Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My Craftsman 1/2 hp garage door opener will go up fine with the push of any button but it starts then stops when I try to push the button for it to go down. It acts like there is something in front of the sensor but there's not. And the sensors are lined up fine. Help!
    President:
  • 3,197 Answers
If the main light flashes 10 times when the door stops it is a door sensor problem. Make sure the small light on each one is lit and not flickering. If the main light doesn't flash you have either a bad IR sensor which is a small printed circuit board just in front of the motor or you need to increase the down force which is a control on the rear of the motor unit.
Posted on May 10, 2010
Craftsman 1/2 HP assurelink garage door opener: hums for 1-2 seconds with no movement. what is wrong?
If the torsion spring is broken, the opener will try for 1-2 seconds and then time out. Watch u tube video below and then check to see if your torsion spring is broken.
Sep 18, 2014 | Craftsman 1/2 HP CHain Drive Garage Door...
We bought a Craftsman 1/4 hp garage door opener. It came with a car remote and a push button. The push botton works fine to open and close the door. But the car remote will only open the door. What do...
If you didn't install the door sensors you must. If you did, make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little.
Oct 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My craftsman 1/2 hp garage dood does not close when it's cold out (with either a push on the remote or a single push from the wall). I have to hold the wall button in until it's completely down. When I do...
Make sure the brackets for the sensors are tight and the small light on the sensors is not blinking ever so slightly. You also might try shading the sensor so that the sun is not shining directly into the lens.
May 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: My craftsman 1/2 hp garage dood does not close whe...
If the main light flashes 10 times when you try to close the door it is a sensor problem. Make sure they are not flickering ever so slightly and that they are not loose on their brackets. Tweak them a little bit.
May 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 HP garage door opener will go up fine with the push of any button, but it starts then stops when I try to push the button for it to go down. It acts like there is something in front of the...
If the main light flashes 10 times and the door reverses to the open position it is a door sensor problem. Make sure the small light on each sensor is lit and not flickering. If they aren't lit tweak them a bit. If they both won't come on you have a bad sensor or the wiring leading to it.
If the main light doesn't flash 10 times you can increase the 'down force' which is a control on the rear of the motor unit. Increase this just a bit and try.
Mar 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Cannot get remote for garage door to work
push the green button on the opener then push your remote button
Jan 25, 2010 | Locks & Locksmithing
My Craftsman 139.53879 remote won't learn the code of my 1/2 HP craftsman receiver type 132C2105-3B. I followed the directions to push the transmitter button and hold the receiver button down until the...
I have no idea what a 132C2105-3B is but try this. Hold the button down on the remote and then press and immediately release the smart/learn button. If the remote is the correct one for your opener it should work.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming kepad for Sears Craftsman Garagedoor opener 1/2 hp
The only procedure I have ever followed is to press the learn button and then enter the code, and not do anything else. I think your last step of holding the button until the light goes out is clearing codes as fast as you enter them. Just stop after you enter your code and let the learn mode time out on its own. That should do it.
And don't put your head through the wall. It just causes more headaches.
Feb 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opened, won't close
If you can press and hold the wall button and the door will go down, you have a photo eye issue. Check the photo eyes at the bottom of the door.
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
205 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
