Jumper setting I have jumpers in the middle left of my board. I have three of them set to clock processor faster. Put a different processor in it. Not sure what other settings are. I am missing page 5 of my manual I downloaded, not sure if that page explains the settings other board time stamp jumper
  • Munganga C?lestin Jul 07, 2008
    - Leds are lighting normaly but no display
    - The device "Broadcom BCM5782KFB" is very hot
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
What is the board model post it then will try for solution
Posted on Mar 28, 2008
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Tip
MAKING YOUR COMPUTER OPERATE VERY FAST & SECURED THROUGH CPU OVERCLOCKING
NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN
drbrightirem.jpgOverclocking a processor means enabling it to operate above the manufacturer's specified frequency. Many internet sites provide instructions for overclocking. Processor manufacturers and many computer experts believe the slight gain in performance (only perceivable on CPU-intensive software) isn't worth the expense or considerable risk.
  • Get whatever tools you need: screwdriver, needle-nose pliers, motherboard manual, cooling hardware, etc.
  • 2 Find out whether your motherboard can be adjusted in the BIOS setup, with jumpers or not at all.
  • 3 Find out clock-speed limitations of the motherboard.
  • 4 Run all Windows and any third-party diagnostic applications you have. Fix all system problems.
  • 5 Make a complete backup of your system, documents and applications you don't have on CD-ROM. Do not overwrite these copies.
  • 6 If you have a BIOS-adjustable motherboard, make changes according to your motherboard manual, and skip to Step 15.
  • 7 Shut down computer.
  • 8 Leave computer plugged in to surge suppressor.
  • 9 Disconnect all peripherals from computer.
  • 10 Remove cover of chassis.
  • 11 Ground yourself to computer with any professional grounding equipment you have. Otherwise, ground yourself by touching a metal part of the chassis.
  • 12 If your motherboard has adjustable jumpers, locate the jumpers that control the CPU speed.
  • 13 Use needle-nose pliers to change jumper settings. Move jumpers to positions indicated in your motherboard manual for the clock speed you want. Check the internet for recommendations.
  • 14 Install a CPU heat sink, heat-sink compound, and a specialty cooling fan, if appropriate and possible.
  • 15 Put system back together, and reboot.
  • 16 If computer does not boot, and CPU still works, try lowering the clock speed. If that doesn't work, restore the original configuration.
  • 17 Check all functions, and run a CPU-intensive program.
  • NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN Tips & Warnings
    • CPUs have rated and maximum speeds. Exceeding the maximum speed is far more likely to cause problems than more conservative adjustments.
    • Overclocking an Intel processor explicitly voids its warranty. Other manufacturers have similar exclusions. Intel prevents overclocking of some CPUs by disabling higher multiplier settings.
    • Expect a shorter life for an overclocked processor, including the possibility of its immediate failure.
    • Prepare to deal with seemingly unrelated problems that can be caused by overclocking: destruction of other internal components, lost data, system and application crashes, and an inability to boot the system. Such problems can occur randomly or materialize well after you have altered your motherboard
    on Dec 06, 2010 | Computers & Internet
    I have a Syntax K7 SV400 motherboard. The board will post but will not install the os. The bios recognizes the cd drive and the hard drive. When I try to install Windows 2000 Pro the cd drive spins and I...
    Nothing, first try the disk in a working pc & see if it auto-runs in windows,if it does then try a different ribbon cable on the cd drive. If it doesn't then the disk is dirty or damaged. Also, not accusing you but windows 2000 is probably the most burned copy of windows around. If this is the case, go to whoever you got the disk from & tell them to re-burn it at 4x if possible but no faster than 6x, then the disk will work. As far as the bus speed is concerned(the jumpers), if the processor is a 100mhz, that's all the faster it will operate. Especially on older pentiums,which it sounds like you have. Now the processors will go to a slower speed, like 166 to 100. Keep in mind when switching cpu's you must set the jumper to the matching or slower speed or it will not post. Also, that speed is half what the actual clock is, meaning, 100 is 200,133 is 266, & 166 is 333 mhz. So if it's a socket 7 or 380 board, you can run an AMD or Cyrix cpu instead of the pentium & use whatever speed you'ld like because AMD products back then didn't lock the multipliers. Also on those older boards, some won't run certain ram speeds, like if the board has 100mhz ram it may not like 133 much. Ram wasn't very backward compatible back then.
