Question about Sony STR-DE595 5-Channel Amplifier
Can I plug an Ipod directly in to this amp? - Sony STR-DE595 5-Channel Amplifier
  • Sony Master
  • 5,384 Answers
You can plug the I-Pod into the amp by using one of these cables. It fits into the headphone socket of the I-Pod and the two RCA's go into an aux imput (perhaps the front one?).
Posted on May 11, 2010
I have a denon ipod dock and a harman/kardon receiver. Can I connect the dock to the receiver?
To plug the dock into the receiver to supply power and interface with the iPod you would have to have one with a built in iPod. Most receivers will not do that, the most common way to connect an iPod to a receiver is using a 3.5mm to RCA cable. You don't even need the dock to do this, you can plug the iPod directly in. You can find this cable at most electronics shops if you don't want to buy online, like Best Buy or Radioshack.
Make sure you connect the white and the red end of the RCA cable to the correct sockets on your receiver, and the small 3.5mm jack into the iPod or the iPod dock, you have to turn the iPod volume up and select the corresponding input on your receiver. If you plugged the 2 RCA jacks (white & red) into the socket labeled "AUX" or "Video 1" you have to select "AUX" or "Video 1" in order to hear the sound.
Jun 18, 2010 | Harman Kardon Audio Players & Recorders
My ipod 30g dont work only show www.apple technical support
The problem *might* be solved by resetting or restoring your iPod. Otherwise, you'll probably need to take the iPod into an Apple store to see what's wrong.
Here's how to reset your iPod:
  1. Turn on the iPod, and make sure it's unlocked (no red is showing by the switch at the top)
  2. Press the "menu" button (at the top of the circle) and the "select" button (middle of the circle) at the same time and hold them down for at least 10 seconds, until you see the Apple logo on the screen
Here's how to restore your iPod:
NOTE: this will delete all music, etc. from your iPod
  1. Plug your iPod into the computer
  2. Open iTunes
  3. Click on "Restore" (on the "Summary" tab)
  4. Follow the onscreen instructions.
You'll need to resync all your music etc. to get it back on the iPod after it's been restored.
If your iPod does not show up in iTunes, use these directions to put it into disk mode: http://support.apple.com/kb/HT1363
Then try the restore directions again.
Hope this helps!
May 09, 2010 | Apple iPod MA446LL/A MP3 Player
You can plug an i-pod into any amp! All you need is a 3.5mm plug to two RCA plugs. The 3.5 plug goes into the headphone socket of the i-pod and the RCA's into an aux imput on the amp.
Mar 17, 2010 | Sony STR-DE595 5-Channel Amplifier
How can I view my ipod pics on my TV screen
1. OK on your iPod and click "Videos" from the main menu. Click on "Video Settings" and then switch the "TV Out" function to "On" by clicking on it.
Plug the iPod audio video cable input to the correct iPod plug-in. The cable's input varies from cable to cable but will either plug into the headphone jack or the power output.
Plug the other end of the audio video cable into the television's video output. The cable has three audio video plug-ins colored red, yellow and white. Plug them into the TV's corresponding inputs.
Turn on the television and change the input to the same one you plugged the iPod into.
Select the video you'd like to play on your iPod. The iPod's video and audio will be redirected to your television.
Jan 24, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
IPod won't sync.
1. Try another USB cord or USB cable.
2. Restrart your computer for a try.
3. Reset or restore your iPod for a try, this way can fix many general iPod problems.
4. Download and install the latest version fo iTunes for a try.
5. You may try this iPod transfer, it's a nice iTunes alternative that can help you upload music and video to iPod, I always use it to sync my iPod when my iTunes can't recognize my iPod, it's easy to use and works pretty well.
http://www.daniusoft.com/ipod-music-transfer.html
Jan 04, 2010 | Apple iPod MA446LL/A MP3 Player
I have a 30 gb ipod video, the screen says connect to computer use itunes to restore ipod. The problem is the original computer with all my music had its hard drive crash, and i havent backed up my ipod on...
probably not... but you can try these:
while the iPod is plugged in, toggle the hold switch on and off (slide it to hold, then slide it back again), then press and hold the "menu" button and the center button until you see the apple logo on the screen, if this doesn't fix it... try a different USB port (use one on the computer itself, not your keyboard or hub), if this doesn't work... restart your computer and make sure you have the latest updates for your computer, if this doesn't work... call apple at this link:
http://www.apple.com/support/expert
Nov 25, 2009 | Apple iPod MA446LL/A MP3 Player
My computer won't recognize my ipod. I there
You haven't given a lot of info to go on here, but this is one possibility.
Ipod usually wants to be drive F. Unplug your Ipod from the computer. Follow these directions below. If you have something in your system assigned to F then reassign the letter. After you are done, reconnect the Ipod and see if that works. (These directions assume XP operating system)
  1. Log on as Administrator or as a member of the Administrators group.
  2. Click Start, click Control Panel, and then click Performance and Maintenance.
  3. Click Administrative Tools, double-click Computer Management, and then click Disk Management in the left pane.
  4. Right-click the drive, the drive that is labeled F and then click Change Drive Letter and Paths.
  5. Click Change.
  6. Click Assign the following drive letter if it is not already selected, click the drive letter that you want to use, and then click OK.
  7. Click Yes when you are prompted to confirm the drive letter change.
Oct 04, 2009 | Apple iPod nano
Power in amp but no sound to speakers
you need to make sure youre getting a signal from the source, RCA's I suppose. Check for loose connections or broken wires. make sure to have 12v+ on power and remote inputs at amp...proper ground too. Lastly, check your ohm loads at speakers, maybe one is about dead. make sure crossover settings are correct.
good luck!
Sep 17, 2009 | Pyle BZDBP212 Car Subwoofer
No bass and muffled quiet sound... help
No, to make this connection correctly you need a pre amp. you can find them online for about 25 and up. your ipod does not have a pre amp section and is sending a very weak signal to your amplifier. A pre amp is the fix. Hope this helps
Jun 23, 2009 | Alesis RA-150 Amplifier
I have the panasonic cq-c8303u radio and i would like to hook up the ipod to it. any tips?
You need to get the Direct Cable for iPod® (CA-DC300U) from panasonic. This allows you to plug in and control your ipod from your headunit. There is also the expansion module (CY-EM100U), however I am not sure if this is necessary if you have the Direct Cable. The Direct Cable might plug directly into the back of the headunit without the need for the expansion module. Check with the company before purchasing one or both. If the direct cable requires the expansion module, then get both, however, I think the direct cable works independent from the expansion module. Again, contact the company about this. The expansion module also lets you plug your ipod as well as other devices into your headunit, however I don't think it allows you to control them via the unit. I think if you want to control the ipod from your headunit, you just need the Direct Cable for Ipod®.
Mar 23, 2009 | Panasonic CQ-C8303U CD Player
Sony STR-DE595 5-Channel Amplifier Logo
153 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
