Question about Kenmore 23822 Top Load Washer
My washer stopped working how do i know its the coupler.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Without knowing the exact symptoms of the problem (does the motor run, can you smell anything, have you tried a different cycle etc) Here are two things to check (the most likely possibilities):
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on May 10, 2010
The Hot Point washing machine has stopped agitating but does spin-what is wrong?
The most usualthing wrong when the Hotpoint brand washer doesn't agaitate is a stripped agitater coupler,i don't see a model number in your question so i don't know if yours uses that coupler but its by far the leading thing wrong with that problem.
This youtube video will show ya how to replace that coupler,watch it and take off your agitator to see if that's the problem. http://www.youtube.com/watch?v=N26MCQKuXn0
GENE
Oct 13, 2011 | Hotpoint Washing Machines
Tip
Washing Machine Motor Coupling Repair
How do you tell if your washer motor coupler has gone bad? Motor couplers are used on "Whirlpool" direct-drive washing machines. In some Whirlpool or Whirlpool-made washing machines, the motor coupler connects the drive motor to the transmission. It operates under extreme conditions and stress. Mostly during start-up and stopping of the motor. The main symptom of a bad motor coupler in the Whirlpool made washing machines is that there is no agitation or spinning action, along with the sound of the motor running. Since the motor is running, but there is no connection to the transmission, the machine will not agitate or spin the clothes out. The motor will simply run, but nothing else happens. In this case, the coupler is most likely cracked. To replace the coupler in the Whirlpool made washer, you must first unplug the washer, remove the top console by either removing the screws or using a putty knife to unsnap the top clips, rotate the console back, pull the washer front off by tilting back,and set the cabinet aside. Remove the clips holding the pump and motor on. Remove the bolts holding the motor on. Inspect the coupler and replace with a coupler if necessary. Re-assemble the motor and pump assembly. Re-assemble the washer in reverse order of disassembly. Plug in and test by running the washer through it's paces.Here is a video on repairing the motor coupler.
on Oct 18, 2011 | Whirlpool Washing Machines
Machine wont spin. it tries but stops
Hello there and thank you for choosing fixya
This is a very common problem with top load machines
Direct Drive Washer Motor Coupler Problem Discussion coupler-exploded.gif couplers on direct drive washers fail almost more than any other part. When it fails it will prevent the washer from agitating and spinning but it will still drain as the pump is connected directly onto the motor. If the water is draining, the motor is functioning properl this is what it looks like
PLEASE LET ME KNOW IF YOURS IS DIFFERENT OK IF SO I CAN GET YOU THE RIGHT DIAGRAM tbirdfan1_13.gif
Aug 15, 2011 | Fisher and Paykel IWL12 Top Load Washer
I have a Kenmore series 70 washer that stopped working and when I turn it on it makes a loud clicking noise. Any suggestions on what this might be. Thanks!!
This is most likely a motor coupler. Set to spin see if it drains... If it drains then it is the motor coupler.
I hope this helps...If I can do anything else to help please let me know.
Mar 20, 2010 | Kenmore Washing Machines
MY KENMORE STACKABLE WASHER HAS STOP SPINNING AND SQUEAKED BEFORE OPEN THE FRONT AND SEE METAL SHREADS
Sounds like you might have a bad coupler. Most of these washers are built by whirlpool and use the "direct drive" system so there is no belt. instead a coupler transfers power from the motor to the transmission. see if the machine agitates, if it doesn't, you have a bad coupler. This is relatively easy fix, but does have some complicated parts to it... If you want to try to fix it yourself, let me know and I will post detailed repair instructions.
Dec 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
I have an older model Kenmore washer - stopped spinning and aggitating - I took the control panel off, how do I reach the belt?
Your problem may not be a belt some Whirlpool built Kenmore washers are direct drive and have a coupler instead of a belt. The coupler is located on top of the motor. It consists of three parts two with prongs and one with holes for each of the prongs. If this is broken or badly worn the washer will not agitate or spin. Good luck. Oh the drive coupler part number is 285753A.
Jan 08, 2009 | Washing Machines
KitchenAid Washer with no spin
Hi, so you have a kitchinaid washer that is not spinning and making a horrible noise.
More than likley you have a bad drive coupler. Which is located if you tip the unit back. not all the way, just enough to see the inerds of the washer. I usually prop it against the wall. There is your pump and attached to the pump is your motor. Between the motor and the transmission is your drive coupler. take the pump and motor off to gain acces to this part. there are 2 clips for the pump and 2 clips for the motor. usually 2 screws holding the clips for pump 2. Take the motor off and you will see the coupler. there is a grommet that goes between the 2 pieces sometimes that gets worn out and you will see black soot on the ground. That's a good indicationg that the coupler is the culprite
Jan 05, 2009 | KitchenAid KAWS850LE Top Load Washer
Kenmore 60 series grinds when spin starts
try taking the pump off the motor and see if the grinding noise stops could be something in your pump or a bad pump
Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
How do i get inside my washing machine?
sounds like your motor coupler has failed,remove the 2 screws on the top head panel one on each side,flip up the console and you will see 2 spring clips,remove them ,unplug the lip switch jack,open the lid and pull the case forward and your in,the coupler is behind the motor,remove water pump clips and motor clips,you can get the coupler from your local appliance parts store for $5,let me know how you do-mike
Oct 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool LSR6232J serial 4217141
If the washer fills, but fails to agitate or spin, the likely cause is a failed motor coupling. There is usually a loud rattling noise associated with a broken coupler. This may be the noise you hear. NOTE: The washer will STILL drain if the motor coupling is bad. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
If the washer fills, may or may not agitate, then stops right after filling, or just before the spin cycle*, you more than likely have a failed lid switch. NOTE: The washer will NOT drain with a defective lid switch. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
* These symptoms vary between models. The result is still the same, however, the washer generally stops at some point before the spin cycle and will not complete a wash load.
Read through both links and try to determine your symptoms. When it comes to lid switches, they sometimes come loose and only need to be retightened. Double check the mounting screws. In most cases, the clicking sound of the switch indicates the switch is good. However, I have found where the actual switch assembly was cracked or separated and made a similar sound, but the contacts were not engaging. Inspect the entire switch, if in doubt.
Motor Couplers allow for the Drive Motor to drive the transmission. This is the connecting link between the two. The coupler takes the punishment in order to protect the motor and transmission from damage. If you are in the habit of washing heavy loads (i.e., blankets, comforters, etc.) this can reduce the life of the coupler. A tell tale sign of a broken coupler is a pile of black filings under the washer. This is usually particles of the rubber bushing between the coupler halves. Another thing that happens is the center hole of the plastic coupler would round out and spin on the either motor or transmission shaft as the older couplers were made entirely of plastic. Replacement couplers (the part number I provided in the link) now have a steel grommet in the center of the plastic which prevents this from happening.
If you check both these possibilites and you still have problems, let me know. I'm trying to rule out the possibility of something more significant, like a transmission problem. Both of these parts are inexpensive (about $50 combined) and can be found at searspartsdirect.com. Just type in your model number in the search menu. The lid switch is located under the "Top and Cabinet" heading as item number 11 (part number 3949247). The Motor Coupling can be located under the "Brake/Clutch/Gearcase/Motor/Pump" heading as item number 13 (part number provided in the link). For comparative shopping, repairclinic.com also carries these parts, sometimes at a reduced price.
I hope this helps you. If you have questions, please let me know.
Aug 17, 2008 | Whirlpool LSR6232J Top Load Washer
Kenmore 23822 Top Load Washer Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
