Question about ASUS P5PE-VM Motherboard
Jpin location as msg and harddrive, pwsw jp20 goes
I set the pins but the green light is on for the computer and the yellow light stays on for harddrive I cannot boot to the window should I reload a new bios since I took the pins off and reset the motherboard pins back to determine the setup process and have to boot the open to F1 F2 F3 these were the setup for all bios and test run is set before you leave the bios or the computer never gets to the desktop or prompt write command. Show the diagram of where the pins or jpins go on the asus pe 3 5 or p3 b f
    President:
  • 2,666 Answers
Download the manual from here. The pin settings will be there.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on May 10, 2010
2000 KIA SPORTAGE STEREO WIRING DIAGRAM
You can use the attached diagram for assistance, but here goes:
1. Blue/Yellow (Pin 1) - Illumination (+12V) (when headlights on)
2. Black/Yellow (Pin 1) - Main Power (+12V)
3. Light Green/Black (Pin 2) - Memory Power (+12v)
4. Black (Pin 11) - Ground
5. Blue/Red (Pin 9) - Left Front Spkr Return (-)
6. Green (Pin 19) - Left Front Spkr Signal (+)
7. Brown (Pin 10) - Right Front Spkr Return (-)
8. Light Green/Yellow (Pin 20) - Right Front Spkr Signal (+)
9. Blue/Orange (Pin 7) - Left Rear Spkr Return (-)
10. Green/Yellow (Pin 17) - Left Rear Spkr Signal (+)
11. Green/Red (Pin 8) - Right Rear Spkr Return (-)
(Note here that the wire color at the rear speaker is
Green/Blue - not sure if this is a misprint (see diagram))
12. Yellow (Pin 18) - Right Rear Spkr Signal (+)
Nov 10, 2013 | Vehicle Parts & Accessories
9VJL3 front panel
Do not have the Front Panel header pinout.
Do have;
Take an LED (Light), with two wires, and check the pins with it.
There is a Top row of pins, and a Bottom row.
Touch the first two pins in the Top row, left side. Does it light up?
No? Go to the next two pins. No? Go to the next two pins.
Keep going until the Power Supply comes on. (It is a BRIEF touch. The Power On switch is a Momentary Contact Switch )
Now you have the Power On switch pins.
LED light blinks? You have the Harddrive activity LED. (Light)
LED light stays on? You have the Power On LED. (Light)
Computer restarts? The Restart switch pins.
Short something out? NOPE. You can't hurt a thing using this method.
4 of those pins are for an internal speaker. (To hear BIOS Beep Codes with)
That's 12 of those 18 pins. (Probably less. It is two rows of 9 pins, that are stated for the Front Panel header)
4 of those pins probably won't be used.
You won't be using IR. (Infra Remote) (Only uses 2 pins, though)
Most of the time with an 18-pin Front Panel header;
Top Row:
Starting at Left side, going towards Right;
Pins 2, 4, 6, 8, 10, 12, 14, 16, and 18.
May be a pin missing in this row, or two.
Borrom row:
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Same thing here. May be 1 or 2 pins missing.
Pins 2 and 4 are usually for the Power On LED. (Light Emitting Diode)
Pins 6 and 8 - Power On switch.
Pins 10, 12, 14, and 16 may be for the Internal speaker.
Pins 18, and 20 are usually not used.
Pin 1 and 3 for the HarDDrive activity LED.
Pins 5 and 7 for the Reset switch.
Pin 9 is usually reserved for the factory, and is a 5 Volt test point.
Pins 11, 13, 15, 17 for speaker; or not used. Same with pin 19.
(So speaker pins may be top row, or bottom row. Dunno )
Another thing. This motherboard is old enough to be using a 3 wire LED, or dual color; for the Power On LED.
LED usually had the colors Green and Yellow.
Yellow for 'Normal' mode, Green for 'Turbo' mode.
(Which is a bunch of cr@p.
Green LED, or Turbo Mode; was actually NORMAL.
Normal mode was the computer operating BELOW the Normal mode)
So pins 2, 4, and 6, may be for a 3 wire Power On LED.
Regards,
joecoolvette
Dec 22, 2012 | Chaintech 9VJL3 P4(478)/VIA Motherboard
How to connect front panel to acer power s290 motherboard
http://www.ascendtech.us/acer-aspire-sa90-mbs7109002-motherboard_i_mbacembs7109002.aspx
The front of your computer is the Front Panel.
The area of pins on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Looking at the Front Panel header it is parallel to the outside edge on the bottom/right of the motherboard.
