Question about Nintendo NES Console
White dotted lines on screen of NES
I just replaced my 72 pin connector. The nintendo does work, however, there are tons of vertical white dotted lines on my screen? What is going on?? What else could be wrong?
I got the same problem with mine i also got a copy of zelda that is actually ghosts and goblins what is best way to clean games?
Posted on May 13, 2008
  • Rosstehboss May 13, 2008
    ok i zoomed around the net since we have the same problem ppl say it is dust and grime getting into the 72 pin connector it also helps if u clean the connection part of the chip on each game im gonna try to opent mine up and clean everything that should help
    Sergeant:
    Champion:
  • 250 Answers
Clean your games too once you replace the 72 pin connector or you're just dirtying it up again. Not to mention the games has enough crud to keep them from working correctly.
Posted on Mar 29, 2008
I have 2 Nintendo NES systems. One I thought didn't work and needed the 72 pin piece changed, but when I turned it on the other day, it sort of worked. The people in the games came up with letters and...
Secret trick: take NES cartridge, press cartridge down and waggle the cartridge inside the NES and then hold the NES down and shove the cartridge onto the pins. An alternate solution is to take a Q tip, dip it in rubbing alcohol and clean out all the dust inside your game.
Mar 23, 2015 | Nintendo NES Console
When I start my NES up it comes up with a white screen and does nothing else once it gets to that point. I've tried using an old NES cleaning kit and that helped it go from a flashing screen to that solid...
There is a 72 pin cartridge slot inside the NES that wears over time, I believe replacing this should correct the problem. You can pick one up for about 5 bucks.
Jan 16, 2011 | Nintendo NES Console
Hi, My nes only displays a white screen when switched on with a game inserted. I have changed the 72 pin connector to one which I know works, cleaned the contact points the connector slides onto and used a...
Hi, probably need a new 72 pin connector, or you have bad capacitors or broken traces. we fix all those, check it out www.consolesolutions.net/nes
Aug 27, 2010 | Nintendo NES Console
NES two thick dotted vertical lines on screen
Well I think that the rf switch is causing this problem so use the NES av cable to see if it makes a difference then.
images?q=tbn:and9gcracbkpnp2t4htfajea_1tmjifpnwacluvc7urvlramcabqhv8aurfvvq
May 24, 2010 | Nintendo NES Console
NES Console: When ever I try to turn my NES on, the POWER light...
72 pin game cart adaptor needs replacing. they can be purchased for around £10 and make it work like nes
May 16, 2010 | Nintendo NES Console
NES-001 WHITE VIDEO PICTURE WITH SOUND OK
its most likely cause its over 10 years old
Jan 09, 2010 | Nintendo NES Console
Why do I have vertical white lines when I put any game into the NES system? Games will play but lines are annoying!
thats cause your connector is going bad probably. to verify this, instead of using the RF connector, use the a/v cables and if you get white lines either way then you know the connector inside of the NES needs to be changed.
Jan 05, 2010 | Nintendo NES Console
Nintendo NES Console Logo
958 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
