Question about Canon CanoScan 4400f MultiFunction Color Printer
My scanner is not scanning dark enough. I am scanning childrens' drawing with handwritten sentences. The sentences show very faintly. You can't read them. And the pictures are washed out looking. This scanner has been hooked up to a Dell running Windows 7. It seems to open into Picassa. This scanner was set up by my technicians. I have no book with suggestions. Can you tell me what settings to check or why this could be happening?
SOURCE: stop working
The covers are pretty easy to remove and access print catridges once you know how. Unscrew screws as they become available, 4 on back then two on each side then 4 on top. the balck plastic front bezels pop off as do the grey side panles. Try pulling out and up from the top. This can be a little tricky but I have not had to be too brazen and have not broken any panels. I am pretty sure that clicking sounds indicates broken parts and a trip to the repair shop. Basically the lock to keep the heads covered is not disengaging.
Posted on Feb 11, 2008
SOURCE: Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Posted on Apr 23, 2008
  • 44 Answers
SOURCE: stripes printed on every picture
go through your printers software in your start menu and clean the heads.
Posted on Aug 21, 2009
SOURCE: scanning negatives or dia positives produces
The problem was fixed after applying the calibration in the Scangear software delivered with the scanner.
It works fine now!
Posted on Nov 24, 2009
SOURCE: Canon Pixma MX850 won't scan - says 'set the pc to start scan'
Do you have more than one PC connected to the scanner? I have both a PC and a Mac connected to it, and I think my scanner is trying to connect to the Mac, which requires image capture software to be installed, rather than the PC. Don't know how to tell it to go to the PC, though...
Posted on Apr 10, 2010
Change scanned doc. to go to word not pdf
Depends on the document. If there are images and the type is handwritten. First scan the type as OCR scan so it scans only the text, a new window should appear for editing...nothings perfect...
Then scan the page with the images as a whole as doc file. Hope this helps, not all scanners are built the same, just have to read the instructions and features before buying.
Another way to scan to word is right from the MS Word Application. View the video to learn how.
Jan 13, 2015 | HP Deskjet 3510 e-All-in-One Printer
Why does my Canon Mf 8380 scan anything handwritten very faint and non legible
Is the handwriting black ink? Colours come out poorly on most scanners.
You need to increase the contrast when scanning handwriting.
Jul 07, 2014 | Canon imageCLASS Office Equipment &...
We have a Canon DR-9080C scanner. When scanning in Duplex on pages with data on both sides, the back side of each page is coming out unreadably faint. The header and any overall large blocks of black on...
The Canon DR 9080C is a 'contact' scanner. There is no optical lens, instead it uses a technology called "Contact Image Sensor' or CIS. The page to be scanned must be close to the glass for a proper image. This is achieved by a full-length rubber roller just above/below the scanning module. The roller is spring loaded and in case it gets stuck, there wont be enough pressure on the document to keep it close to the glass. ensure these rollers are moving smoothly and if required clean them. The rollers are on the opposite of the Scanning module.
S. Mohan, Chennai, India
Jul 29, 2011 | Canon DR-9080C Path-Through Scanner
What do you mean by (ocr) on an x2670
Optical character recognition, usually abbreviated to OCR, is the mechanical or electronic translation of scanned images of handwritten, typewritten or printed text into machine-encoded text.
These can be scanned in a word processor or other programs, then can be modified.It is software usually include with your Printer/Scanner
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Jan 11, 2011 | Lexmark X2670 All-In-One Printer
I've been scanning in drawings and the drawings each have some words at the bottom of the page. When I scan it, only the words appear to be recognized but not the drawing. It was working fine before, why...
may be you have written the words in darker ink and drawing might have been in pencil! scanner usually recognises dark areas and adjusts the picture based on it! make sure you darken the drawing as much as those words!
Oct 16, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
Bad contrast with scanner
Last things first: NO USER SERVICEABLE PARTS INSIDE.
That's the way HP does things. There are no rheostats or pots to adjust. It's all done electronically now, with chips and things.
You never said how it does with color or greyscale photos or drawings.
As for the RGB=(64,64,64), that's about right for the scan picture settings and the mixed (text and graphics) setting, and is particularly true for color picture settings. Have you tried using the setting for drawings (or line art), specifically greyscale drawings? Usually the greyscale lineart or drawing setting will render black text. You might also try scanning with the settings set for Text. If the greyscale drawing settings or greyscale text settings do not produce black text, try reinstalling your software and drivers.
If the contrast stays the same for all settings after reinstalling the software and drivers, and if it doesn't scan color and greyscale pictures correctly, then it sounds like your scanner is going bad.
As for the scans you've already done, you can darken the text by taking it into a photo editor, such as Paint Shop Pro or Photo Shop, and adjust the contrast and brightness to get the effect you desire.
Apr 18, 2009 | HP Scanjet 8250 Flatbed Scanner
Please help When I scan a document and save to PDF
Check you scanner settings. Increase the contrast/brightness. Try a good printed page. Clean the glass thoroughly
S. Mohan
Mar 24, 2009 | HP 5590 ScanJet Flatbed Scanner
Scans slides too dark.
maybe the slides are too dark, in other words, the pictures you took didn't have enough exposure therefore you it shows up dark.. You could always use photoshop or someother photo manipulation software to lighten the scan, same thing happens with my hp scanner with slide adapter, if it slides just show up dark, lightening it with software will help, unless it is unsaturated/shadows too dark, etc..
Hope this helps.
Nov 11, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Faint image on scans
REPLACE IN THIS ORDER.
CABEL(CHEAPEST)
IF THAT DOES NOT WORK
IT NEEDS A FORMATTER BOARD.
Jun 11, 2008 | HP LaserJet 3055 All-In-One Printer
Canon CanoScan 4400f MultiFunction Color Printer Logo
272 people viewed this question
old marine
old marine
