Question about Car Audio & Video
I am have lost the harness cable to plug to the
I am hve lost the harness cable to plug to the back of the unit. Hence if the pins are known then a new harness may be made. Audio radio/player wh-mp3/usb-970 from wharfedale international. Riaan
  • 21 Answers
If you open the case they usually have the pins marked on the board or you can just call the company i am sure they have some left over
Posted on May 10, 2010
Trouble shoot
I believe that's a Speed Sensor issue.
Diag:
1. Ensure mainshaft and countershaft speed sensors are installed properly. Disconnect mainshaft speed sensor harness connector. Using a DVOM, measure resistance between sensor terminals.
2. If resistance is not 400-600 ohms, replace mainshaft speed sensor. If resistance is 400-600 ohms, disconnect 25-pin PCM harness connector "B". Check for continuity between ground and 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
3. If continuity is present, repair short to ground in Red or White wire between PCM and mainshaft speed sensor. If continuity is not present, reconnect mainshaft speed sensor harness connector. Measure resistance between 25-pin PCM harness connector "B", terminals No. 15 (Red wire) and No. 14 (White wire).
4. If resistance is not 400-600 ohms, go to next step. If resistance is 400-600 ohms, go to DTC
P0720 (FLASH CODE 9) . Check for loose PCM harness connectors. Replace PCM with a
known-good unit if necessary.
5. Disconnect mainshaft speed sensor harness connector. Check Red wire for continuity between 25-pin PCM harness connector "B", terminal No. 15 and mainshaft speed sensor harness connector. If continuity is present, go to next step. If continuity is not present, repair open in Red wire between 25-pin PCM harness connector and mainshaft speed sensor
harness connector.
6. Check White wire for continuity between 25-pin PCM harness connector "B", terminal No. 14 and mainshaft speed sensor harness connector. If continuity is present, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary. If continuity is not present, repair open in White wire between 25-pin PCM harness connector and mainshaft speed sensor harness connector.
Mar 21, 2014 | 1998 Acura Integra
Car
Speed Sensor probably. Try:
harness connector.
Mar 21, 2014 | 1998 Acura Integra Type R
I HAVE A KENWOOD DNX9980HD 20 PIN HARNESS THAT CONNECTS TO THE KENWOOD HEAD UNIT. I ALSO HAVE AN AXXESS ASWC (STEERING WHEEL CONTROL MODULE)20 PIN HARNESS THAT CONNECTS TO THE AXXESS ASWC. THE AXXESS...
HI,
If you make a close verification on the back side of kenwood DNX9980HD 20 PIN HARNESS then you can see a Light Blue wire with Yellow stip ( BLUE/YELLOW) on it with a identification mark as "Remote cont". You have connect this wire to the Brown wire with white strip (BROWN/WHITE) from the 20 PIN HARNESS of AXXESS ASWC . There wil be a brown wire also from this 20 PIN HARNESS of AXXESS ASWC, leave it free insulated. It will not use with kenwood radios. You have to check for LIGHT BLUE with WHITE strip. There is also two other blue wires of which one with white strip. You hve to choose the light blue wire.
ok
Aug 06, 2011 | Car Audio & Video
Es lexus 300 p 1705...What is this?
DTC P1705 - NC2 (Direct Clutch Speed Sensor) Revolution Sensor Circuit malfunction or Direct Clutch Speed Sensor Output is 300 RPM or less with Vehicle at 20 MPH or more & with Park/Neutral Position Switch Off
Most probably you have an electrical fault causing the problem and attached is a diagnostic procedure. It could be 2 separate problems and after rectifying the P1705 only would you know it is single or 2. Repair manual shows right on top of transmission, black sensor with single bolt, 2 wire plug. P/N 89413-08020 list price $113.80
NOTE: DTC P1705 is set when PCM receives 2 gear position signals at the same time.
1. Turn ignition on. If any A/T gear position indicator lights remain illuminated when gear selector is moved from that gear, go to next step. If all A/T gear position indicator lights turn off when gear selector is moved from that gear, system is okay at this time.
2. Disconnect A/T gear position switch connector. If all A/T gear position switch indicators go out, replace A/T gear position switch. If all A/T gear position switch indicators do not go out, go to next step.
