Question about HP Pavilion dv2000t Notebook
Computer turns on with blue lights but no video or boot up
    President:
  • HP Master
  • 2,017 Answers
Remove the ram and clean it and fix it again and try to boot.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on May 10, 2010
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Nothing displays on the monitor when I turn on the computer
is there power to the monitor? is the monitor in standby(yellow light on monitor)? is the monitor on (green light on monitor)? how is the monitor connected to the computer, VGA (square fat cable, the end may be blue) or HDMI cable? When you turn on the computer is the power light on and HDD light flashing / showing activity? this would indicate that the computer is booting up. If you have power light and activity on the computer, I would unplug the data cable to the monitor. If the monitor is plugged in, i would press the power button to try and turn on the monitor / take it out of standby. If the monitor is ok you should see a message like "no signal" or "no input". This would tell you that the monitor is fine, but you may have a problem with the video card or video port on the motherboard. If you have no activity light on the on the computer, you may have a problem with the OS not booting up. You really didn't provide much detail on what has been done, but this is how I troubleshoot out in the field when working on something like this.
Oct 09, 2013 | Computers & Internet
Imed 1402 wont boot up
Your computer is not completely booting (it's failing the POST).
You need to identify the problem by disconnecting everything but the CPU, video, and memory. See if you get something displayed on the screen. If not, there is a good chance the problem is in the video card. Just to be sure, if you have 2 sticks of memory, take one out and try a boot. Then swap sticks.
The monitor is blinking yellow because it's not getting a video signal.
Feb 20, 2012 | Packard Bell Computers & Internet
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Aug 25, 2011 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
if ur system not boot,then after unstall tuneup,our system
Apr 03, 2010 | HP Pavilion dv2000t Notebook
Dell Inspiron Desktop PC won't start up
Hit FN at boot then let me know what it does
Jan 14, 2010 | Dell Inspiron 530 Desktop Computer
Mine similar except the blue light stays on ,monitor goes black
Have you tested the monitor? The monitor could be faulty. Try hooking up the computer to another monitor or another computer up to that monitor if possible. If the monitor is testing good then make sure all USB devices are disconnected and try to boot again. Then open the case and blow out any dust. Check the motherboard screws are tight. If the screws holding the motherboard to the case are loose it can cause a grounding issue. Then swap out the power supply with a working one and see if that fixes it. Disconnect hardware one at a time and re-boot. One of the devices...cd-rom,harddrive,ect could be faulty. Make sure the video card is fully seated and test the card in another working computer or test a working card in that computer. If it has on-board video then install a video card if available and see if it works. If none of these things work then the board is bad and needs replacement.
Sep 10, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
THE LAPTOP WILL NOT START PROPERLY
The solution to your problem is probably not the monitor, follow these steps:
1. Connect and boot your computer with 2 different monitors.
2. If it does'nt work with either of them the problem is from another computer component.
Posible Problems:
1. Your video card may be damaged or moved from it's slot.
2. Your proccessor may be damaged.
Posible solutions:
1. If you have computer hardware knowledge open the case
2. Remove the Video card.
3. Insert it back or insert another video card from a friend.(if it works with your friends card, obviously the video card is the problem)
4. Restart your computer and see if it works.
Now if it does'nt work after that you will have to replace your proccessor with one that works, from a friend, because you say your computer boots but if your monitor doesn't work you don't know for sure if it boots corectly.
The steps above are only for people with hardware knowledge, if that is not your case you should contact a computer service.
Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Feb 14, 2008 | Toshiba Satellite M30X Notebook
Computer does not turn on
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Getting into Windows Safe Mode To get into Windows 98 / ME safe mode, as the computer is booting press and ... safe mode as the computer is booting into Windows, turn off your computer.
POST troubleshooting steps. Turn on the computer and see if it beeps normally. If the computer has never ... If you're able to get the computer to boot with one or more of the sticks.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | IBM ThinkPad T40 2373 Notebook
HP Pavilion dv2000t Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
