Question about U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613)
I forgot my custom ip address of us robotics so now how i can connect to it
  • 68 Answers
Go to your LAN connection and double click it -> click details -> see the default gateway thats it .
Posted on May 10, 2010
Release ip address. I want to be seen on the internet with a different IP address. When I plug the cable modem directly into my computer I can release and renew and get a new IP with the network card, this...
The easiest way to release and renew your IP with a router that doesn't have that feature is to unplug the modem (not the router) for a few minutes - overnight while your sleeping to be sure.
May 23, 2011 | U.S. Robotics MAXg USR5461 Router
Good evening, I have a router 9107 us-robotics, in which the cable is connected to the internet. On the other hand I have a wireless router d-link dsl-G604T, connected to the router us-robotics. I did port...
You cannot have two routers connected, or daisy-chained, together. The internal workings of both devices are the same. The "internet" connection going into the us-robotics works fine, but the us-robitics thinks that the other devices connected to it are computers. So the us-robotics assigns an internal IP address (192.x.x.x or 172.x.x.x) to the dlink. The dlink then is connected to the computer and assigns the same type of IP address through DHCP. This causes havoc on home networks.
So, thinking about it, the dlink thinks that the connection it is getting from the WAN side (or from the us-robotics) is the internet and forwards you that page. Port forwarding only forwards data on specific port but is not true service.
If you are trying to get a wireless signal and that is the reason for the additional d-link, the you may want to look at a Wireless Switch, rather then a Wireless Router. The difference is that the Switch will take commands from the us-robotics, while the router will try to think for itself.
Feb 28, 2011 | Computers & Internet
I forgot my password
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Jan 19, 2011 | U.S. Robotics MAXg USR5441 802.11b/g...
How do i change my password.us robotics wireless maxg router
ACCESS THE DEVICE SETTING THRU IP ADDRESS ON BOTTOM OF DEVICE IS USUALLY AN IP TYPE IN EXPLORER ADDRESS SPACE THE IP ADDRESS .. EXAMPLE \\199.210.01 .01
OK THERE WILL BE THE NOMENCLATURE PAGE WITH OPTIONS TO CHANGE PASSWORD
Jun 15, 2010 | U.S. Robotics MAXg USR5461 (738168036790)...
I cannot access my modem. When I type in the IP address 192.168.100.1 it says windows cannot find the address, even though I have an ethernet connection
Linksys routers, for example, use 192.168.1.1 for their internal IP address. D-Link and Netgear routers typically use 192.168.0.1. Some US Robotics routers use 192.168.123.254, and some SMC routers use 192.168.2.1. No matter the brand of router, its default internal IP address should be provided in documentation.
Jun 15, 2010 | Arris SURFboard SBG900 (49402201900) Modem
The default address for that make and model is: http://192.168.2.1
If you changed the default address, you can perform a factory restore to reset the router.
To restore the factory default settings is to press in and hold the RESET button on the Wireless MAXg Router for between five and ten seconds.
You will lose all of your personal settings if you restore the factory default settings.
Mar 20, 2010 | U.S. Robotics USRobotics USR5461 Wireless...
How to find router fully ip address?
if your PC still working and connecting to the internet thru this router, then open command prmpt, enter "ipconfig" and read the ip address of the default gateway. at most simple home networks, that is your router.
Jun 06, 2009 | EnGenius EOC-3220+ (EOC3220PLUS)
My US Robotics USR8054 Wireless Modem stopped working
DHCP may not be working on the router. What IP address does the router give your computers? It should be a 192.168.123.xxx address as default. If you are not getting an IP, then you will have to set a static IP in the range above to connect to the router setup webpage and reenable DHCP.
Mar 07, 2009 | U.S. Robotics USR8054 Wireless Router
RG54SE II
In your wireless router,U want to configure the ip adress of internet,may R u static ip R dynamic ip address,
1. Statis ip customer means, configure the static ip address in your wireless router,
2. Dynamic ip customer means, configure the ip address of the ADSl modem ip.
May 20, 2008 | MSI Wireless-G RG54G3 Router
Modem and router sharing IP address
You will need to disconnect the modem from the router.
Then you will need to connect your computer to the router using an ethernet cable. (plugging into one of the LAN ports)
Next you need to log into the router control panel and change the IP address there. If your modem is giving out IP addresses like 192.168.0.5 then you will need to change the 3rd octet on the router to an IP address like this: 192.168.47.1
Jan 05, 2008 | Computers & Internet
U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613) Logo
101 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
