannot be placed into the green hole. You'll get a picture but it will be in black and white. You can only connect these yellow, red, and white composite wires to a component input spot on this television in order to get a color picture.
Aug 21, 2011 | Televison & Video
I am trying to get my combo player hooked up to my tv. I don't have the manual. I just want to be able to watch DVD's and VHS tapes.
Check the type of connections on your combo player and TV, there are likely two options for connection:
1st option = AV: 3 RCA connections (yellow, red, white)
2nd option = COMPONENT: 5 RCA connections (red, green, blue, red, white)
Get the appropriate cable and connect it to the available input on your TV. Unless you have an ancient TV from a few decades ago, it should at least have AV connection.
Jul 15, 2011 | Televison & Video
For some reason, my DVD player just started showing up in black and white. Also, when I select the "source" on my TV remote, instead of showing the option "AV" for the DVD player, it...
Select AV as your source and that should cure the problem as long as you have the video and audio cables connected to the right inputs. You could also use an S-Video cable instead of the video cable for better picture quality depending on your TV model (assuming it has a S-video input). Your owners manual(s) will probably have diagrams for you to follow.
Jan 30, 2011 | Panasonic DMR-ES40
g
OK,you need 3 leads,(A/V leads),normally red white and yellow.
So yellow is for Picture (video).go from video OUT (combo) to TV video IN.
Then red and white .... Audio OUT of combo into Audio IN on TV
TV must then be set to AV1 or AV2 depending on which AV inputs you used..
Rod
May 04, 2009 | Televison & Video
No picture when connecting CRT TV to Panasonic DVD/VHS Combo
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
Feb 14, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Install s-video cable now dvd is black & white
you might have a bad cable just because you get a great picture but no color.i would exchange the cable where you bought it and try another one.
Dec 06, 2008 | Toshiba Cinevision DVR2000
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
DVD output is Black & White
What type of machine is doing the copying?
Feb 27, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Picture only shows in black & white when playing DVD
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Dec 21, 2007 | Televison & Video
Televison & Video Logo
195 people viewed this question
Top Televison & Video Experts
Electro Med Services...
