Question about Sewing Machines
Machine runs slow and won't speed up when pedal pushed down further
  • Anonymous Mar 24, 2014
    Works on very fast speed when pedal is only pushed down slightly
  • 92 Answers
Pedal needs attention, or replace. wcbotha@yahoo.com
Posted on May 12, 2010
My Bernina 730E is varying in speed even though I am pressing foot pedal to thr floor. The speed does not stay steady, somestimes running extremely slow in full speed mode. What is wrong?
it could be pedal control or the speed control unit on the motor as it is reasonably common for that machine
take it in for a service to ensure that other factors ( thread around bobbin shaft, fluff etc is not slowing the machine
Nov 01, 2016 | Bernina Sewing Machines
My Singer Sewing Machine runs too fast. Is there a way to slow it down?
what type of machine do you have. I have two that I operate with buttons and it has a little slide button to speed or slow down I don't know why it should run to fast with a foot pedal because you control the speed with your foot you may want to check to see if there is any trash that has gotten in the foot and somehow not allowing the foot to come back up
Sep 10, 2015 | Singer Sewing Machines
The foot pedal gets hot after a few minutes
It sounds as though the foot pedal is the problem. Maybe a shorted out wire in the actuator (rheostat). When your foot is off the pedal there should be no power running through it. If it has a short then it "thinks" the pedal is partially depressed to the slow position so runs at that speed. If the pedal can be removed/unplugged from the machine, do this and see if the machine stops running.
Sep 07, 2015 | Sewing Machines
Why when the Foot pedal is pushed all the way down does it click and only allow th machine to go at a very slow speed?
Check to see if there is something caught up in the foot pedal, like a scrap of fabric. That could be enough to prevent you from fully closing the pedal. Disconnect the pedal from the machine and from the wall. Holding the pedal in your hands, squeeze it closed as far as you can. Release. It should pop open. If it does not, then the pedal springs may be broken or worn out.
Aug 01, 2014 | PfaFF Tiptronic 2030
Sewing machine running slow
check the plug in to the outlet first
then check the power cord connection to the sewing machine
could be something wrong with the power cord
could also be something wrong with the motor
also could be a wiring problem
Jan 06, 2013 | Sewing Machines
Can not start at a slow speed with foot pedal need to now how to adjust start speed
THE FOOT PEDLE IS NOTHING BUT A REASTAT. A REASTAT IS A WIRE WRAPPED AROUND A CONDUCTOR THE WINDINGS START OUT FAR APART AND GET CLOSER TOGETHER THE FARTHER YOU PUSH THE PEDLE DOWN . THE FAR APART WIRES ARE THE SLOW SPEED THE CLOSER ONES ARE FASTER SPEED
THESE WIRES WILL WEAR OUT OVER TIME OR CORRODE OVER TIME AND CAUSE THIS PROBLEM. TRY SOME ELECTRICAL CONTACT CLEANER AND SPRAY THE FOOT PEDLE INSIDE ANY WHERE YOU CAN AND LET DRY. MOST CONTACT CLEANERS ARE NONE CONDUCTIVE AND DRY IN MINUTES
Aug 15, 2009 | Consew 206RB
No matter how hard I press down on the foot pedal my needle speed is super slow. The needle position indicator sometimes shows up when the needle is down and the needle continues it slow speed even when my...
is the machine easy to turn by handwheel? if not it may be seizing and needs servicing.
if the machine is free to turn by hand it sounds like your foot control is in need of repair or replacement - see a tech.
scott.
Jul 20, 2009 | PfaFF Sewing Machines
My machine has power, but foot pedal only makes needle go slowly
sounds like the contact in the foot peddle has failed try a new peddle
Jan 02, 2009 | Necchi 3101 Mechanical Sewing Machine
Sewing Machines Logo
211 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
