Question about SanDisk Sansa e260 MP3 Player
Blank Screen I don't know what I did wrong but my Sansa e250 has lighted wheel but nothing showing on the screen. It turns on and off. I tried the recovery mode but it doesn't show on the screen.
Try letting the battery run out than plug it into your computer and see if that works
it sounds dumb but i had a similar problem and it worked
Posted on Apr 01, 2008
SOURCE:
Blank screen
make sure the battery is fully charged, then disconnect from your computer. Wait a while for the device to cool and try turning it on again. Mine took a few tries but once it sat for a while it didnt fight me again.
Apr 02, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e250
I have a proplem with my sansa e250 after upgrading it. Now I can't start my sansa. The whole sansa is frozen. Just appear SanDisk logo on the screen, blue wheel lite and that's all.
I tryed several time to reset it by pressing the power on (menu) buton for more than 15 sec. It power of after that, but when I try to start it again problem persist - sansa e250 is frozen after logo of sandisk apear on the screen.
Please help me
Aug 17, 2008 | SanDisk Sansa m250 MP3 Player
My mp3 won't turn on
How do i set up a playlist
Apr 10, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 won't turn off
My Sansa e250 wanr turn on and i had a full battery whats wrong
Mar 08, 2008 | SanDisk Sansa e250 MP3 Player
My Sansa e250 wont turn on
http://sansae200.blogspot.com/
Dec 05, 2007 | SanDisk Sansa e250 MP3 Player
I was using my sansa e250 when it froze
perform soft reset on the device press and hold the menu/power button for about 30 secs until the player turns off.
Dec 03, 2007 | SanDisk Sansa e250 MP3 Player
A blank screen
Try going to recovery mode by enabling the hold switch then press the record button then press the menu button until you see on the player screen welcom to recovery mode. Download the update from the sandisk site then install and run it on your computer. Then perform the update. Hope that helps.
Jun 14, 2007 | SanDisk Sansa e250 MP3 Player
I need help with my sansa e250 mp3 player
Hi. Seems like your player may be encountering some corruption. Try this and see if it would help: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Let me know if this helped :)
Apr 21, 2007 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
