Question about Garden
Does the Honda 3813 take a positive or negative ground?
  • 2,100 Answers
Most all garden tractors here are negative ground. I have seen only a few things positive ground, and that was an old land rover and old jaguar, Both british made. I couldn't find any reference to it being different. Hope this helps.
Posted on May 10, 2010
1993 Honda shadow vt 1100 drove it to work today park it for about 2 hours went out to crank it the bike started for a second then died hit starter button again and lost all electrics no electrical power...
Hi, Bobby the following is a comprehensive charging system test that is guaranteed to the find issue with your system.
1. Battery Test: The battery needs to be a fully charged and load tested to ensure proper readings, connections need to be clean and tight. If you are not working with a fully charged and functional battery, all other voltage tests will be incorrect. Standing battery Voltage should be 12.5-13.2 DCV.
2. Charging System Voltage Test: Start motorcycle, measure DC volts across the battery terminals you should have a reading of approximately 13.2-15 DC Volts.
3. Check Connections/Wires: Inspect the regulator/stator plug, and check the battery terminals for connection/corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC Output test Fails and Resistance Check, and Stator IB Test Pass then Rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator
Start motorcycle and change Voltmeter to AC volts.
Probe both stator wires with your meter lead.
The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
22 amp system produces about 19-26 VAC per 1,000 rpm
32 amp system produces about 16-20 VAC per 1,000 rpm
45 amp system produces about 19-26 VAC per 1,000 rpm
Stator Resistance Check:
Switch your multimeter to Ohm x 1 scale.
Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on system, check service manual for specification
Generic Specs:
22 amp system produces about 0.2 to 0.4 ohms
32 amp system produces about 0.1 to 0.2 ohms
45 amp system produces about 0.1 to 0.2 ohms
Stator IB test or Ground Check:
Probe each stator wire with your positive lead on the multimeter and the negative to ground.
There should be no continuity to ground on either wire.
If there is continuity to ground your stator is shorted to ground.
5. Regulator Test: Each of the following tests isolates the regulator only, so if any of these tests fail, the regulator is at fault.
Identifying Wires:
Battery Charge Lead- Wire going from regulator to battery positive.
AC output leads- Wires coming from the Stator to the regulator.
Ground- Wire from Regulator to ground or regulator may be grounded via the physical bolting to chassis.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from regulator body to chassis ground).
Fwd/Reverse Bias Test/Diode Test: This check is testing the Diode function to ensure it is regulating the AC current for the stator into DC Current.
Switch multimeter to Diode Scale.
Place your Multimeter positive lead on each AC output wire.
Place your multimeter negative lead on the battery Charge wire.
The meter should read voltage typically around .5 volts.
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire.
The reading should be Infinite.
With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires.
Note: Below is a table to show the readings:
Positive Lead Negative Lead Reading
AC output 1 Battery charge lead Voltage
AC output 2 Battery Charge Lead Voltage
Battery charge lead AC output 1 ?
Battery charge lead AC output 2 ?
Ground AC output 1 Voltage
Ground AC output 2 Voltage
AC output 1 Ground ?
AC output 2 Ground ?
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
VT1100C No power just went dead Honda Shadow Forums Shadow Motorcycle Forum
http://www.jetav8r.com/Vision/Stator/fault_finding_by_www.electrosport.com.pdf
Honda SHADOW VT1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual
Feb 19, 2017 | 1994 Honda VT 1100 C Shadow
On my honda 50 cc moped nthing happens when i press starter button nothing hapens trevor
The first thing to do is get a multimeter and check your battery. I assume it's 12V so you'll need a minimum of 12.6V. Then put your negative lead on battery negative and positive lead on the hot wire to the starter. If you have battery voltage when you hit the button move your negative lead to the starter ground and check again. If you have battery voltage then your starter is bad. The maximum voltage loss acceptable is .5V from battery voltage. If you don't have battery voltage after the first test possible fuse wire or switch, if not after the second test bad ground.
Jan 31, 2017 | Honda Motorcycles
2002 Honda VT 1100 C2 Shadow Sabre how to check if your getting power from alternator
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amperage and must be replaced AGM types more so than lead acid batteries.
1. Battery Test:
3. Connections and wires:
Inspect the regulator stator plug, and check the battery terminals for connection corrosion. If everything seems to be in order, move on to number 4 below to determine if there's a failed component.
