Question about Cameras
Have an olympus stylus 1030sw camera. was working
Have an olympus stylus 1030sw camera. Was working fine up to 2 days ago. When cameras is turned on a chime (4 times) comes on and then the camera turns off. When turning camera in review mode able to review with no problems. What gives?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 10, 2010
Hi there, I used my camera in sea for many times, always was working nice. But some days ago I went to sea and the camera stopped working the flash. I left overnight off and next day it was working...
It still amazes me how many people buy these cameras that are seemingly "waterproof" and eventually have the very same problems you are now having. The only true underwater camera is one in an underwater housing.
Oct 25, 2010 | Olympus ? 1030SW Digital Camera
My Olympus µ 1030SW Digital Camera used to work fine when i plugged it into my computer to download photos. But ever since two days ago my computer now "does not recognise the usb device". Two other...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jul 10, 2010 | Olympus ? 1030SW Digital Camera
Olympus 1030sw say card full when it is definitly empty
1. Is there a slide switch on the side of the card? Is it unlocked? 2. Go into your camera's menu and find "reset"...follow the on-screen instructions. 3. Format the card in the camera.
Dec 08, 2009 | Olympus ? 1030SW Digital Camera
My Olympus 1030sw is 8 months old and I took it
Well, getting it wet voided your warranty. Remove the battery and card...don't try to turn it on to avoid short circuits.You can try to bury it in some dry, uncooked rice for a couple of days. Water , especially salt water, is disastrous to cameras. The chance of it working are slim and even if it does for awhile, it may stop altogether later. Keep your fingers crossed.
Nov 26, 2009 | Olympus ? 1030SW Digital Camera
OLYMPUS STYLUS 1030SW. up, down, left, right and centre buttons not working
good day,
although it might seem a hardware problem, you might also consider the software used in sensing what buttons are being pressed.
i suggest that you have it checked by a competent technician at your nearest olympus service center or to your seller. dont forget to bring your warranty card (if it is still valid).
i hope this helps
Oct 12, 2008 | Cameras
Write protect written across screen,will not allow me to view or take pictures,why??
try taking the xd card out and take a pic if the camera works i would try a new xd card faulty cards are pretty comon allthough i havnt seen that message before
Sep 26, 2008 | Olympus Stylus 710 Digital Camera
Olympus Not working period
I have the same camera - and almost exactly the same problem. It was working fine one day, next day not. I've done the battery thing - it's apparenty not the battery. Actuall, I have it a good "whack" with my hand and got it to turn on once, but don't think that's really very good for it in the long run. This camera is only about a year old - and I use it OFTEN.
Sep 12, 2005 | Olympus Camedia Stylus 300 Digital Camera
Cameras Logo
250 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
