Question about Sony EVC100 Hi8 VCR
Unit accepted cassette, won't eject
Unit accepted cassette. Hit play. It started to play just one second and stopped. Won't play rewind fast-forward or eject. What could the problem be? I tried turning it off and on. When you hit eject you can hear the gears moving but the tape remains inside.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Check the tips in my profile
Posted on Jul 18, 2010
Microcassette won't play but does rewind and fast forward
I have the 3 of these units at my office with the exact same problem. Turns out, with a little tinkering there is a simple fix.
Open up the unit (by unscrewing the two screws underneath) and look for a brass disk with a black rubber band around it that connects to a small tip. The rubber band should be either stretched, broken, or even melted. This is the problem. Over time the rubber band deteriorates which causes the unit to not play a tape (rewind and fast forward operate differently).
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and will be difficult to remove.
Hope this helps.
Apr 14, 2013 | Sony BM-815 / BM815 Micro Cassette...
WON'T PLAY BUT WILL REWIND AND FAST FORWARD
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and it will be difficult to remove.
Hope this helps.
Cassette is stuck. Cannot eject
Sounds like the tape is dragging and the spindle wont release it because of the torque on it. Can you rewind or fast forward to see if it releases?
Sep 09, 2012 | Samsung DVD-V4600 DVD Player/VCR
I put a tape in and it keeps flipping sides without playing and pops out and says Error. It even does it with a CD-Cassette Adapter. Before the Cln came up and I pressed on the eject button and that...
Cassette decks have sensors on the reels which tells the deck when the tape is at the end. When the reel stops the deck switches the direction of the tape and sometimes the position of the head(depending on the deck design). Most common problem is the tape is hard to turn, or the deck won't turn it ( deck thinks it's at the end, click, still won't turn, click, won't turn, click) you should fast forward and/or rewind your tapes from start to finish once in a while to keep them lined up(narrow spool/less friction), you shouldn't have to but it works. BUT,...your problem sounds like a slipping or broken belt/or dirt causing the problem. Take the deck out to have a look and clean the capstans(rubber rollers)belts,heads with alcohol and a Q-tip while your at it. Dirt's usually the main culprit and if you do have some other problem, cleaning it is always a win/win (It will also sound better clean)
Sep 20, 2011 | 1995 Buick Regal
Tascam 644 When I press play it won''t stay on play, it stops. It will rewind and fast forward but that too stops by itself.
Scott has a point. You need to determine what is causing the unit to stop and it could be a bad cam motor belt if it has one or the lack of take-up die to the bad idler or even a dead spot on the reel motor. The reel motor will work normally at high speeds due to inertia but at low speeds as are used in play the dead spot of the motor can become much more apparent.
Sep 17, 2010 | Tascam 122MKIII Single Dual Cassette Deck
Cassette does not eject
Either the tape is jamed round sound head, or the door is stuck with somthing like a handle of the case on side of camera, but sounds like tape stuck, run film backward a little (not forward) as more tape will get stuck in forward motion.
May 24, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Cassettes not rewinding
The heads could also just need a good cleaning, either professionally or using a head cleaner dv tape. It's important to remember to always use the same manufacturer dv tape all the time. Evidently, Sony and Panasonic do not mix well, and the lubricants from those two tapes combined will gum up the works. If you use Sony dv's, always use a Sony head cleaner and vice versa. Cold can also cause those lubricants to gum up. Sometimes simply fast forwarding will loosen things up.
Nov 25, 2007 | Video Cameras
Eats tapes
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
- Jim
Feb 20, 2007 | Symphonic WF803 DVD Player/VCR
Sony EVC100 Hi8 VCR Logo
479 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
