Question about Hunter Fan 21894 Heater
Only one speed is working and the light doesn't turn on
  • 26 Answers
Is this new fan if so didnt wire correctly during instalation
Posted on May 10, 2010
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
04 Saturn vue compressor turns off when fan is set to 3 or 4
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing. I exchanged mine and it works like a charm now.
May 31, 2012 | 2002 Saturn VUE
My 2004 toyota celica's turn signal clicks extra fast when it's set to turn right. Also the front right signal light doesn't blink. Is the problem a broken bulb or a broken flasher relay?...
most likely a faulty relay is all... fix that and you'll be fine, they tend to speed up to let you know that they're on their way out.
Jul 12, 2011 | 2004 Toyota Celica
99 grand cherokee blower selector high position not working. Blows only level 1-3. replaced resistor, same problem.
automatic or manual a/c.
I'm going to assume manual but Auto is simular and i can give some direction if you have that as well.
There will be a black with tan wire at the blower resistor. This is the wire the HVAC control head grounds to turn the fan on high speed. With a test light hooked to power unplug the resistor, set the blower speed to high, turn the key to the run position. the test light should turn on when you probe the connector. If it doesn't pull the control head and back probe that same wire at the back of the control head with everything still plugged in. If the test light again does not illuminate the the control head is bad and not providing ground
If the test light does turn on when you probe the blower resistor connector plug the resistor back in. Turn the blower speed to the low setting. With your test light hooked to ground see if there is power on the black with tan wire. if there is turn the HVAC off and ground that wire with a jumper wire. the fan should run at high speed. If it doesn't you have a defective resistor.
Jul 01, 2011 | Jeep Grand Cherokee Cars & Trucks
I have 05 volvo vnl 670, isx cummins 450/500. keeps losing power, check engine ECU comes on knowbody seems to know what it is. they just keep replacing sensors.
I have a 2007 Volvo 670. The check vehicle ecu comes on. The fault code is MID 144 PID 191 FMI 5. THe truck won't go pass 1400 rpm, the speedometer doesn't work, the cruise doesn't work, the engine break doesn't work. I have to turn the truck off going down the road at highway speed for about 10 seconds and it'll go back to normal. Can anybody help?
Feb 16, 2010 | 2005 Volvo XC90
Light works, fan does not
Is it a multi speed fan and it doesn`t work on any speed?? Does the fan spin easily?? If not, the bearings have failed. If you can spin it easily, you`ll probably find that the ground wire in the coil has burned away in the connector or within the field coil windings themnselves. If it was just one of the coils, you would be missing one speed only but if it doesn`t work at all, it sounds like the grounding coil that`s failed. Ian
Aug 05, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Hunter Fan 21894 Heater Logo
104 people viewed this question
Top Hunter Fan Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Hunter Fan Heating and Cooling Expert? Answer questions, earn points and help others
