Start my notebook averatec 2300
I have an Averatec 2300 laptop and with no noticeable reason it does not start, do you know what the problem could be? Do you have any history in failures like that? Did the microprocessor break down?
I will appreciate your help, since I'm broken down since my machine does not work.
  • fransal Mar 28, 2008
    Dear Cropp
    the Battery and AC power is no the problem, I have two notebook averatec 2300 and I tested microprocessor interchanging those in both laptops and they found no problems with the microprocessor, I tested also memories the same way in they also found no problem. What the problem could be?
  • lseid Mar 02, 2009
    Does not boot up and fan does not turn on. This laptop has been barely used. It's attractive but very disappointing.
  • 377 Answers
Hi dear
Ouch! Have you tried taking the battery out to see if it will run on AC power when the battery is not installed? Sometimes a bad battery can kill the system.
Do you have a meter that you can measure the output of the AC adapter with to see if it is correct? If not, any chance you could swap adapters with someone for a while to see if theirs works on your computer and vice versa? A local shop may also be able to test your adapter to see if it's working.
regards, cropp
Posted on Mar 28, 2008
I suggest replacing the battery. Also have you read your manual? Page 42-46 address power issues and suggest that you basically purge your battery every three months by going into the BIOS. I also know that on some laptops they just won't work at all without a battery in the battery compartment so I'm not sure removing the battery and testing on AC power will address your problem. Again, I think I would just purchase and replace the old battery.
Posted on Jun 03, 2008
Averatec 2300 series
Does it feel loose where the power cord plugs in? Did this happen overnight or were there more symptoms?
May 05, 2010 | Averatec 3200 Notebook
I have averatec laptop. The point where battery adapter is inserted start getting hot and burning smell comes..
The power jack has failed. You need to get a new one fitted.This you can do yourself or better still, get someone who knows repair shop or a mate.
Jan 04, 2010 | Averatec 3200 Notebook
Avweratec 2300 will not turn on
have you tried running it in safe mode? if it starts up then go to your start menu>all programs>accessories>system tools>system restore. go to a date before hand were it did work and your computer will restore itself.
Sep 10, 2009 | Averatec 3200 Notebook
Computer does not turn on when I press the power button
do u have the power adapter plugged in, or are you using battery power? the first thing i would try is disconnecting the battery. just compleatly remove it and set it aside. then try starting it with the adapter plugged in. sometimes the batteries go bad and are corrupt. i had this happen to a compaq laptop a few years back. after i got rid of the battery it worked fine. if it works u can always buy a new battery.
Feb 26, 2009 | Averatec 2371 AMD Turion Notebook
Averatec 2300 wont install windows XP
If you get the Windows splash screen (which you indicate you do), then the system is working. Unfortunately, when Windows starts, it is trying to use the video card drivers. It appears that the drivers may be corrupt. The initial way to check this is to hit F8 as it is starting to see if you can start windows in safe mode. If you can, go into the device manager and remove the display adapter you see there. When Windows starts, it should find it and either ask you for the drivers or start with generic drivers that work until you provide the correct ones.
Feb 01, 2009 | Averatec 3200 Notebook
Averatec 2300
My 2300 started same problems in Dec 08 (almost 2 years old) Its an overheat problem! With black screen the two blue lights an bottom left are on. Leave powered up and in an hour or so will shut down on its on, then will start back up normally but shut down again in about an hour.Correction 1. pull off back cover, blow out the dust. 2.Go to set up (F2 on power up and run fan cal) 3. Take the back cover off you will feel how hot the CPU and hard drive are that is because vents are too small for an aging laptop. Now take the cover and drill a double line of holes on each side of the hard drive vents, Next over the CPU (where the fan blows in air, drill a triple line of new vent holes in the cover). A 5/32 drill will be about right. You may also wish to purchase an inexpensive Belkin laptop cooler. About $19 at Best Buy. This solved my problem as I do like this little one for travel
Glenn New Mexico
Jun 22, 2008 | Computers & Internet
Averatec 2300 laptop will not power on.
We need to determine if the problem is your graphics chip or if the laptop really isn't booting. Do you get any kind of hard-drive activity light when you boot it up?
May 13, 2008 | Averatec 3200 Notebook
My averatec 3250 laptop has no sound
What would you like assistance with?
Dec 22, 2007 | Averatec 3120V Notebook
Computers & Internet Logo
552 people viewed this question
David Payne
David Payne
