Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Makita 18volt 6347 cordless drill
Drill "ratchets" prematurely even on highest torque speed and on light work.I've pulled it apart but can't find any one thing that needs replacing for eg a bearing . all the bits inside seem to be sealed units and i don't know which unit needs replacing
    Champion:
  • 313 Answers
Then you need transmision assy. item 14 in breakdown
see toolpartsdirect.com for further info on your drill
Posted on May 29, 2008
SOURCE:
I have a Makita #6347d, when I have been using the drill I had some smoke from the battery connection to the drill and the housing of the drill had some smell of smoke. Whats up? Thanks, Bill
Check what gear you in, the Makita will smoke if you exert to much torque, consider buying a decent impact driver? If its not under much pressure then it may be a fault with the drill. I have owned one and it was reliable but sometimes under-powered for an 18volt compared with others on the market.
Hope this helps
Jon
Oct 23, 2010 | Makita 6347DWDE 18 - Volt Cordless Driver...
When i drill with my 18volt cordless, and the bit catches it makes an awful grinding noise inside the drill, its not the adjustable clutch set low. its set on drill?
Your speed switch is between gears, pull the trigger lightly and slide the speed switch back and fourth until it is fully engaged. Also turn the clutch setting all the way down then all the way back to lock it is not uncommon for them to get dodgy.
Cheers,
Kevin
Mar 23, 2010 | Dewalt DC6PAKRA Heavy Duty Xrp 18volt...
How do you remove the chuck on a 18volt makita drill driver
there is a flat head screw in the center of the keyless drill chuck counter clocwise to remove.
Nov 28, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
I have just bought a 12v panisonic drill, is the
The racheting sound is the result of the torque setting indicated on the dial before the chuck. Set the dial to the drill bit icon, or all the way past the highest number, and that locks out the torque control, and it will not ratchet
Sep 03, 2009 | Panasonic EY6409GQKW 12 - Volt, 1/2"...
Makita 14.4V Cordless Impact Driver only works at high speed
Most cordless drill / drivers like this have electronic switchs which unfortunately would have to be fixed by a repair agent. Depending on it's age - make sure that you tell the agent that it never really worked properly, warrentys only cover parts that were faulty from manufacture and not wear and tear, so it may get fixed for free depending on the repair centre
May 18, 2009 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
Need to know how the gears fit in the gear box
Click this link and download pdf file that will show gear assembly and a lot more. After you download the file, scroll down toward bottom of page for illustrations.
http://www.toolpartsdirect.com/manuals/pdf/repair/makita/6347d.pdf
Good Luck.
Apr 25, 2009 | Drills
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
232 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
