Wireless problems. I have an asus f9s notebook. I bought this in Malaysia. Now I am in Australia, and am not able to get wireless, even though i can connect to a wireless hotspot. I have checked my driver, and this is working fine. i am not sure what to do. i am not sure if i have an antivirus installed before i bought this (at a computer shop). How can i disable this if i have it?
  • robstabobsta Mar 29, 2008
    s4u311, and cropp, thanks. i will try these suggestions out, and get back to u.
    tkw2201, this is the added info. I am travelling, so i generally try to connect to hotspots at campsites/hotels/cafes. The problem is that, when i try to sign up, internet explorer is rerouted to another site, which i don't understand!! therefore, i cannot get onto the sign up page!!! I have asked at these places if i need to pay first, or if there is a password, and there is none. I thought these were free for customers?
    Secondly, i have a 90 day trial for the norton antivirus, but because i cannot connect to the internet, i cannot sign up!! I had set up windows defender, and there is a firewall, but i am not sure if this is causing the problem!!
    so there you have it. I hope that this helps, as i am desperate to use the internet on my own laptop,
    Thaks a million for all your help.
  • Anonymous May 11, 2010
    not sure what the problem is,
    you have a wireless adapter in the laptop and can connect to a hotspot,
    have you paid for the privelage to use the hotspot with a credit card?
    are you trying to use it at home via a wireless modem/router?
    why would you want to disable the virus protection? unless its norton's, but then you would need another package.
    more accurate information would be help full
    thanks
    Terry
    Sergeant:
  • 349 Answers
Ok well their are not many places you can get free hot spots,
you say that a site opens up in the explorer that you did not ask for ,maybe you have some spy ware on your laptop directing you to their site,even though your not connected, and this is stopping you getting connected in the first place.
run anti virus and anti spy ware software.
hope this is of help,
Terry
Posted on Apr 01, 2008
    Guru:
  • 377 Answers
Hi dear
try to make your firewall off,
or try this
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
  9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-entwireless problems. - fccfda9.jpg
  11. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connewireless problems. - 34b0a7b.jpgt should work.
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Posted on Mar 28, 2008
  • 813 Answers
Remove your anti virous & try to connect is happen by firewall sattings if u remove your antivirous & ur firewalll setting
your wireless working in a proper,
tay this
& thnks to using fixya
SOURCE:
Asus f9s , laptop will boot with sound and backlight but no image at all , does any one no if its to do with the nvidia chipset only causing the fault and not any other chip on the motherboard , thanks .
nvidia 8XXXseries on any laptop fails.belive me i repaired sony, asus, hp, packard bel,.........so it's the videochip.needs reflow, reballing(temporary!!!!!!)or another laptop solves the problem...
Aug 07, 2013 | Computers & Internet
Bought an Asus K55VJ-SX218H notebook for college & can't connect to their wireless Internet. We've also tried connecting using cable with no luck. It connects to my home wireless but not t
You need to contact the college's IT support to get the college's wireless router configuration settings so you can configure your laptop's wireless with these settings.
Mar 04, 2013 | ASUS Computers & Internet
I have an ebook notebook 7 but it wont load the internet even though it is saying im connected with a strong signal. any advice?
just because you are connected to a wireless network does not necessarily mean that you can access the internet. Can you access the internet from another wireless device using the same wireless network. If you can then the problem lies with whatever browser you are using and maybe your firewall. Please reply with what windows version you are using and what browser and firewall is on your ebook
Mar 20, 2011 | ASUS Eee PC 1000HE Netbook
Will not connect to internet even though it recognises the router
Hi
Have you entered your wireless network password?
See page 5 on how to "enter WEP/WPA" in the manual available online at :
http://dlcdnet.asus.com/pub/ASUS/DigitalHome/Internet_Radio/AIR/q3195_air_qsg_content.pdf
Thanks
Isaac
Jan 31, 2011 | ASUS Air Notebook
Where to buy a F5RL motherboard in Australia
Did you do a Google or eBay search for the motherboard.
Fellow oz in QLD (not so sunny at the moment).
Feb 10, 2010 | ASUS F5RL-X2 Notebook
BIOS Password Problem
The only thing that a bios update would do would update the bio your password info should stay the same maybe your not typing it right try typing with or without cap lock
Mar 10, 2009 | ASUS F9S-B1 Intel Core 2 Duo T7500 2.20GHz...
Locating the batter AAA 1.2V in Malaysia
Actually in Malaysia 1.2V AAA batteries available in most gadget stores and even in supermarkets. You may also get on local eBay website. www.ebay.com.my
Jan 07, 2009 | Panasonic KX-TG1033S Cordless Phone
Help!!!! i have just bought my kids an asus eec pc and cant get it to connect to my wireless network. Any one help????
If ya'll bought the Linux version don't even get upset about it, send it back ASAP. There is no fix. I have been researching the wireless bug on ASUS Linux Xandros for months...it's not the computer its the software and there is no fix at this time.
Dec 26, 2008 | ASUS Eee 4G Notebook
I do not find driver fo Asus V7100 pro
This is the driver for windows XP / 2k
http://dlsvr01.asus.com/pub/ASUS/vga/nVidia/Released_Drv/nv5655_2kXP.zip
and this one works for ME / 98SE
http://dlsvr01.asus.com/pub/ASUS/vga/nVidia/Released_Drv/nv5655_98SEME.zip
Nov 24, 2008 | ASUS V7100 Pro (64 MB) Graphic Card
Asus A6 laptop
Try clicking on Start->Run Then type in: services.msc and click ok. When the window opens, scroll down to the bottom where you should see Wireless Zero Configuration. Make sure this service is started. If not, start it, then go and try your wireless again. If it IS on... then you may want to try reinstalling your wireless card/adapter.
When you go to Network Connections, right click on the wireless connection and on the Advanced tab, make sure the box is checked to let Windows Configure Your Wireless Connection.
Jan 28, 2008 | ASUS A6U Notebook
Open Questions:
Computers & Internet Logo
Ekse
Alun Cox
