Question about Lexmark X1240 All-In-One InkJet Printer
Scanner not workin-lexmark x1240
Ive installed my software to my computer but it doesn't give me an option to scan,it prints fine but i cant scan
  • 6 more comments
  • clsjh6 Apr 03, 2008
    prints fine but won't scan
    oh and won't copy either
  • clvpsy9 Apr 10, 2008
    [email protected]
    I can't copy or scan from my Lexmark X1240, either. I have uninstalled my firewall and it worked once, now I have installed and uninstalled my Lexmark X1240 and it still does not scan or copy. It will copy from the printer and it does not allow change of color, it comes out orangish. I have almost given up. Help!!!
  • Anonymous May 24, 2008
    prints fine but wont scan or open the All in One center- sounds like I bought a lemon
  • kha-sha Nov 21, 2008
    i haven't tried to print but iu can't seem to scan pictures r even find a icon that will help me my problem is the same
  • klim Dec 26, 2008
    HI I HAVE A PROBLEM WITH Lexmark x1240 I CAN PRINT BUT CAN NOT COPY OR SCAN. I have Win XP-PRO - i dont know what to do tried everything
    help me please
  • Anonymous Dec 28, 2008
    will not print are scanner
  • papa14 Feb 24, 2009
    I have same problem, the light on the scanner never turns on. Is it possible that the scanning light needs to be replaced? Printing is fine.
    Genius:
  • 2,035 Answers
Which operating are you using if your using (Vista use windows photo gallery to scan)
Posted on May 02, 2008
SOURCE:
I have a lexmark x1240 and just installed a new cartridge. I keep getting an error message that says " print cartridge missing" install print cartridge even though both cartridges are in the printer.
If you insert the old cartridge, does it recognize it? If it does, then it's a problem with the new cartridge. Try to check if you already have taken out the protective tapes out of the cartridge.
If it still doesn't recognize the old cartridge, then it's a problem with the printer.
Nov 29, 2012 | Lexmark X1240 All-In-One InkJet Printer
My lexmark x1240 all-in-one will not print. It saves XPS files and when I go to open them it will not open them. I have already installed the XPS reader. Also, when I try to scan, a box pops up saying...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/lgJCxt. Select your operating system, download and execute the file.
Try to scan again to verify that the problem is fixed.
If the problem continues, please contact Lexmark Technical Support for additional assistance.
Oct 11, 2011 | Lexmark X1240 All-In-One InkJet Printer
Hi, i was using lexmark x1240 printer and scanner, i changed my laptop but i lost my cd so i cannot download it to my new computer. what should i do?
The drivers and full software are available for supported OS versions here: http://support.lexmark.com/index?page=product&locale=en&productCode=LEXMARK_X1240&segment=SUPPORT&userlocale=EN_US#1 .
Please note that the download doesn not include any third-party software that came on the original disc.
I hope this helps.
Apr 30, 2011 | Lexmark X1240 All-In-One InkJet Printer
I have windows 7 and when i print pictures it prints one or two pictures and then it do not close and i have to restart my computer It worked fine on xp home
Use the Windows 7 driver from the Lexmark website. You may need to uninstall the existing Lexmark X1240 driver first before installing the new one. Instructions on how to uninstall the Lexmark software available at http://bit.ly/8ZH59T. Then, check if your Windows 7 is running on 32-bit or 64-bit operating system by going to Start menu > right click on Computer > Properties. You can download the Lexmark X1240 driver for Windows 7 at:
Click on Download Now, execute the file and follow the instructions in the software. Thank you for choosing Lexmark.
Oct 11, 2010 | Lexmark X1240 All-In-One InkJet Printer
My lexmark x2650 printer wont let me scan. ive installed and uninstalled software. i get flashing lights on the top of the printer at the bottom right hand side
Please open the paint from "start/all programs/accessories/paint"
when you open the paint " click on file and selct the option scanner and camer wizard if your scanner is installed then the option is hilichted. click on scan and it will scan the document. this is easiest way to scan the document.
Nov 02, 2009 | Lexmark X2650 All-In-One InkJet Printer
I just bought a new lexmark copier, scanner, fax,
This should give you a good explanation of what ocr is.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1268319518_0_en,00.html
Jul 07, 2009 | Lexmark X3550 All-In-One Printer
Scanner all in one center not appearing
If you have the BLUE LINES on the print out, you have an image quality issue, try cleaning the printhead 3x to resolve problem
Nov 06, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
382 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
