Need a wiring diagram for capacitor on carrier ac model number 3BEN024310
  • 82 Answers
See page 2 here...the drawing section with H (hermetic compressor) F (fan) and C (common. -- http://www.docs.hvacpartners.com/idc/groups/public/documents/techlit/38en-1w.pdf
Posted on May 10, 2010
A\c is not working
Posted on May 06, 2013
2 Suggested Answers
  • 415 Answers
SOURCE: need a wiring diagram for capacitor on carrier ac
Here's your wiring diagram. :-)
Posted on Apr 02, 2010
What size capacitor in a Carrier Heat Pump 38yh036300
This is a three ton heatpump must likely it is a 35/5uf capacitor. But if you can read compressor tag it will tell you size it requires and also fan label will do some for it.you will need to ask for a dual capacitor from supply house make sure you pay close attention to hoe wires hook up so you can wire in new on before removing wires make sure you have high voltage turned off to unit.take pic with phone this will help when you rewire
Mar 10, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
Capacitor Wiring
I would think you have solvrd this by now but anyway I needed your model number of the unit outside more than the capacitor. Here is a simple diagram.so try to go by location and your colors. Should you have questions I will be here, Thanks Sea Breeze
More Carrier AC Wiring Diagrams
Jun 14, 2013 | Heating & Cooling
How do i connect the capacitor to my 38ckc024 ac unit. i have 2 yellow, 1 brown, 1 blue wire.
Here is a link to the wiring diagram for this unit
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya
Jul 05, 2011 | Carrier 38CKC024 Air Conditioner
Do no what wires go where on the capacitor for our carrier a/c unit
Some capacitor start motors have two brown leads (one with white stripe) that go to capacitor. Others wire into the start winding, if that is the case follow wiring diagram on the motor. Also if this is in an A/C unit follow the wiring diagram in the unit (usually on inside of cover)
Jul 17, 2010 | GE 18 Hp Capacitor Start Ac Motor 115...
Need wire diagram for 3207-121189
http://www.corp.carrier.com/www/v/index.jsp?vgnextoid=9d087afdef677010VgnVCM100000cb890b80RCRD
Search this web site. It has lots of manuals. It is Carrier site.
Hope this helps. Wiring diagrams are hard to find but I know they are there if you input enough of the right info.
Hope this helps and be patient while you search.
Nov 20, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
May 11, 2009 | Carrier 38CKC036 Air Conditioner
I am a ac tech, and i was working on a old carrier unit, wich had no schematic diagram. I need it in order to get the compressors going. if i give you a model # can you please provide one. roof top ac...
you aren't an ac tech number one but i shall overlook that . your question is llike will the sun come up in the north or the south tomorrow. obviously in the east as it has since the earth was created. anyway. all compressors since the beginning of time wire up the same .a wire commonly referred to as the common goes from the contactor to the compressor. usually black in color, hence the old coloqualism Blacks are common. the run wire is from the contactor to the run side of the run capacitor or from the contactor to the run connection on the compressor. hence the old slogan reds run when you point a gun at them. the only wire left is the start wire that come from the start capacitor and is usually yellow . hence the old saying blacks are common, reds run, and yellows are always starting something. very ethnic i know but thats how i was taught.now that the wirings correct check to see volts through contactor are correct and if one side of contactor is not feeding. if volts good then check capacitors with a cap checker. if all else looks good kill power and inspect compressor terminals at compressor. if burned off consider a termilock kit good luck..
Jul 19, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
626 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
