Question about Panasonic PT-47WXC43 47" Rear Projection Television
Panasonic pt-53wv53g power light flashes 3 times tv wont turn on
    President:
  • 788 Answers
If you are getting the three red LED lights flashing then your symptom sounds like a damaged convergence IC.
If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
How do I tell if the IC’s are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC’s. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
With the low price of LED and Plasma TV's it is hard to repair sets today.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on May 13, 2010
My name is Callie and my panasonic PT-60LCX64 projector tv wont turn on. I can hear it running and hear the fan, and read about a switch that needs to be pressed in but i cant find the switch.
PT-60LCX64 - Panasonic
shop.panasonic.com > Get Support
Panasonic60" Diagonal LCD Projection HDTV. ... Details http://shop.panasonic.com/support-only/PT-60LCX64.html ... Will the Touch Pen (TY-TP10U) work with my TV?
Panasonic TV Not Turning On? (PT-60LCX64)? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 13, 2010 - When I power the TV on, the green light flashes for about a minute, and ... Source(s): panasonic tv turning pt 60lcx64: https://tr.im/EBjDN ... I have apanasonic tv PT-56lCX66 and it wont turn on? Why won't my Panasonic PT-52lcx16TV turn on? Panasonic lcd rear projection 60 inch tv..model #PT-60LCX64.
Panasonic PT60LCX64 Lamp with Housing TY-LA1000
www.amazon.com > ... > Projector Accessories > Lamps
Amazon.com, Inc.
Rating: 3.8 - ‎30 reviews
PANASONIC PT-60LCX64 TV Replacement Lamp with Housing ... Howere, EVER TIME we turn the TV On a Pop Up Message comes up to Set a Lamp Timer!
Panasonic LCD Projection 1 Orange Amber Blink PT 43 50 ...
? 5:48
https://www.youtube.com/watch?v=Z9tLqxpD1qU
Apr 18, 2013 - Uploaded by norcal715
Dec 26, 2015 | Panasonic Televison & Video
Red light flashing, tv wont turn on
need the model number of the panasonic and also how many times it is blinking. The blinking is an error code.
Aug 03, 2012 | Panasonic Televison & Video
My panasonic pt53wx53g tv wont turn on. the power light blinks 3
thats the error for the convergence failure. You can get the repair kit for your model at www.tvrepairworld.com the kit contains the parts and the CD with detailed instructions
Sep 08, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-56WX33/red light blinks 3 times ovr-n-ovr
It's one of two things, a bad chipset, or bad lamp. 200-250 repair. Hope this helps
Jul 07, 2009 | Panasonic PT-56WX53 53" Rear Projection...
Panasonic PT-47WX42F does not come on light flashes 3 times HELP!
There is a service manual which should cover this model/chassis series:
Elektrotanya for electronics experts
(PDF format - free - no sign-up needed - 100% clean)
Page 11 ('auto diagnosis feature') shows a table of LED flashes and what each one means. I'd start by checking D-board (since that is power and deflection) and going from there.
Dec 21, 2017 | Televison & Video
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-53TW53G
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Aug 17, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Panasonic PT-47WXC43 47" Rear Projection Television Logo
146 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
