Question about Mitac Mio P550 GPS Receiver
MIO 720T CAN YOU TELL ME IF ITS POSSIBLE TO USE THE 720T WHILE IT IS PLUGGED INTO THE CIGARETTE LIGHTER IN THE CAR. THANK YOU SO MUCH SUE
    President:
  • 1,944 Answers
Yes you can use it when plugged in.
Posted on Mar 28, 2008
Used cigarette lighter to inflate tire, left inflater on for a long time now cigarette lighter doesn't work and car doesn't always start
It sounds like you might have drained your battery! When the car is running does the Cigarette lighter produce power? It should be working while the car is running. That would also explain why the car starts sporadically. Try leaving the car on for 40 minutes. That might charge the battery enough.
Jan 22, 2014 | 2001 Pontiac Grand Am
Is there an adapter that can be used on a car cigarette lighter for plugging in appliances?
Your best bet is to check on eBay for an adapter - the Asians make all sorts of stuff for cars now & i'm sure there is an adapter out there suited for your purposes. P.S. It may sound silly but are you sure you are using the actual cigarette lighter socket & Not a power outlet socket that many cars are now fitted with as standard?, my phone charger fits the cigarette socket but not the power outlet?, you never know?
Sep 13, 2012 | 2004 Kia Rio
My cigarette lighter won't work
Check the fuse. If the fuses are good, then it's possible that the cigarette lighter is unplugged. If the portion of the vehicle was disassembled, it may not have been reconnected during assembly.
Aug 01, 2012 | Interface Lincoln Zephyr 2006 06 W/nav...
Cigarette lighter stopped working
check your fuse box sometimes when this goes something else goes in the car ur radio etc..
Jan 24, 2010 | 1996 Chevrolet Cavalier
Where can find the Cigarette Lighter fuse
Cigarette lighter and electric plug do not work in 2007 Caliber after use of Magellan GPS - put in a new fuse - still doesn't work. Would anyone have a suggestion as to how to repair this problem? Thank you
Oct 02, 2009 | 2008 BMW 3 Series
Radio installed into the car. When radio is set into the receiver, there is no response. Light will not light up.
is it plugged into the cigarette lighter? or is it hardwired. If it is plugged into the cigarette lighter, check the fuse for "CIG" in the Main Fuse panel, mostlikely it is blown. Replace. 15AMPS
Aug 26, 2009 | XM Radio (XMP6000)
Zumo 450 Power Through Cigarette Lighter
You should be, Check to make sure the fuse isnt blown on either the cigarette lighter plug or in the plug that has the wires coming out of it.
Nov 24, 2008 | Garmin zumo 550 GPS Receiver
I have a Mio C220 that does not power on even though battery is charged. Will not work off of battery or plugged into cigarette lighter. Bought it in Nov. 07 but have lost box, receipt, software, and all...
Mio wants people to know, especially the folks who recently bought the Mio C220, that you need to put the SD card in the unit for it to work. The Mio C220 has the maps on the SD Card, and it seems that not everyone knows to put the SD card in the unit before firing it up. No SD card means no working GPS.
Mio Says:
1. Before you power on your C220, insert the SD Card firmly into the slot on the right side of the device
2. Once the SD card has been inserted into the device, power on your C220 by pressing and holding the power button for 10 seconds.
For More information check out the Mio GPS Page on the SD Card for Mio C220
Jun 21, 2008 | GPS
How to recharge the unit
you can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Dec 25, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Mitac Mio  P550 GPS Receiver Logo
82 people viewed this question
Top Mitac GPS Experts
Greg Cann
Greg Cann
TO Lady
Are you a Mitac GPS Expert? Answer questions, earn points and help others
