Question about Boating
I have a 1995 Ranger Sport R72. I want to remove
I have a 1995 Ranger Sport R72. I want to remove the bench seat but see no screws/bolts holding it in place. How is it held in place?
I have the same boat OK here is what you do...on the back of the bench seat on driver and passenger side where the humps are...take a regular screw driver pry one the back its velcroed down pull it up and bam three screws on each side seat will slide forward and pull it out!!!
Posted on Aug 22, 2012
How do you remove the middle bench seat on 2001 ford windstar? I already removed the 3rd row bench seat but the middle one has seatbelts attached to it and I can't figure out how to get them off the seat...
ok if you can see were they are bolt to the floor remove it from there and take the seat out with it,now if that seat is hold down by going in a slot and with a lever you pull or push to take out just do what you have to remove the seat
Jun 26, 2014 | Cars & Trucks
How to remove the seat from a 1995 honda shadow 1100 american classic edition
An screw the rear seat bolt under the sissy bar, take of rear seat, an screw 2 bolts behind front seat, take the seat of by pulling it a little bit back.
May 24, 2014 | 1995 Honda VT 1100 C Shadow Spirit
Do I need to use power tools to remove/reinstall the bench seat bolts?
yes tighting them by hand will be enough to hold the seats saftly, you shouldnt worry about it
May 05, 2013 | 1997 Mercury Villager
Change fuel pump,how to
pull the back seat out (pull up on the rear bench, look at the front of the bench by the bottom, there is a small bracket (both sides) the goes into a molded space in the floor-push the front of the seat back hard and pull up, the bottom of the seat comes off)-then unscrew the bolts/screws that hold the back of the seat to the car, and you have no back seat anymore...pull up the rug/insulation and you will see a rounded, rectangular plate held in place by screws-remove those screw, and remove the plate-there is the fuel pump. Unplug the harness, hoses and unscrew the large plastic collar to lift out the fuel pump-be careful you do not damage the sender unit when you lift out the assembly.
Mar 14, 2011 | 2000 Oldsmobile Intrigue
Remove the back seat from chevy celebrty 1987
Push lower end of rear seat back to unlock clips (takes a bit of effort)
Lift bench out
Should be clips or bolts holding the top of the rear seat - release these
Push up on the upper section of seat to release top clips.
in some car models
Remove the 10mm bolt behind the bench near the seat belt fastening sight and then lift the seat up from the back to the front..towards the front seats. The clips are angled down and in so that the back has to lift up first.
This will help. Thanks please keep updated. please please do rate the solution positively .thank you for using fixya
Mar 18, 2010 | 1987 Chevrolet Celebrity
How do you remove the armrest on the front seats?
The armrests have covers that can be removed. Locate the zipper on the arm rest. Once you unzip it pull it toward the back of the arm rest and this will expose the one bolt that hold the armrest on. You will need a large torx and rachet to get it off. Once you take out that bolt the armrest will come right off.
Feb 02, 2010 | 1995 Ford Bronco
How to remove the back seat from my 1998 Mercury Villager
it is not designed to be removed. It is designed to slide back and forth as needed.
Section 01-10: Seats and Tracks 1998 Villager Workshop Manual
REMOVAL AND INSTALLATION Seat, Rear Bench
Removal
  1. Remove the center seat(s) if equipped. Refer to the procedure in this section.
  1. Slide the bench seat forward to the center row seating position.
  1. Use a flat-blade screwdriver to remove the cover caps from the front of the rear seat cushion latch cover.
  1. Remove the two rear seat bolts from the front of the rear seat cushion latch cover.
  1. Lift the rear seat cushion floor cover on the back of the rear bench seat and remove the two inboard rear seat bolts and the two outboard rear seat bolts.
  1. Remove the bench seat from the vehicle through the body side door opening.
Apr 30, 2009 | 1998 Mercury Villager
I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
c4253aa.gif Seat —Third Row Bench Removal
sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
  1. Remove the second row seats. For additional information, refer to Seat—Second Row .
  1. Remove the floor mats.
  1. Lock the seat cushion in the upright position.
    1. Lift the handle to release the cushion.
  1. Move the third row bench seat to the second row position.
    • Lift the seat track release handle.
  1. Remove the two bolt covers.
  1. Remove the two seat track front bolts.
  1. Remove the four seat track rear bolts.
    1. Position the rear seat cushion floor cover aside.
  1. Remove the third row bench seat.
Mar 02, 2009 | 1997 Mercury Villager
Boating Logo
704 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