13 pin header.
6 across the Top row with 1 pin missing, 7 across the Bottom row.
Top row is numbered EVEN
Starting on LEFT side coming across to the Right, Top row;
Pins 2, 4, 6, 8, No Pin, 12, and 14.
Pins 2 and 4 have a Green area
Pins 6 and 8 have a Red area
No Pin 10.
Pins 12, and 14 have a Yellow area
Bottom row is numbered ODD.
Starting on LEFT side coming across to the Right, Bottom row;
Pins 1, 3, 5, 7, 9, 11, and 13.
No Pin 10.
Pins 12 and 14 have a Green area.
A) Pins 2 and 4 in the Green area (Top left) are for the Power On LED
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
B) Pins 6 and 8 in the Red area are for the Power On switch.
C) Pins 12 and 14 are N/C. Not Connected
D) Pins 1 and 3 in the Yellow area, are for the HarDDrive activity LED light.
Pin 1 is for the Positive wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
E) Pins 5 and 7 in the Purple area, are for a Reset switch, IF a Reset switch is used.
F) Pins 9, 11, and 13 are N/C.
(Pin 9 is 5 Volts DC. Used by the factory for testing)
Regards,
joecoolvette
(I thought the internal speaker was that round little 'buzzer', below the bottom white PCI slot, (PCI 2), and close to the edge of the motherboard )
Nov 01, 2012 | Acer Power S290 PC Desktop
ABIT-BD711
Okay,.......that was DU-MB!
Lemme see,.......oh yeah!
Letters and words! !O_O!
(Wondered where my glasses were!)
http://images.search.yahoo.com/images/view;_ylt=A2KJkCAV3j9QW2cAUAOJzbkF;_ylu=X3oDMTBlMTQ4cGxyBHNlYwNzcgRzbGsDaW1n?back=http%3A%2F%2Fimages.search.yahoo.com%2Fsearch%2Fimages%3Fp%3Dabit%2Bbd711%26fr%3Dmoz35%26fr2%3Dpiv-web%26tab%3Dorganic%26ri%3D2&w=600&h=444&imgurl=www.ixbt.com%2Fmainboard%2Fimages%2Froundup-i845e%2Fbd7ii-raid-board.jpg&rurl=http%3A%2F%2Fixbtlabs.com%2Farticles2%2Froundupmobo%2Fabit-bd7ii-raid-i845e.html&size=111.5+KB&name=Abit+BD7II-RAID+%28i845E%29+Mainboard&p=abit+bd711&oid=14ba8ece461cfe2b401fe4f974d4c0b7&fr2=piv-web&fr=moz35&tt=Abit%2BBD7II-RAID%2B%2528i845E%2529%2BMainboard&b=0&ni=56&no=2&ts=&tab=organic&sigr=124cn6s7j&sigb=12vbgaaru&sigi=120054ob4&.crumb=J6iwC7bwOtM
Motherboard photo, and detailed info below it. Scroll down.
Looking at the motherboard installed in the computer case:
1) To the right of the Ram Memory slots, and in the upper right corner, is the 20-pin ATX main power cable connector, on the motherboard.
Whitish connector with two columns of 10 socket holes.
A 20-pin ATX main power cable plugs in here,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note the Lock on the side of the power cable's connector, (Middle photo, and right photo), and the Tab on the motherboard connector, (Left photo)
When the power cable is plugged in correctly, the hooked end of the Lock on the power cable's connector, will be hooked over the Tab on the motherboard connector.
2) Look at the bottom Left corner of the Processor socket. Note the three cylindrical objects. (Radial Aluminum Electrolytic Capacitors)
Note the whitish square 4-socket hole connector below them.
This is where the 4-pin ATX +12 Volt power cable goes. It also has a Lock, just like the 20-pin ATX main power cable connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
This is power for your Intel Pentium 4 processor.
3) To the Right of the Ram Memory slots, and located below the whitish 20-pin ATX main power cable connector, are the two IDE connectors. (Turquoise Blue)
One is for an IDE (PATA) harddrive, and one is for an IDE(PATA) optical drive. (CD/DVD drive)
The one on the outside near the edge of the motherboard, has IDE1 next to it.
It is for the Harddrive.
The one closer to the middle of the motherboard is IDE2.
It is for the optical drive. (Or drives { 2 } )
NOTE*
One side of those rectangular connectors has a cutout in the middle.
(Square U-shape cutout)
This is where the Locating Lug, on the flat ribbon IDE cable's connector, goes to.
