Question about Microsoft Windows XP Professional
Problem In network connection
The network disconnected itself within 5 minuted after the system starts though the network server Icon on taskbar shows as connected.
Please someone help me to get rid of this problem.
Could it be possible b'coz of any virus or cookies.
Since I came to know about this,an another problem I could see when the system starts a command box - like box named REGSVG.EXE appear on the desktop and state as follows " WE CAN'T ACCESS THE SPECIFIED PATH OF FILE. YOU MAY NOT HAVE THE APPROPRIATE PERMISSION TO ACCESS THE ITEM.
PLZZZZZZZZZZ HELP ME
    Problem Solver:
  • 6 Answers
1.do u have your laptop operating system cd?
2. if yes restart it
3.put in your cd and re-intall the operating system and the problem will be solved
Posted on Mar 29, 2008
SOURCE:
Can't connect CK31 to Barcode software
Hi Chris,
You need a few things to be able to connect your Intermec CK31 to a server and all the settings are within the "Intermec Settings" within the terminals control panel.
First thing to start with is the wireless profile, set this up to match your current access point wireless settings, SSID, Encryption Type, Key etc. You can also set your wireless IP. Once this is done there will be an icon in the taskbar that shows connection and signal strength. Depending on the firmware revision of the terminal you should be able to use the tools to ping a device on your network, if the server responds to a ping then you should be able to get to your server when you try and connect.
I hope this helps.
If you need any more help then please do not hesitate to contact us:-
[email protected] or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jun 19, 2012 | Intermec CK31C,COLOR TE2000,5KY LINR
Show error
E indicates an Error condition.
1.Without turning off the product, disconnect the USB cable from the rear of the product.
NOTE:The USB cable connects to the port on the rear of the product. The port is labeled with the USB icon ( ). If your printer has a network or wireless connection, ignore this step.
Figure 1: Example USB connection (your product might not look exactly the same as this example)
2.Remove the cartridges from the product.
3.Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
NOTE:If your printer does not have a display, wait until the cartridge lights blink. If the cartridge lights do not blink within a few minutes, skip to the next step.
4.Disconnect the power cord from the back of the product.
5.Wait 60 seconds.
6.Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7.Reinsert the cartridges, and then close any open doors on the product.
8.If you receive a prompt to print a calibration page, do so.
9.If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
5.Wait 60 seconds.
If that doesn't work you can log on to HP.com/Support and Drivers.
Find your device and search the error codes listed.
You can also download a real good Utility, HP Print and Scan Doctor.
Apr 27, 2012 | HP DeskJet F380 All-In-One Printer
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
My Acer Aspire One was working perfectly untill today, now it wont connect to the internet either by erthenet cable or wireless, each time i click on the browser icon it thinks about if for a few seconds...
Here are some suggestions that may help you resolve your Acer Aspire One problem.
