Question about Microwave Ovens
Burnt french fries in microwave panasonic model nn-s615wf is there anything i can do to remove the smell
    President:
  • 949 Answers
Here is a link to a website that has a lot of good tips on cleaning and getting rid of odors in a microwave.
http://www.howtocleanthings.com/how-to-clean-microwave.htm
Posted on May 11, 2010
What do i do about the tirntable not turning
first open door an take a good sniff see if you smell any burnt smell it could be a burnt out drive motor or a broken wire there are repair shops that do that DO NOT TRY AND FIX YOUR SELF read the warning panel
Jul 11, 2014 | Panasonic NN-H965 Microwave Oven
I have panasonic nn-sd688s its fuse burnt out i need a new fuse where i can buy new one if u let me know. thanx
Easiest is probably Radio Shack, followed by any electronics supply store.
Best regards, --W/D--
Jan 25, 2011 | Panasonic NNSD688S Stainless Steel 1300...
I have a panasonic inverter microwave model 1250w and does not heat up, everything else works fine
its likley to be the magntron burnt out,,(thats the bit that heats the food up) its a pricy part to buy and have fitted,,it may be a lot cheeper to buy a new unit
Jun 20, 2010 | Panasonic NN-S254WF Microwave Oven
We cooked popcorn a little too long. How do I get rid of the burnt oder.
If you put 1 cup of vinegar and cook it for approx 2 minutes. This will stink for a bit, however, it will neutralize the burnt smell.
Feb 18, 2010 | Panasonic NN-SN657SMicrowave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Bulb Replacement in Microwave
You have to take off the case. Need a T20 Tamper Torx bit and a Phillips #2 Bit. There are 2 tamper-torx screws on the case to discourage inquisitive types / prevent untrained hands from entering. Once the screws are out (5 in total), slide the cover off the back. On the right-hand side, you will see the electrics. The bulb is behind the black oval shaped fitting that lies just behind the 2 big red wires that carry the high voltage to the microwave tube. Just pry over the bend-down metal tab, and lift off the black oval, bulb is attached to it. Replace, re-install, and test with case off and door open to ensure your replacement works. Re-install the slip-off case and screws. You're done.
Kermit
Jun 06, 2009 | Panasonic NN-T990SA Microwave Oven
Cook top light will not turn off on Panasonic Microwave nns255
Check your manual and see if you purchased the correct type of replacement bulb (wattage).
Apr 25, 2009 | Panasonic NN-P295SF Microwave Oven
Bulb replacement
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Jan 18, 2009 | Panasonic NN-T990SA Microwave Oven
Burnt Rubber Smell then Off
That would most likely be a problem with the inverter or magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | Panasonic NN-H664 Microwave Oven
Microwave Ovens Logo
113 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
