Dell Optiplex GX-270 Dual Channel Memory
I have inserted 2 dimms at position 1 and 3 on mobo to get advantage of Dual Channel Support. when i looked into BIOS (Phoenix-A03) it showed memory channel =1. do i need to upgrade my BIOs from A03 to A07 (latest).
nilesh
    Sergeant:
  • 318 Answers
Depends on the motherboard, you might have to have paired memory, which means you might have to use 1 & 2 as a matched pair. This has to do more with the make of the motherboard rather than the bios.
Posted on Mar 28, 2008
SOURCE:
Why does my computer dell optiplex gx 270 not fully support direct x 8.1
Your video card determines Direct X support. If you look at Newegg.com--find a newer video card and read the tech specs most of them now support Direct X 10 or higher.
I hope this helps!
Aug 10, 2012 | Dell Optiplex gx 270 heatsink & fan asm
I have dell optiplex gx 520, it gives no display, it gives 6 long beeps, all capsitors are in good condition.
remove all your RAM and insert 1 by 1 into the dimm slots (power on each time to see which slot is faulty)... try this for each RAM module to see which is still good
Aug 04, 2011 | Dell OptiPlex GX280 PC Desktop
I have dell optiplex gx 150 beeps 6 times and a and b led is amber and c and d led is green
the 6 beep codes will be in a specific timing i.e. two beeps, a space 2 more beeps, and another space and 2 more beeps.
Looks like it may be a memory problem according to the lights.
ad54556.gif Possible memory failure
Reseat all DIMMs and restart the system to retest.
Here is the link to the beep codes and diagnostic lights for your dell optiplex gx 150 HERE
The Beep codes are in Table 2 and the diagnostic lights are in Table 3.
Apr 14, 2010 | Dell Computers & Internet
I'm doing a memory upgrade. i have four memory slots, 2 blue and 2 black. i have two, 2g dimms; for dual channel operation do i use the 2 blue slots or the first blue slot and the first black...
Try them in the same-colored slots, nearest the processor. It seems ASUS (who makes your mobo) has chosen to color code their slots so those of the same color enable dual-channel. If you can't tell from the BIOS detection, try CPU-Z to verify that the memory is in the correct slots for dual-channel operation. Putting one in the wrong slot should not damage anything. It would just make it so you can't take advantage of the extra speed.
Oct 24, 2009 | HP Pavilion A6430F Desktop PC
Can you mix 1gb and 2gb dimms in the same machine (for a total of 6gb)? I added two 2gb 1066 DDR2 dimms (''OCZ'') to a PC that already had two 1066 DDR2 1gb dimms (''Kingston''). I moved the 1gb dimms to...
Your MB is AM3 with 128MB DDR3-1333 built-in, four 1.8 Volt DDR2-1200+ depending on cpu. Have you enabled cpu 64 bit extensions? Tried slowing down your memory bus?
My ASUS use dual channel for dual core cpu. I have 2 yellow and 2 black dimm sockets. Both dimms in yellow is single channel, one in yellow and one in black is dual channel. Might try 2,1,2,1 rather than 2,2,1,1 order. If only your 2 1GB dimms are seen then why do you get 4 GB from 1GB+1GB? Sounds like sockets 1,2 are giving you 4GB and 3,4 don't work? Are the 1GB+1GB in 3,4 visible if the dimms in 1,2 are removed? Per Gigabyte page your AMD Phenom II 920 is AM2+ : "Note: Due to AMD AM2+ CPU limitation, memory module DDR2 1066 or above speed is only supported by 1 dimm per channel." Per AMD (which does not show your cpu, AM3 cpu fit AM3 or AM2+ socket and support ddr2 and ddr3, AM2+ cpu only work in AM2+ socket and support ddr2 only.
Oct 16, 2009 | Computers & Internet
Is dell optiplex gx 270 apligable for optiplex 270
i don't see any reason that you can't as long as you use the 260 drivers.
Nov 16, 2008 | Computers & Internet
How do I fit memory upgrade into an Acer L100
Fit memory upgrade? If you mean what memory to buy?
Up to 2 GB of DDR2 533/667
MHz soDIMM SDRAM (dual channel support on two DIMMs)
If you mean install it? Just look at the notches on the DIMM and on your mobo...line them up and snap them in.
James Mac
www.earncashsleeping.ws
Aug 31, 2008 | Acer Computers & Internet
Open Questions:
Computers & Internet Logo
307 people viewed this question
Ekse
Alun Cox
