Question about HP Compaq ProLiant 800 Server
System halt while booting - HP Compaq ProLiant 800 Server
3 Suggested Answers
luis356
  • 53 Answers
SOURCE: corruption exists!System halted?
you have a bad memory stick.
Posted on Jun 03, 2009
info2u
  • 596 Answers
SOURCE: processor in incorrect slot system halted error
You don't see this often but when you do it means your cpu is not in cpu slot 1. (Usually you are also running 1 processor in your server.) Just move the cpu to the other slot, power on your server and you should be good to go. Be sure to only touch the edge of the cpu and not any of the chips in the middle.
Good Luck
C2Solutions
Posted on Mar 05, 2010
Lenovo a328 system halted
Try safe mode with networking OR last known good configuration through Advanced Boot options (press f8 at boot to get there).
could be virus / spyware / junk related issue, run a scan with the antivirus, check the registry, unwanted programs, run a cleanup and clean msconfig too.
call 1-877-805-1027 for expert help
Oct 24, 2015 | Lenovo Computers & Internet
Windows XP sp3 not booting Error system halted
Is your First Boot Device in BIOS is Set to Hard Drive? IF not then Just Change it Hard Drive.
Aug 11, 2012 | Intel Computers & Internet
Fatal Error, Chasis Entruded, System halted appear at first time boot up. and if I again restart, sometime it works continuously till I shut down the PC and if I boot up again some times it works or some...
Good day try to remove the memory card, sound card and video card, clean the copper leads using an eraser and try to check all the connectors specially the hard disc, do this and it will resolve the problem, best regards.
Aug 19, 2011 | ASUS P5PE-VM Motherboard
Dell Dimensions 4400 boot failed: system halted
reload the windows, it missing the loading operating files.
Jul 06, 2009 | Dell Dimension 4400 PC Desktop
I get the message "system, halted check cable"
Open your System unit and make sure all components are properly connected. your hard Disk Cable might be loose or damaged etc...
Jul 05, 2009 | Gateway 700 XL PC Desktop
Boot failure- system halted was my problem , kindly help me boot failure- system halted
Yours is purely an operating system and /or hard disk problem ok. If you have the Recovery cd, try running it if not you will have to reformat your hard disk and re-install the operting system. It's a painful thing to lose some very important files. I suppose too that you must have a backup of your vital files. So go on with the reformation and your will come back alive ok. Good luck
May 26, 2009 | Gateway Essential 400 PC Desktop
Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
Mar 20, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
Error message
Open Your system and there is a Battery which looks like a Coin. that is CMOS Battery (CR2032) Change that battery and then Reboot your system and try go to BIOS menu with DEL , F11 , F1 or F2. Either of these Buttons can Work.
This will resolve your issue
Nov 26, 2008 | Computers & Internet
Hp dv2000 error code 104- unsupported wireless network device detected system halted
The user has not described the operating system in use.
However this problem generally occurs due to incompartible hardware. in this case it is ever stated. ie. Network interface Device. I suggest you disconnect the Network devices including cables, then try to reboot.
If not descibe how far the booting process gets and type of network hardware connected and operating system to your system
Heruless
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Sys Init Error - Halt - But I want it to skip All Errors
darian69, windows did not setup correctly. Double check all data cables & power cable connections. (Tight fits).
(This is not an uncommon error). Please download the manufactures drive utility software for a bootable floppy disk or bootable cdrom disk. Test/check & setup the drive, (formatt). Than install windows. Once installed, turn on windows firwall & install nic driver software. Run windows update. Check for hardware updates & install. This should fix the system halt.
Please let me know if this stopped the error message.
Mike
Apr 18, 2008 | Tyan Toledo i3010W (S5197G2NR TOLEDO...
HP Compaq ProLiant 800 Server Logo
156 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