4. Stator Checks/Rotor Check: Each of the following tests isolates the Stator & Rotor. If AC output and resistance test fail and stator test passes then the rotor is at fault (Pull Primary covers and inspect rotor for damage).
5. AC Output Check:
Unplug the regulator plug from the stator start motorcycle and change Voltmeter to AC volts. Probe both stator wires with your meter lead. The motorcycle should be putting out approximately 18-20 ACV per 1,000 rpm. Reading will vary depending on system, check service manual specification
Generic Specs:
Switch your multimeter to Ohm x 1 scale. Probe each stator wires with meter leads and check resistance on the meter.
Resistance should be in the range of 0.1-0.5 Ohms. Reading will vary depending on the system, check the service manual for specifications.
Generic Specs:
Stator Ground Check:
If there is continuity your stator is shorted to ground and must be replaced.
5. Regulator Test:
Identifying Wires:
Next, switch your multimeter leads putting the negative lead on the AC output wires and the Positive lead on the Battery Charge Wire. The reading should be Infinite. With your meter on the same setting, place your multimeter positive lead on the regulator ground wire or to the regulator directly, and then place your meter negative lead on the AC output leads.
Next, switch your multimeter leads putting the negative lead on the regulator ground and the Positive lead on the AC output wires. The reading should be Infinite.
Stator test honda shadow
http://racetechelectric.com/files/pdf/rte_troubleshooting_flow_chart.pdf
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Jun 27, 2014 | 2002 Honda VT 1100 C2 Shadow Sabre
1988 Honda VT800 not charging
Hi, Anonymous before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
5. Stator Ground Check:
6. Regulator Test:
Identifying Wires:
Battery Charge Lead- Wire going from the regulator to battery positive.
Regulator Ground Test: Ensure the regulator body is grounded or grounding wire is fastened tightly to a good ground (you should verify this by checking continuity from the regulator body to chassis ground).
For more information about your issue and valuable "FREE" downloads for viewing or printing that you will need please click on the blue links below. Good luck and have a wonderful day.
Help battery not charging while running also ignition problem
88 Shadow 800 Not Charging
honda vt800 pdf 1 Docs Engine com
http://mybikemanuals.com/honda/honda-vt-owners-manuals
Aug 18, 2013 | Honda VT 800 Motorcycles
Honda 2004 Sabre will not charge the battery
Hi, Rhall20448 before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Battery Test:
5. AC Output Check:
Generic Specs:
Generic Specs:
6. Regulator Test:
Identifying Wires:
Why won my battery hold charge
Honda Shadow VT1100C Charging System Repair
Jul 27, 2010 | 2004 Honda VT 1100 C2 Shadow Sabre
1987 honda accord need the color codes for radio wiring harness?
hi
Car Radio Battery Constant 12v+ Wire: White/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Red
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Antenna Trigger Wire: Yellow/White
Left Front Speaker Positive Wire (+): Blue/Green
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): Red/Green
Right Front Speaker Negative Wire (-): Brown/Black
Left Rear Speaker Positive Wire (+): Blue/Yellow
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): Red/Yellow
Right Rear Speaker Negative Wire (-): Brown/White
if my information was useful please vote me
Jul 12, 2010 | 1987 Honda Accord
I need diagram of the stereo wires to put in an aftermarket stereo
1996 Honda Accord Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow/White
Car Radio Accessory Switched 12v+ Wire: White/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Deck
Nov 24, 2009 | 1996 Honda Accord
I am looking for sevice bulletins for honda 3813 lawn tractor
I had a similar problem with my Honda 3813. When I tore it down, I found that the 3813 has a slow delay cyclinder - something like a shock absorber - the slowly puts pressure on the clutch plate after you let up on the clutch pedal. In my case, the clutch is old and worn, this is exactly the symptom I experienced because the clutch was nearly worn out - it took like 10 or more seconds to get going. A new drive clutch and a little adjustment fixed this problem for me. To replace the clutch without removing the engine I had to cut the cross brace plate on the bottom of the tractor.
To get to this you need to remove all the tin that is under the seat part of the tractor - a real nuisance.
Also, it took me 3 months to get the clutch from the Honda dealer. .... definitely not helpful! Good thing I had a John Deere as a backup, I've never had trouble getting parts quickly for that.
Mar 13, 2009 | Garden
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