Try to eliminate possible causes by
1. Shut down / power off all the PCs - the Aspire One and those belonging to your son and daughter.
2. Shut down / power off all game or multi-media consoles that can connect to internet via router.
3. Power off any another network connected devices (hard drives, printers, scanners, picture frames)
4. Power off your wireless router and cable/dsl modem for about five minutes.
5. Power on your cable/dsl modem.
6. After a couple of minutes, power on your wireless router.
7. Power on your Aspire One and a few minutes after desktop is loaded, shut off its wireless.
8. On the desktop's Taskbar, make sure the Wireless Network Connection icon has a red x beside it.
9. Look for the double-screen icon representing Local Area Connection in the desktop's Taskbar.
10. If not there, click start, control panel, network connections and right-click Local Area Connection.
11. Click enable on the pop-up to enable the Local Area Connection and its icon appears with red x.
12. Connect ethernet cable from one of the router's RJ-45 LAN ports to Aspire One's ethernet port.
13. The red x should disappear from the double screen icon in the Taskbar.
14. Hovering your mouse cursor over the icon should get a pop-up with the connection's status.
15. If OK, click on your IE browser icon on the desktop.
16. If nothing happens, click start button at bottom left and click on IE in start menu or program list.
17. If nothing happens, press Ctrl and Alt and Del key together to bring up Windows Task Manager
18. In WTM, click Applications tab to see if IE Task is running.
19. If not, click Processes tab to see if iexplore.exe process is running.
20. If not, check if you can start anything else such as Notepad.
21. If nothing starts, you should consider doing a recovery using Acer eRecovery Management.
22. If IE does start, click on its Tools tab then click on Diagnose Connection Problems...
23. Follow on-screen instructions to diagnose your connection problem.
24. If successful, close down IE, remove ethernet cable and restart the Acer Aspire One.
25. Disconnect the ethernet cable and turn on the Acer One's wireless with its wireless switch.
26. Big green letters "Wireless LAN Enabled" should appear momentarily at bottom of desktop
27. Followed by a pop-up balloon over the Taskbar's wireless icon announcing connection made.
28. Open IE browser again, click on its Tools tab then click on Diagnose Connection Problems.
29. Follow on-screen instructions to diagnose your connection problem.
30. If OK, the problem may be an interaction with one of the other networked devices/systems.
31. Redo this procedure but power on one of the other devices/systems before the Aspire One.
32. Redo one at a time for each of the other device/systems.
33. If the Aspire One is found to be OK with all of the devices/systems connected one at a time
34. Then the problem may be when ALL of the devices/systems are on and connected.
For example, depending how it is setup, the router's DHCP may have run out of IP addresses.
Another example is IP address conflict due to systems not flushing their IP cache on restarting.
These two examples assume the problem exists regardless either on wired or wireless connection.
If just one of the devices/systems is causing the problem, it may have been infected with a virus.
Jan 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
Cant find network system icon as turned off
Try these steps.
Open RUN (go to start--> run) then type NCPA.CPL, this will open the available network connections on your PC. Now check whether network driver is Enable or Disable. If its Disable you need to Enable. Right Click on that icon and select Enable.
If that doesn't work try the next step. Right Click on the Taskbar and select Properties. Now you can able to view the Taskbar and Start Menu Properties. On the Taskbar Tab Click on Customize. There you can able to view your current items. Select your network there and select the option Always Show from the drop down list.
Please let me know about the status.
Dec 23, 2010 | Dell Inspiron 1300 Notebook
Windows 2000 Server networking works, Local Area icon missing
Did you try visiting the (Broadcom NetXtreme gigabit) website for a updated driver or patch?. Also sometimes windows updates could be the problems try a system restore is you did any recent update.
Jul 03, 2009 | Computers & Internet
Icon shows connected but cannot surf net and receive emails
try this, turn off your pc then shut down your router then shut down the modem after 5 minutes restart the modem after all the lights are lit turn on the router after all those lights are lit start you pc, then go to my network icon and view network connections, then click on the properties tab high light the tc ip line and hit the properties tab click Obtain IP address automatically and the same for Obtain DNS server automatically. In the advanced tab in the IP address box have DHCP Enabled and check the box Automatic metric, in the DNS tab check Append primary and connection specific DNS suffixes and check the box to Append parent suffixes of the primary DNS suffix, at the bottom check the box Register this connection's address in DNS. In the WINS tab check the box Enable LMHOST lookup and click the Default in NetBIOS setting. Now having done this click OK and OK again then click the close tab for the properties window and then reboot your computer, you should be able to surf the net with out any problems.
Sep 10, 2008 | NetGear WGR614 Wireless Router
Wifi
SCENARIO 1
1. Goto "Start"
2. Click on " RUN"
3. Type in "ncpa.cpl"
Click OK
Now the network connections window will come up
Right click on wireless network connections TAB
Goto properties
Under the general category
U will find two check boxes- Show icon in notification area when connected
Notify me when this connection has limited or no connectivity
Make sure that both are checked....
Then click on OK and you will find the WIFI icon in ur system bar...
IF THE PROBLEM IS NOT RESOLVED THEN FOLLOW SCENARIO 2
SCENARIO 2
Right click on start button
Goto properties
Under the taskbar category
click on customize
it will give u the list of options
Find wireless network connection option
click on it and change the status to always show and click ok
Then click apply and then ok
Problem shud b resolved 100%
Feb 18, 2008 | Computers & Internet
Connection to internet through BTVOVAGER2091
You need to clone the MAC Address of the Belkin Adapter.
Oct 30, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Cannot connect to modem
if you know the cables are connected and not faulty, then it could be the fact that the network card itself is dissabled, so right click on the network icon in your taskbar and click status if showing and click enable in the next window, if when you right click on the icon in the taskbar and the option to 'connect' is displayed, click this instead. If non of the above work, you may have a faulty cable or network card.
Jul 31, 2007 | Linksys BEFSX41 Router (DHBEFSX41)
Microsoft Windows XP Professional Logo
55 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
