Question about IBM ThinkPad 600E 2645 Notebook
I get disk read error when I try to boot it up.
    President:
  • 2,017 Answers
It is hard disk problem kindly take the backup of system if you can and replace the hard drive immediately.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on May 10, 2010
Intel D102GGc2 shows disk read error when detached sata dvd writer and xp boot when attached the same
Hi. if you're getting the same 'disk read error' when the DVD drive is attached and detached, then the error relates to the hard disk, that you're supposedly trying to install XP onto.
Ultimately you want the board to boot the DVD drive first. A quick change to the 'Boot priority' in the BIOS should sort it.
Apr 27, 2014 | Intel Computers & Internet
Disk read error
it is entirely possible that the boot sector is damaged. if this is the case you need to boot with the cd that came with the machine, or a recovery cd you've made, and load the recovery environment. once their load the command prompt. it should just be a button in vista or 7 and it will automatically load in xp. once loaded type "chkdsk c: /r" no quotes. let it run, this will check for bad sectors and should fix the issue. try and reboot, and let me know what happens. if you don't have the recovery cd's or installation media you can download msdart, which has the recovery console built in. i went ahead and uploaded msdart, download the version you think you need. https://rapidshare.com/files/2296685117/ERD50_x86_WinXP_SP3_blueforce.ziphttps://rapidshare.com/files/2914560443/ERD60_x64_WinVista_SP2_blueforce.zip https://rapidshare.com/files/267688033/ERD60_x86_WinVista_SP2_blueforce.ziphttps://rapidshare.com/files/1400985026/ERD65_x64_Win7_RTM_blueforce.ziphttps://rapidshare.com/files/3314839442/ERD65_x86_Win7_RTM_blueforce.zip
Jan 05, 2012 | Dell LATITUDE Computers & Internet
UNMOUNTABLE BOOT VOLUME ERROR ON GATEWAY GM5045E WITHOUT RECOVERY OR WINDOWS XP DISC.
An unmountable boot volume error suggests that you may have a hard disk failure or at least some corruption to the hard disk which the system uses to boot Windows XP.
To try to resolve this problem you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) then would need to be burnt on to a blank CD then the computer booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need a Windows install CD or other recovery CD media.
If HDAT2 finds a lot of unrecoverable errors then you should seriously consider replacing the drive - you should be able to recover data from the old drive using other tools on the Hiren's Boot CD, including booting the CD mini-XP environment and using the tools there too.
Dec 29, 2011 | Gateway GM5045E (RBGM5045E) PC Desktop
Pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
May 11, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Disk read error when booting
when a "disk read error" occurs, it's most probably the disk that crashed. you can try and repair the disk by booting from a bootable cd or USB-stick with diagnostic functions, such as UBCD4win, which can be downloaded for free. UBCD has many functions to check disks for consistency. if this does not help you, then i'm afraid that you will have to replace the disk with a new one. however, it may still be possible to retrieve data from the disk, if you connect it to a pc using a usb-to-ata bridge. the program i use for data retrieval is file scavenger.
Apr 21, 2010 | Gateway MT6451 Notebook
Not booting. "disk read error occurred"
This means you HDD is either corrupt or faulty, try downloading a copy of Hirens BCD to try to access the HDD (or use and external HDD enclosure) and if you can, put it back in the laptop, if not reformat it and reinstall windows.
Aug 11, 2009 | Acer TravelMate 4200 Notebook
Dell b130 internal system restoration failed
Incase you don't have any thing important on the computer try a factory restore. This will wipe out everthing and make the cmputer like new. To start it power off the laptop. Power it on and hold down ctrl and tap f11 severl times at the Dell logo screen. Try this q couple of times as it may not work the first time. If this does nothing you'll need the os cd (xp cd) tO repair or reinstall windows.
Aug 07, 2009 | Dell Computers & Internet
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jaddude
Jan 07, 2009 | Dell Latitude D600 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
