Question about Whirlpool RBS245PDS Electric Single Oven
Whirpool GBD307 - Display not working
Hello. I have a Whirlpool built in electric convection oven model GBD307. The display is does not display any value but the light key turns on/off the light inside the oven. Intermittently, the display shows a F2 fault code and a E6 error code. According to the code explanation it's "CANCEL key drive line open. recommended repair are:
1. Check keypad connector for firm connection. (tried this still problem)
2. Press CANCEL. If error code returns after 60 sec, replace keypad. (Where is the CANCEL key?
3. Replace control. (If this is required where is the best place to order?)
Thanks / appreciate you assistance.
jr
  • Caterina82 Nov 22, 2008
    The control panel is out. Whirlpool appears to have had a major issue with this one. Part 8302319. It's on back order until 12/25/08, as many, many of us have had this thing break all about the same time. Interesting, huh? Wouldn't you think this would be a recall due to a faulty part? I would. Whirlpool says no. I'm fairly disgusted.
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Posted on Aug 01, 2009
Replace the 22uf-50volt capacitor. Looking at the glass display bottom right corner you need to flip the board to the tan side in that same spot you will see two small caps. You want to replace the smaller one. I replaced both for $2.00. Radio shack has them in stock.
Posted on Jul 17, 2011
  • 84 Answers
We repair this circuit board quite often. F2/E6 is caused by failure of control board. These can definitely be fixed and returned almost as fast as buying new.
Posted on Oct 24, 2009
Problem: no control panel display oven not working.
I replaced the control device in the Whirlpool built in oven
RBD305PDB14..and still does not work..
Posted on Sep 18, 2009
  • 110 Answers
You can call fox appliance,
you can go to www.repairclinic.com
Posted on Apr 03, 2008
  • Marc White
    Marc White May 09, 2008
    YOU CAN ORDER FROM SEARS,,,FOX APPLIANCE OR GO ONLINE TO REPAIRCLINIC.COM
No power on double oven after a storm
I have a RBD275PRS00 built in double oven. Had an electric
www.fixya.com/support/t8971528-rbd275prs00_built
Apr 16, 2011 - Had an electric storm the other night and ever since the oven won't -Whirlpool ... Question about Whirlpool RBD275PR Electric Double Oven ... For an oven to require parts after 2.5 yrs of service and 2 self cleanings tells me ... fiest press the on key see if the display comes if not the turn the power off for 5-8 ...
Whirlpool panel buzzing Ovens Questions & Answers - Fixya
www.fixya.com > Forum > Tags > panel buzzing > Ovens
Whirlpool ovens panel buzzing related questions and answers. ... the control panel on my Whirlpool electric double oven Model is RBD305PDS14? ... No power on control panel During self clean cycle the power to the panel went out. ... panel the instrument panel on an oven won't change time because of a storm problem.
Jan 01, 2016 | Whirlpool RBD275PR Electric Double Oven
I just bought a whirlpool built-in electric convection oven and cooking with it. But, the light does not turn off...why?
There is a light switch on the control panel will this turn off the light if not call for warranty service
Feb 05, 2015 | Whirlpool Ovens
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
Whirlpool Gold Series double oven electric model GBD307-PDQ309
Usually this is a touchpad and control panel fault but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
With the model number of the oven we could look up the code and be more specific about the problem.
Go here for: http://www.repairclinic.com/Whirlpool-Range-Stove-Oven-Parts
RepairClinic.com
asplogo.jpg?ver=23
appliance parts, help & more
Apr 09, 2009 | Whirlpool RBD305PD Electric Double Oven
How do I get into the fuse to change it on my whirlpool GBD307 PDQ7 oven? Where is it located?
There are different fuses, a fuse is located on control assembly board, a thermal fuse is accessible removing a panel at the back of the oven, or inside the oven.
Enter here to find assembly diagrams and parts for your model.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Whirlpool GBD307PDS Electric Double Oven
Oven does not heat
I would suggest that you check the oven element, it sounds as though it is faulty to me.
Dec 14, 2008 | Ovens
Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Apr 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Whirlpool Double Oven GBD307
there are three possible issues, one is a faulty ground. the computer uses ground to determine zero in binary logic. It could also be a stuck key on the input board, or the main control board. Check your owners manual, some units come with an exceptional warranty on the electronics. This is a big one and it may be worth your time to call a tech in to check it out. electronics are expensive and you can not send them back if you diagnosis is wrong.
Sep 24, 2007 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool RBS245PDS Electric Single Oven Logo
1,923 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Richard Roth
Richard Roth
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
