Question about Texas Instruments TI-83 Plus Calculator
Im using the geometricpdf and everytime i plug in numbers and press enter it gives me err:argument. How do i fix this?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Make sure the first argument is a number between 0 and 1, inclusive. Make sure the second argument is an integer or a list of integers.
Posted on May 10, 2010
I get ERR: DATA TYPE
Error Data Type mean that you entered a value or variable that is the wrong data type:
• For a function (including implied multiplication)
or an instruction, you entered an argument that
is an invalid data type, such as a complex
number where a real number is required. See
Appendix A and the appropriate chapter.
• In an editor, you entered a type that is not
allowed, such as a matrix entered as an element
in the stat list editor. See the appropriate
chapter.
• You attempted to store an incorrect data type,
such as a matrix, to a list.
Jan 14, 2013 | Texas Instruments TI-84 Plus Calculator
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
Everytime I try to do powers and square roots I get an error message
An ERR: MEMORY is given when there is not enough memory to perform the instruction or function. To increase available memory by deleting the contents of any variable (real or complex number, list, matrix, Y= variable, program, Apps, AppVars, picture, graph database, or string), follow these steps. • Press [2nd] [MEM] to display the MEMORY menu.
• Press 2: Mem Mgmt/Del.
• Select a variable or data that needs to be deleted and press [ENTER].
• Use the arrow keys to move the cursor next to the item, and then press [DEL]. The variable or data should now be deleted from the memory.
When deleting programs or Apps, a message asking for confirmation will appear. Select 2:Yes to continue. To leave any variable screen without deleting anything, press [2nd] [MODE].
Jun 29, 2012 | Texas Instruments TI-84 Plus Silver...
Err Argument with binomcdf(7,0,.25,2) when trying to find No More than 2
binomcdf() takes two or three arguments, but you're providing four. The first argument is the number of trials (7 looks good for this), the second argument is the probability (.25 looks good for this), and the optional third argument is the number of successes (2 in your case).
Try binomcdf(7,.25,2)
Oct 04, 2011 | Texas Instruments TI-84 Plus Silver...
Im trying to graph inequalities on my ti 84 plus, and it keeps saying ERR:INVALID DIM. how do i fix it?
Try deactivating the Statistica plots.
Press [2nd][Y=] to enter Stat Plots. Press the PlotsOff menu option.
Sep 21, 2011 | Texas Instruments TI-84 Plus Calculator
How can i get logarithms on the calculator
For natural logarithms Press [2nd][X], enter a positive number, close the right parenthesis and press [ENTER]. If the number is decimal the result is displayed as a number. If the number is integer, put a decimal mark at its end to have the result displayed as decimal.
For decimal logarithms use the ALPHA keyboard to enter the log( command, complete the argument and press ENTER
If you want to calculate log in base a of number b type log(b,a).
Apr 13, 2010 | Texas Instruments TI-89 Calculator
Do I need a virus checker installed if im using
There are arguments that you do not need it for CE. If you decide you do want it, Avast has a very good product. Here an arguments that it is not needed, including a link to a blog on the subject.
Thanks
Mar 09, 2010 | Computers & Internet
Excel 07 truncuating problem
You need to use the ROUND function.
E.g. type: =ROUND(A1,2)*A2
Assuming the 2.131576 is in cell A1 and 1000 is in A2.
The round function round the value to 2 decimals (in this case because I specified 2 as the second argument).
May 06, 2009 | Keystone Excel 2007 Essentials for PC...
Calculating out npv and irr
Use the "FINANCE" app:
[APPS] [1] [ENTER]
for npv: select "7:NPV"
now you should get "npv(" on your screen.
use: npv(interest rate, cost {cash flows}, {frequencies of cash flows})
for irr: select "8: irr"
"irr(" will come up.
use: irr(interest rate, cost {cash flows}, {frequencies of cash flows})
May 13, 2008 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
140 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