3. Reconnect A/T gear position switch connector. Shift through all gear positions except Reverse. Using a DVOM, measure voltage between 16-pin PCM harness connector "D", terminal No. 6 (Green/Red wire on 2.3CL or White wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires).
If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Red or White wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Red or White wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
4. Shift through all gear positions except Neutral and Park. Measure voltage between 16-pin PCM harness connector "D", terminal No. 13 (Blue/White wire on Accord or Light Green wire on 2.3CL and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Blue/White or Light Green wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Blue/White or Light Green wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
5. Shift through all gear positions except "D4". Measure voltage between 16-pin PCM harness connector "D", terminal No. 9 (Light Green/Black wire on 2.3CL or Yellow wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Light Green/Black or Yellow wire between 16-pin PCM harness connector "D" and A/T gear position switch. Repair as necessary. If Light Green/Black or Yellow wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
6. Shift through all gear positions except "D3". Measure voltage between 16-pin PCM harness connector "D", terminal No. 8 (Green/Blue wire on 2.3CL or Pink wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Blue or Pink wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Blue or Pink wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
7. Shift through all gear positions except "2". Measure voltage between 16-pin PCM harness connector "D", terminal No. 14 (Green/Yellow wire on 2.3CL or Blue wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, go to next step. If battery voltage is not present, check for a short in Green/Yellow or Blue wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Green/Yellow or Blue wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
8. Shift through all gear positions except "1". Measure voltage between 16-pin PCM harness connector "D", terminal No. 15 (Light Green/White wire on 2.3CL or Brown wire on Accord and Odyssey) and 25-pin PCM harness connector "B" terminals No. 20 or 22 (Brown/Black wires). If battery voltage is present, check for loose PCM harness connectors. Replace PCM with a known- good unit if necessary. If battery voltage is not present, check for a short in Light Green/White or Brown wire between 16-pin PCM harness connector "D" and A/T gear position indicator, or A/T gear position switch. Repair as necessary. If Light Green/White or Brown wire is okay, check for loose PCM harness connectors. Replace PCM with a known-good unit if necessary.
Hope helps.
May 24, 2011 | Lexus ES 300 Cars & Trucks
Need to know how to connect the 12 v dc power to the unit as I lost my power cable for radar 1000
As you look at the back of the display unit, the power plug has 7 connection posts.
Top left is pin 1 Bottom Right is pin 7
Pin 1 ..... + 12v
Pin 2 ..... - 12v
Pin 7 ..... Boat Ground
Rob
Oct 14, 2010 | JRC 1000 MKII Radar GPS Receiver
I want to replace the navigation unit in my 2002 camry with one from a 2007 camry. Most of the plugs on the back of the units are identical -- except for the black plug. The 2002 unit is a Fujitsu Ten...
You are not going to be able to perform this replacement scenario. Due to the fact that you are dealing with 2 different manufacturers, the wiring is different. There is no cable that is available to give you what you want.
Actually, there is a second component in the NAV system, that is what the unique cable plugs into. If you want to switch the NAVs , you need both components, and the correct wiring harness.
Hopefully, I have saved you a considerable amount of time and effort. Thanks for considering FIxYa fo advice.
Oct 28, 2009 | 2002 Toyota Camry
Alpine CDA 9855 plug configuration
an alpine dealer will have the ability to order a new harness for it.
there is only one made for that particular unit.
May 26, 2009 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
16 pin innerconnecting cable
i just went through that same problem, with the pins disengaging from the clip itself. if you reuse the same plug, it might come out again when its installed. my solution is just to get a new wire harness. i got my's for less then 20 bucks shipped to me.
Oct 13, 2008 | Eclipse (AVN7000) Car DVD Player
Kenwood 8pin harness
looking at back of 8 pin harnes, with wires facing you and tab facing up, left to right,
top
plugged into head unit i----------- i
______________________| |___________________________
| 1st pin, - blank | 2nd pin - Black wire | 3rd pin blank | 4th pin blank |
| 5th pin - yellow | 6th - pin blank | 7th pin- green| 8th blank |
Sep 27, 2008 | Kenwood Excelon DDX-7015 Car DVD Player
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
