Question about Boating
I have 10+ volts to the foot petal but no power to the head of the trolling motor . If I hit the switch on the foot petal I loose all voltage
  • 2,926 Answers
Take the foot pedal apert and inspect for a bad or broken connection on the positive lead.
Posted on May 11, 2010
The trolling motor will rotate directions but stopping motion. the blade will not turn with the foot petal
time to replace it then not many shops want to even try repairing them
Feb 23, 2017 | Boating
Have a brother sawing machine it just humms when i press ladel
would be something wrong with the foot petal or the motor, make sure the foot petal is snuggly connected into the plug of the machine, and if it is, then the machine needs to be checked
Mar 20, 2014 | Singer Sewing Machines
Foot petal is not working and it is plugged in.
Is there power, does the sewing bed light come on? If so there is probably a fault with the pedal. If you are practical you can open the pedal and fit a volt meter across the terminals to see if the voltage increase when the pedal is pressed.
Feb 11, 2014 | Singer 7422
How to fix foot control
have someone with a multi-meter open the foot pedal and test with the meter. It probably needs replaced.
Sep 17, 2012 | Riccar Sewing Machines
Peg pergo gaucho jeep won't go when push petal, bought new battery but not battery
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in, then check for power at the foot pedal, then at the shifter, then at the motors
Oct 07, 2011 | Peg Perego Gaucho Rock'in
My brake light won't turn off even if my foot
Your brake switch is just hung up. it is located directly above the brake petal and is attached to the petal bracket-use a flashlight and get down low enough to see up under the dash where your brake petal is, it will be hooked onto the petal bracket-just move it, it is probably just mis-aligned.
Jul 20, 2011 | 1990 Toyota Tercel
Trolling motor doesnt work?
Most trolling motors have in-line breakers, I would start there & see if one went bad, then check the wiring under the foot pedal for broken or corroded contacts, then you will have to trace wires & make sure everything is in order starting at the trolling motor plug.
May 24, 2009 | Boating
Minn kota problem
Same deal with mine, was using it with no problems until I turned up the trust alittle and it just quit, never turned back on nor did the circuit breaker pop. Talked to Minn Kota thy said the board might be fried as well. So took it to a authorized dealer. I had 2 issues (only minor with the motor) Easy fix for mine was under the button on the foot pedal is a small round magnet about half the size of a pencil in diameter or so. The tech said it got recessed down to far and if it should happen again just pull it up again. So took it back home re-installed and no luck, just heard a tiny ticking noise from the foot pedal, no prop movement. SO I checked the batteeries, all good. Even though the connectons had very minor corrosion I decided to disconnect all and clean them. Re-connected them and now I am back in business. Dont understand it, but hey it works until I actually test it out on the lake. Hope it helped
Sep 29, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
