Question about Zanussi 23 in. ZDI6041 Built-in Dishwasher
Zanussi Integrated Dishwasher ZDT6244
My dishwasher is causing the RCD to trip on my fuseboard. Have had an engineer out who diagnosed a crack in the motor housing that is allowing water to leak on to the wiring underneath. He repaired it with some sticky stuff but that only held for 30 mins. When I called him back said needs new motor housing will phone you with estimate. No further response in spite of 3 reminders, makes me think he doesn't want to do it. Tried other firms but nobody wants to repair integrated dishwashers! Is it possible to DIY? Can't even find the model number on your site. It is only 3 yrs old.
  • 185 Answers
Is there a model number anywhere on it
Posted on Mar 28, 2008
Dishwasher is tripping RCD, can it be repaired?
not necessary-- yet-- to buy a new unit
tripping the rcd is an indication of earth leakage which could amount to water in the wall plug across pins, moisture across the power board, water in the motor, faulty heater element
what you need is an accredited electrician to run tests on the system to find the reason for the earth leakage that is tripping the rcd
the rcd works from microvolts and operates in nano seconds to prevent electrocution of the operator
testing before buying may save heaps of cash
May 19, 2015 | Stoves Dishwashers
Hi, my zanussi izzi dishwasher has started acting up, it will start a cycle but after a couple of minutes it trips out the main RCD in the fuse board, now i have isolated it to the dishwasher itself and...
If it trips after a few minutes of coming on , it is probably the heater which is faulty , disonnet it and try , if it doesn't trip you need a new heatee
May 02, 2017 | Zanussi 24 in. IZZI ALU Built-In...
Hotpoint Aquarius FDW60 tripping electrics
I had the same problem. found out that the RCD was faulty & needed replaced. now o.k.
Sep 14, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Washer/drier tripping rcd!
Hi.
Sounds like you have a short or an earth fault.
if it trips right away, try it with the motor disconnected, if it still trips then you will probably have to call an engineer..
Nov 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Faulty Diplomat Dishwasher - tripping mains fuse
My dishwasher a diplomat 12 program (hja8640) was doing exactly the same where every now and again when turned on at the plug it would trip. After engineers coming out several times and failing to fix it, they condemed it. New one was supplied, however did exactly the same thing. The electrician came back, checked the RCD power breaker and this was fine. It was then discovered that some dishwashers and washing machines send out a lot of earth leakage, combine this with other appliances on in the house can be enough to trip.
Soloution. The electrician removed the kitchen circut from the RCD breaker and intalled another breaker RCD just for the kitcehn loop, this therefore means that the kitchen has a seperate trip from the rest of the house, and touch wood, has solved the problem. This mind you has taken about three months to work out so i hope it saves you some time.
Always use a fully qualified electrician though.
Thanks.
Oct 21, 2008 | Dishwashers
ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Sep 30, 2008 | Zanussi ZHQ575 Electric Double Oven
Smeg dishwasher tripping out fuseboard
Has the door got any heavier, as mine started tripping the electrics when a spring broke and short circuited the connections.
f so you will have to get the spring out, from the underneath is best and replace it if you want the door to work correctly again. On mine the second one went a month later.
Aug 07, 2008 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Jul 18, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
Rcd tripping
Well done ! Thanks for the information.
Jun 07, 2007 | Baumatic 23 in. BDW5 Built-in Dishwasher
Tripping out RCD
i had this probem and apparently there's a 'float switch' in the bottom of the machine. This switch is a safety cut off and when activated can not just stop the machine but trip the electrics in the house. the reason for it activating is when food clogs up the drainage bit water can not drain and fills up the bottom of the machine. this then activates the 'float switch' as a kind of safety cut off.
the way to sort it is to disconect the machine from the mains and drain and water. empty the clogged up food from the drain bit. then tip the machine back and a load of water will pour out (may need a load of towels for this bit or take the machine out the back and do it)
once this is done, plug it all back in and give it a try - works for my machine, good luck.
Aug 25, 2006 | Indesit 24 in. D63 Free-standing...
Zanussi 23 in. ZDI6041 Built-in Dishwasher Logo
548 people viewed this question
Top Zanussi Dishwashers Experts
Owen Barnes
Paul Carew
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
