The machine starts out fine but when it is supposed to spin it does't always do so. If you bang on the top of the machine where the lid switch is it will then start the spin cycle. Estate Heavy Duty/ Super Capacity 2 Speed.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
Posted on May 10, 2010
Have a GE washer that has small, medium, large, and super load size. It's a top loader. When machine starts wash cycle, it bangs on the cotton and permanent press setting?
Probably out of balance, if in the spin cycle. If not, a "bang" corresponding with agitator reverse, you may have a transmission problem. Override open lid off switch with a pencil or used toothbrush in the small hole upper left location just under lid when closed so you can see the agitator action. If so run it till it breaks. Then replace. Otherwise, call your friendly appliance repairman and ask for a repair estimate first. If it is an ageing machine consider repair cost versis a lightly used one or new.
Oct 30, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
I have the model LSR7233B with the same problem as
What I would do is unplug the lid switch assembly from the harness and jump out the quick connect to see if that washer will run fine. Then replace the lid switch assembly. To do that you is gonna have to flip up the control panel. I have repair photos HERE
Feb 14, 2010 | Washing Machines
My kenmore washing machine will not enter into the last cycle and will not rinse out. Silly as it may seem banging on top of the machine with the lid closed sometimes gets the machine to start again and...
Hi, check lid switch, open lid, check carefully locate lid switch, or lift top of machine, get access to lid switch, could be broken or faulty, also check all wiring harnesses, there could be loose connection, check timer connections, all other connection, but first check your lid switch. when you lift lid, look for small slot, on machine around area lid covers, use something to press and release lid switch, preferable something non conductive, i use a small screwdriver. it could be just broken / faulty lid switch, or loose connection, you can check yourself, or let someone check for you, that's no big deal, always switch off power, before doing any repairs. good luck.
Aug 13, 2009 | Washing Machines
Washer works fine till it gets to the spin cycle, makes very loud bang bang bang like it's going to blow up, did find two brass pins under the balance plates in a small cup that it droped down into, lined...
those are shipping pins pull them back out,check the tub springs,also the triangle the tub sits on has 3 pads it rides on check them also,somebody has bypassed the lid switch,it's ok,let me know what you find-mike
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Won't agitate!
does your model have a drive coupling its between the motor and gearcase,when they brake the machine wont wash or spin and makes a wierd noise
Jan 12, 2008 | Whirlpool LSR6232J Top Load Washer
Maytag Washer won't switch from rinse to spin
You have a bad lid switch. Before I retired Maytag had a lid switch kit that improved the switch that was originally in it. The problem would usually present itself if a person accidentally dropped the lid with a bang which would put the lid switch out of adjustment.
Jan 08, 2007 | Zanussi ZJD1219 Front Load Washer / Dryer
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