    May 14, 2010 | Computers & Internet
    Mobo Jumper settings for BX pro PC100 Motherboard
    *********** board sounds like the same as a Fujitsu board.
    D1115
    moz-screenshot-1.pngthe user manual can be found at diplodocs
    It shows the jumper settings and board layout for a Fujitsu motherboard.
    I hope this helps. Have a great day
    Mar 18, 2010 | Computers & Internet
    How do you set a LG GSA-H10A DVD Drive as a Slave?
    on the drive there will be printed or stamped:
    MA, SL, CS (maybe in a different order.) Often there is a printed label, and often the re are tiny letters stamped either above or below the jumper pins.
    You need to place a jumper in the vertical position over 1 set of pins corresponding to the map above.
    ie if you want the drive to be a Master, jumper the vertical set marked (or indicated) as MA.
    If you want it to be Slave, jumper the SL set.
    If you want the drive to be set depending on where on the IDE ribbon cable is conected, connect the pins marked as CS.
    BIOS will then allocate the drive as either a master or slave.
    Using Internet Explorer but not Firefox, get the manual here:
    http://www.lg.com/uk/support/product/support-product-profile.jsp?customerModelCode=GSA-H10A&initialTab=warranty&targetPage=support-product-profile#
    Note the manual is a dejaVu document which will ask to load a viewer plug-in into Internet Explorer.
    Actually, inside that document, there is a drawing indicating that reading from left to right (ie from next to audio connector), the pins are: CS,SL, MA. So for example upper and lower pins at the extreme left are Cable Select, so you would jumper those 2 pins.
    Cheers,
    Steve
    May 16, 2009 | LG GSA-H10A Burner
    How can I understand the jumpering system of a motherboard
    Most motherboards dont have jumpers nowadays,( their all into sweatshirts) if they do, the usage of the jumper is described in the manual, & if u aint got one of them sqwint at the board, theres info on there., try manufacture website, but they do remove old manuals & drivers.
    Dispite my words, Always will a CMOS have the provision to be shorted
    Feb 19, 2009 | Intel Motherboard
    Hav K7T266 Pro2 motherboard, can not get it to go past turning on
    Lorna,
    to change bus to 133 MHz, you need to unlock the speed by setting a corresponding jumper on the board to assign busspeed by bios. After doing so, you need to clear CMOS and reboot. Next you'll have to set speed and multiplier in bios. Ideally: 900MHz = 100 x 9. Alternatively: 133 x 6.5 If that doesn't help...check if your RAM-modules are any good anymore. When RAM is not functioning, CPU-error code may be presented, since CPU cannot read/write to RAM, therefore not function. Let me know how this turns out.
    Kind regards,
    Stephan
    Jan 30, 2009 | MSI K7T266 Pro2 (MS 6380-060) Motherboard
    I accidentally changed my CPU clok frequency from 100 to 250 and now my computer won't boot?
    Ok I realize this is old and you may have given up by now or gotten it figured out, but I'm gonna try to help even with that being said, first of all I just recently had the same problem, this is a sure fire way to fix your issue,
    step one, open up your computer so that you have access to the motherboard,
    step two, find the system battery.
    step three, near the battery there should be a jumper, this will be a little plastic piece with metal connectors inside it, it should be slid onto two pins out of three available, move it over one space meaning if its on the left and middle move it to the right pin and middle pin, the three pin pole should say cmos right by it, or clear cmos.
    step four remove system battery, no need to worry this is just the memory for the cmos chip and it will revert it back to when the board was new, you can change the settings in your bios program back to what they were when it last worked,
    step five, making sure that your power cord is not hooked up to the computer in the back, (no power to computer) press and release your power button a few times, (this will drain the capacitors stored power)
    step six, walk away for about 20 minutes, just to make sure that clearing of cmos was a success,
    step seven, replace cmos battery.
    step eight, move jumper back to original possition.
    step nine apply power to the computer and boot up should be operatioinal again, you can then go back into your bios setting and change as wanted, however I would only overclock a little at a time as boards will only handle so much overclocking before they will freeze up, i would not go more than 200 mine froze at 200 so you may not even want to go there, Hope this helps.......
    May 18, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
    Jumper setting
    hello
    can you send me this page to check with you if you want
    AYADI
    Mar 14, 2008 | Iwill VX133 (MAVX133) Motherboard
    Jumper settings for old Compaq M/B to accept AMD K6 2 500
    that motherboard will not support that processor.sorry for the bad news!!!
    spiked
    Nov 17, 2007 | Computers & Internet
    Computers & Internet Logo
    97 people viewed this question
    David Payne
    David Payne
