Question about Kitchen Ranges
How to start self clean program - Kitchen Ranges
  • Kitchen Ranges Master
  • 43,501 Answers
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Posted on May 11, 2010
Need self-cleaning instructions....missing manual.
To Self-Clean: 1. Close the oven door. 2. Move the door lock lever to the right to the locked position. 3. Press CLEAN. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. If the door is not closed, beeps will sound and "door" will appear in the display until the door is closed and the Clean pad is pressed again. If the door is not closed within 45 seconds, the self-cleaning operation will be canceled and the display will return to the time of day. If more than 5 seconds elapse between pressing the Clean pad and the "up" or "down" arrow pad, the program will automatically return to the previous display
5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. 6. After 4 seconds, the oven will start cleaning. "LOCK" and "CLEAN" will appear in the display. The cleaning time will count down in the display. To Delay Start Self-Clean: Before delay starting Self-Clean, make sure the door is closed completely or it will not lock and the cycle will not begin. 1. Press DELAY. "DELAY" will flash and "00:00" will appear in the display. 2. Press the "up" or "down" arrow pads to enter the amount of time you want to delay the cycle. Delay time can be set from 10 minutes (00:10) to 11 hours and 59 minutes (11:59). 3. While "DELAY" is flashing, press the CLEAN pad. "CLEAN" will flash in the display. 4. Press the "up" or "down" arrow pad. CL-M (Clean - Medium soil, 3 hours) appears in the display. 5. To choose a clean setting other then Medium, press the "up" or "down" arrow pads to scroll through the self-cleaning settings. CL-H (Clean - Heavy soil, 4 hours) CL-M (Clean - Medium soil, 3 hours) CL-L (Clean - Light soil, 2 hours) Choosing a cleaning level automatically programs the selfcleaning time. After 4 seconds, "CLEAN," "DELAY," and "LOCK" will appear in the display to show that the oven is set for a delayed clean operation. The delay time is displayed
Apr 21, 2015 | Kitchen Ranges
Oven door won't lock, self clean won't start
this is a door lock error , you will need to replace
Feb 20, 2013 | Kitchen Ranges
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
When I try to use the self-clean program, I remove the racks but then the cleaning cycle won't start and the "remove racks" indicator is flashing. There is a vertical metal piece in the back of...
I just did the self clean function today. They need you to remove the rack supports from each side of the oven cavity. Simply pull up on them to remove. When I did this the message was not displayed and the slef clean function started. Hope that helps.
Darren
Nov 15, 2010 | Electrolux 30" Self-Cleaning Freestanding...
Self clean wont turn on!
Hi, If the self-cleaning operation on your double oven will not work, make sure the oven clock on the upper oven shows the correct time of day. In addition, Make sure the Lock Lever is in the cleaning position, pushed all the way to the right on the top oven. If a delayed start time has been programmed, that may be the cause of the cleaning cycle not beginning right away.
Thanks for using fixya....
Oct 28, 2010 | Thermador SC302T Electric Double Oven
Does not go into self clean only beeps
here is a link for your owners manual click here
To set Self-Clean:
2. Press the appropriate Clean pad.
• CLEAN flashes.
• SET and UPPER or LOWER flash in the display.
3. Press the Autoset pad.
• “MEd” (Medium Soil, 3 hours) is displayed.
4. Press the Autoset pad to scroll through the self-cleaning
settings.
“HVy” (Heavy Soil, 4 hours)
“MEd” (Medium soil, 3 hours)
“LITE” ( Light Soil, 2 hours)
Choosing the soil level of the oven automatically programs
the self-cleaning time.
5. After four seconds, the oven will start cleaning.
• If the door is not closed, beeps will sound and ‘door’ will
display. If the door is not closed within 30 seconds, the
• CLEAN will appear in the display.
• LOCK will flash in the display. Once the door locks,
LOCK will remain steady.
• The cleaning time will start counting down in the
display.
Please take the time to rate this solution
Jan 30, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
Hotpoint Self Cleaning Oven
the oven has a feature where you set the time for it to begin cleaning and the time for it to end cleaning.
Next to the clock in the middle of the back are two dials. The top one is the start time, the bottom one is the end time.
I suggest 2 hours to allow a good cleaning.
The locked light will turn off when the cleaning is done, allowing you to open the locking lever.
Jan 17, 2008 | Ovens
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
187 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
