Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
Clean light is flashing. Will not operate. suspect heater circuit
    President:
  • 949 Answers
This is due to the water not heating properly.
Here is a link to show how to reset the control so you can use it, what may be causing it and how to resolve it.
Posted on May 10, 2010
My delay light has come on and I cant get the dishwasher to start. The delay light goes out after the time has expired but if you try to move it to the start position the light comes on again
The Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). The Control will flash the Clean LED 7 times repeatedly and will disable the Start/Resume key until cleared.
To clear and reset the control press in this order: Heated Dry ? Normal ? Heated Dry ? Normal and then let the unit run for 1-2 minutes and then press Cancel and let the dishwasher complete the cancel cycle. The dishwasher should operate normally again unless it does not detect a temperature rise in the main wash cycle.
It could be caused by a Heater circuit problem if it continues to stop and flash the Clean light.
It could have one of the following failures:
Open in heater.
Open connection or component in heater circuit.
Faulty heater drive circuit on control.
It can also be caused by the wash pump not pumping water past the heater efficiently.
Oct 11, 2016 | Kenmore Dishwashers
"Clean" light is flashing and cancel button will not correct problem. Is there a way to reset so dishwasher can return to normal operation?
Hi
If clean light is blinking 7times then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn't work then its an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Oct 23, 2010 | Dishwashers
My dishwasher seems to be locked up and needs to be reset. the clean led is constantly flashing. i had this trouble in the past, and the serviceman reset the dishwasher by using the touchpad on the front...
stop the current cycle and
cycles if it suspects a
faulty heater (no
detected in heated
intervals). Control blinks
the Clean LED 7 times in
repetitive fashion and
disables the Start/Resume
key until cleared.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater
circuit.
■ Faulty heater drive
circuit on control.
Running Diagnostics clears the control and
allows it to operate again. If heating problem
is not corrected though, the control will stop
running again on next cycle. See below.
1. Unplug dishwasher or disconnect power.
2. Check all components and connections in
the water heating circuit or heat dry circuit.
■ Check resistance of heater.
■ Check resistances of all connections and
components between the control and
heater.
■ Check operation of heater and temperature
sensor in Diagnostics cycle.
Aug 26, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool dishwasher model number GU3600XTSY2 is flashing: The clean light is flashing! It's not the heater circuit either. It says the dishwasher is malfunctioned. Call for service to check heater...
The clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Mar 17, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Clean light is blinking. dishwasher won't turn on
it is a problem with the heating cycle.Dishwasher “Clean” Light Blinks 7 Times The electronic control looks for a temp. rise of 2° - 4° F.
If no temp rise, the control assumes a heater fault and blinks the clean LED 7x.
Check the heater circuit, water fill, wash pump operation, and neutral side door
switch.
Run a Diagnostic Cycle to reset the control.
REPLACING THE CONTROL WILL NOT RESOLVE THE CONDITION.
All Electronic Controls
S.O.P. – Standard Operating Procedure Whenever an electronic control is suspected
to be the cause of a product failure: before replacing the control, disconnect and then
reconnect all of the wiring harness connectors to ensure proper electrical contact.
I hope this helps.
Jan 24, 2010 | KitchenAid Dishwashers
Kenmore 665 17033400 Elite dishwasher clean light flashes 7 times and it wont run. i used the reset combination, all lights lit and stayed lit until i pressed reset. Then it started a wash. now the wash...
That signals an issue with a faulty heater &/or heater drive circuit.
(that info comes from their troubleshooting guide)
I ran into it this weekend and discovered that the heater coil in the bottom of the washer was broken.
Jan 14, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Model # 665.17032402 Clean light is flashing. Manual says to check heater circuit. How is the heater circuit checked? How is the heater element assembly replaced?
You need to check the thermostats in the heater circuit as well. The element is held in place my 2 nust from the bottom where the wires attach.
eric
Jun 29, 2009 | Dishwashers
Blinking Clean light in Whirpool dishwasher
Control is programmed to stop running and not allow any further cycles if it detects a water heating problem (no temperature increase detected in heated Main Wash on 3 consecutive cycles). Control blinks the Clean LED 7 times repeatedly and disables the Start/Resume key until cleared. Running Diagnostics clears the control and allows it to operate again. The water heating problem must be fixed or the control will stop running again. See potential causes below. Heater circuit problem: ■ Open in heater. ■ Open connection or component in heater circuit. ■ Faulty heater drive circuit on control. 1. Check operation of heater in Diagnostics cycle. 2. Unplug dishwasher or disconnect power. 3. Check resistance of heater and all components and connections in the water heating circuit or heat dry circuit.
dont forget to vote hope this helps thank you
Jun 20, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Clean light flashing
The clean light should be blinking 7 times, pause, then repaeat if it is doing this -- it is a water heating fault. Use one of the following key dances to clear fault
a) Heat Dry - Normal - Heat Dry - Normal
b)High Temp-Air Dry-High Temp-Air Dry
All the Leds should light up now just press cancel and Unit should operate. If it shuts down again the heater isnt working properly. Some times the door doesnt get shut well and that causes the fault. But the dishes arent very clean if the heater is not working.
Oct 16, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
185 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