It aligns Number 1 pin in the connector, with Number 1 wire, in the flat ribbon IDE cable.
IF, there is NO Locating Lug on the flat ribbon IDE cable;
On one side of the flat ribbon IDE cable is a thin RED stripe.
This stripe denotes the side that Number 1 wire is on,
http://en.wikipedia.org/wiki/File:Nappe.svg
Looking at the rectangular IDE1 and IDE2 connectors, Number 1 pin is at the BOTTOM of those connectors.
(Motherboard installed in computer case)
On an IDE harddrive, Number 1 pin is ALWAYS towards the 4-pin power connector.
Same with an optical drive.
4) Since this is a motherboard, that has a RAID option for using multiple harddrives, I'm guessing the two Yellow rectangular connectors, below the two rectangular Turquoise Blue IDE connectors, is for more IDE harddrives.
http://en.wikipedia.org/wiki/RAID
5) Below the two Yellow IDE harddrive connectors is a Black rectangular connector.
This has 34 pins, and is for a Floppy Drive, IF a Floppy drive is used.
6) Below the Black Floppy Drive connector on the motherboard, is the Front Panel header.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
What is needed here is a Front Panel header pinout.
Dunno. Photo isn't clear enough.
Looks like a Black rectangular strip of plastic, with 8 pins in a row.
4 pins, 3 spaces, 1 pin, 1 space, 3 pins.
Looking closely, (And you may need a bright light, and a magnifying glass), what are the abbreviations next to the pins, on the outside edge of the motherboard?
HDD = HarDDrive activity LED (Light)
PW = Power On switch
RST = Reset switch
PWLED, or close to that effect = Power On LED.
Post back in a Comment.
IF, it is just a row of single pins going across, I would use an LED light that has two wires on it.
Computer, (Power Supply actually), plugged into power, touch the two wires to the first two pins.
Nothing?
Go on.
When the Power Supply comes on you know you have the Power On switch pins (2)
Now go back through, but do not touch those pins again.
LED light blinks? = HarDDrive activity LED (Light)
LED light stays on? = Power On LED (Light)
Computer restarts? = Restart switch pins
7) To the left of the white long PCI slots, (There are 5 towards the bottom of the motherboard), are two small Black rectangular connectors. Each has 4 pins in it.
The one that has Audio, or CD, or CD-IN, is for the audio cable from the CD/DVD drive.
8) At the Top of the motherboard in-between the Processor socket, and black Ram Memory slots, is an Orangish connector with 3 pins. Should have CPU, or CPU_FAN next to it. This is where the Processor fan plugs in.
9) At the bottom/left, and below the two small black connectors with 4 pins in them, is an Orangish connector with 3 pins.
This should be for the computer case fan.
(SYS_FAN)
Additionally you may want to join this website, and ask them for the Front Panel header pinout, for your Abit BD711 motherboard,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
Finding information for an ABIT BD711 motherboard, is about as rare as finding hen's teeth.
I, and I'm sure 100's of people, would be in your debt, if you would post the Front panel header pinout for this motherboard.
Hope I have redeemed myself for the S.N.A.F.U. of the question asked in the Comment, lol!
Regards,
joecoolvette
Aug 30, 2012 | Computers & Internet
I need the wiring chart for a mcp61pm-am motherboard
Gateway Support > Gateway MCP61PM-AM motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rnv.shtml
Click on - Product Views
The area of contact pins on the motherboard, that the wires from the Front panel go to, is the Front panel header.
If you need the pinout for the Front Panel header, click on -
S- Front Panel Connector
Looking at the different colors on the Front Panel header, and matching pin numbering;
Pin 2 = Orange with Yellow + sign.
Pin 4 is solid Orange.
Pin 6 is Green.
Pin 8 is Green
There is NO Pin 10.
Pin 1 is Red with a Yellow + sign.
Pin 3 is solid Red
Pin 5 is Blue
Pin 7 is Blue
Pin 9 is solid Yellow.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for +5 Volts, and factory use.
D) Pins 2 and 4 are for the Power On LED. (Light)
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) There is No Pin 10. Just a blank spot. (Yellow)
Click on B - Processor Core Power, for the 4-pin ATX +12 Volt power cable connector, location on the motherboard.
[ Processor to the Top, Ram Memory slots to the Right;
the square white 4-socket hole connector, is straight over to the left, from the bottom left corner of the Processor socket ]
On the U - Intrusion Switch Connector?
I believe the style of switch used, is if it is open, then the computer will not work.
Therefore connect a small wire to those two pins.
(Same thing as the switch is Closed)
Need Molex female metal terminals?
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
Could I be wrong about how the switch works? Yes.
Could be the alternate style where the switch is open, and removing the computer case cover, closes it.
In this case do not connect a jumper wire.
All the other wiring connections are shown.
Have a specific question on the wiring? Post back in a Comment.
Regards,
joecoolvette
Aug 05, 2012 | Gateway Computers & Internet
Wiring diagram emachine T5246
OKAY!
There's what I'm talkin' about!
The model number.
The eMachines T5246 Desktop PC uses a
Foxconn/Winfast MCP61PM2MA motherboard.
[You stated Foxconn/Winfast. I got that. Just letting you know ]
Guess what?
So does the Gateway GT5476E Desktop PC,
Click on - Product Views - in the list.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
If you need a pinout for the Front Panel header, click on -
S - Front Panel connector
The Top row is numbered EVEN. Starting from the Left side going to the Right;
Pins 2, 4, 6, and 8. There is NO pin 10.
[Colors going from Left to Right;
Orange/Yellow, Orange, Green, Green ]
The Bottom row is numbered ODD.
Pins 1, 3, 5, 7, and 9.
Red/Yellow, Red, Blue, Blue, Yellow ]
B) Pins 5 and 7 are a Reset switch, IF a Reset switch is used.
C) Pin 9 is for 5 Volt power. This was used by the factory. It is N/C.
Not Connected.
Any other connector info you need? Post in a Comment.
Specifications,
http://support.gateway.com/s/PC/R/1009603/1009603sp2.shtml
1) Ram Memory:
Uses DDR2 Sdram at 667Megahertz. (667MHz)
Maximum TOTAL amount for the motherboard is 2GB. (2 GigaByte)
Maximum Amount for each Ram Memory slot is 1GB.
IF, you just have one ram memory module, make SURE it goes in ram memory slot 1. (DIMM 1)
That is the ram memory slot closest to the Processor.
Uses a SATA harddrive, and IDE (PATA) optical drive/s.
Does have two SATA connectors on the motherboard, so it can use ONE SATA optical drive.
On those SATA connectors on the motherboard,
http://support.gateway.com/s/MOTHERBD/Shared/4006200R/4006200Rmvr12.shtml
See the bottom SATA connector has SATA 1 next to it?
The SATA harddrive is supposed to be plugged into it.
However, the beauty of SATA is, NO MATTER WHAT SATA connector you plug into, BIOS will find that device.
Want to plug the SATA harddrive into SATA 1? No problem.
Want to plug the SATA optical drive(CD/DVD drive) into SATA 1?
No problem.
Want to plug the SATA harddrive into SATA 2? No problem.
Want to plug the SATA optical drive into SATA 2? No problem.
BIOS will find the device.
For additional questions please post in a Comment.\
Regards,
joecoolvette
Aug 02, 2012 | E-Machines Computers & Internet
Powers on but will not boot. No beep codes and no video.
firat check ur smps by shorting the green and black pin if not working chenge the smps if working look for the front pannel pins remove the pwsw pin and short it with a screwdriver if working means u have problem with the switch if not working there is problem with the motherboard also check the front pannal for correct power switch pin
Oct 14, 2010 | HP S3120N Pavilion Slimline Desktop...
I have a HIPRO HP-305 power supply. The green
the 4 pin connector is for cpu power. the hipro power supply are not very reliable.
Jun 14, 2017 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Flat Panel Monitor goes off two seconds after turning on the computer. It will not stay on. System is about five years old. could the monitor be bad?
Have you moved it recently? The monitor has a sensor that tells when the computer is on. Some times the computer settings tell the system to go in to standby mode and this will remove the signal that tells your monitor to stay on. Check your computer to see if it's running. Usually a green or yellow light on the machine will blink. If everything is good, check the pins in the cable from the CPU to the monitor. Check both sides. If a pin is bent or bad. replace the cable. Trying to straighten it might break off in the plug. Also, the video part of your computer may be bad. Try the monitor on a diffrent computer to see if it powers up.
Sep 04, 2008 | Sony Computers & Internet
Monitor remains in standby
turn the monitor off and the computer off. unplug it from the wall. let set for 10 sec. make sure you have it in the right place and in all the way. turn computer back on, then the monitor.
Dec 18, 2007 | X2Gen MG15VT 15" LCD Monitor
ASUS P5PE-VM Motherboard Logo
175 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
